Доброго времени суток!
Есть пара nexus 7k и нужно настроить между ними EoMPLS.
Всё вроде бы хорошо: LDP есть, "xconnect" проходит, но сам трафик не ходит, по счётчикам видно, что уходят только пакеты, но ничего не приходит по mpls.
Ниже представлен конфиг:
interface loopback24
ip address x.x.24.2/32
interface Ethernet3/23.995
mpls ldp discovery transport-address interface
mpls ip
description mpls-test-vf
mtu 9126
encapsulation dot1q 995
ip address x.x.254.93/30
no shutdown
interface Ethernet3/22.58
description c1-mpls
mtu 9216
encapsulation dot1q 58
no shutdown
mpls ldp configuration
router-id Lo24 force
port-profile type pseudowire cm
encapsulation mpls
vc type ethernet
state enabled
l2vpn xconnect context core
member Ethernet3/22.58
member x.x.24.1 58 port-profile cm
Выход по команлам:
sh mpls ldp nei
Peer LDP Ident: x.x.24.1:0; Local LDP Ident x.x.24.2:0
TCP connection: x.x.24.1.646 - x.x.24.2.32754
State: Oper; Msgs sent/rcvd: 69/97; Downstream
Up time: 00:15:54
LDP discovery sources:
Targeted Hello x.x.24.2 -> x.x.24.1, active, passive
Addresses bound to peer LDP Ident:
sh mpls l2 vc 58 deta
Local interface: Eth3/22.58 up, Eth VLAN up
Interworking type is Ethernet
Destination address: x.x.24.1, VC ID: 58, VC status: up
Output interface: Ethernet3/23.995, imposed label stack {40}
Preferred path: not configured
Default path: active
Next hop: x.x.254.94
Create time: 1d17h, last status change time: 00:08:51
Last label FSM state change time: 00:08:51
Signaling protocol: LDP, peer x.x.24.1:0 up
Targeted Hello: x.x.24.2(LDP Id) -> x.x.24.1, LDP is UP
Graceful restart: configured and enabled
Non stop routing: not configured and not enabled
Status TLV support (local/remote) : enabled/supported
LDP route watch : enabled
Label/status state machine : established, LruRru
Last local dataplane status rcvd: No fault
Last BFD dataplane status rcvd: Not sent
Last BFD peer monitor status rcvd: No fault
Last local AC circuit status rcvd: No fault
Last local AC circuit status sent: No fault
Last local PW i/f circ status rcvd: No fault
Last local LDP TLV status sent: No fault
Last remote LDP TLV status rcvd: No fault
Last remote LDP ADJ status rcvd: No fault
MPLS VC labels: local 34, remote 40
Group ID: local 0, remote 0
MTU: local 9216, remote 9216
Remote interface description: c2-mpls
Sequencing: receive disabled, send disabled
Control Word: On (configured: autosense)
VC statistics:
transit packet totals: receive 0, send 51
transit byte totals: receive 0, send 3264
transit packet drops: receive 0, seq error 0, send 0
Второй сконфигурирован анологично, разница лишь в ip адресах на интерфейсах. Оба устройства соединены на прямую. Не могу понять почему не бегает трафик...
На обоих коммутаторах версия NSox : version 6.2(6)
Вы это имели ввиду?
ping mpls pseudowire x.x.24.1 58
Sending 5, 100-byte MPLS Echos to x.x.24.1,
timeout is 2 seconds, send interval is 0 msec:
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
'L' - labeled output interface, 'B' - unlabeled output interface,
'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
'M' - malformed request, 'm' - unsupported tlvs, 'N' - no label entry,
'P' - no rx intf label prot, 'p' - premature termination of LSP,
'R' - transit router, 'I' - unknown upstream index,
'X' - unknown return code, 'x' - return code 0
Type Ctrl-C to abort.
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
Total Time Elapsed 10 ms
я конеш нексусы не трогал никогда, но:
1) в манах первым делом предлагают включить "feature evc". включен?
2) на разных концах xconnect'а совпадают vlan? (у вас в примере 58)
1) он включен, но на данной схеме вроде он не особо нужен.
2) вланы совпадают, дальше нексусов идут каталисты, там разрешен только этот влан и поднят l3 интерфейс с vrf.
sh run int gi3/15
Building configuration...
Current configuration : 217 bytes
interface GigabitEthernet3/15
switchport trunk allowed vlan 58
switchport mode trunk
mtu 9198
ip device tracking maximum 0
ip access-group 166 in
load-interval 30
no cdp enable
end
interface Vlan58
description testmpls2
ip vrf forwarding cm2
ip address 10.0.0.2 255.255.255.252
end
3) лицензия есть? или они не энфорсятся?
Лицензии включены все, что есть.
install feature-set mpls
allow feature-set mpls
feature-set mpls
feature mpls l3vpn
feature mpls traffic-eng
feature mpls ldp
feature mpls l2vpn
а у вас в нексусе случаем не F2 платы стоят? если да, то они mpls не умеют.
Собираем на 1g модуле N7K-M148GT-11L - это модуль серии M1. В качестве Fabric card module стоит N7K-C7009-FAB-2.
  • 4 weeks later...
