mbike2000ru Posted July 3, 2014 Posted July 3, 2014 (edited) Коллеги, кто нибудь цеплял Grandstream HT503 к внутренним линиям Panasonic KX-TEB308? Цель - звонить на внутренние номера Панасоника с Астериска. я соединяю FXO порт с внутренней линией АТС Панасоник. ПРи входящем вызове на Панасоник in 1 Stage Dial - вызов рвется. (Когда использую режим 2 Stage Dial, то вызов проходит. Но нужен именно One Stage.) Я ставлю Wait For Dial Tone = Yes Есть какие то особенности у внутренних линий панасоника? SYSLOG: Jul 3 16:26:34 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] ATACtrl::processFxoOutgoingCallInitiated, Dial Plan Match = 1 r=13 Jul 3 16:26:34 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] Vinetic22::stopCidDetection on port 1:0 Jul 3 16:26:34 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] ATACtrl::processVoip2PstnCall 13, FXO Port 1:0 Off-hook Jul 3 16:26:34 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] ATACtrl::Start CPT Detection (tone 17) on port 1 Jul 3 16:26:34 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] ATACtrl::processVoip2PstnCall, Start Wait For Dial Tone Timer = 10 Jul 3 16:26:34 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] IFX_TAPI_EVENT_FXO_APOH event received on port 1 ch 0 Jul 3 16:26:34 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] Dispatching event: 34 (LINE_APOH) on port 1:0 Jul 3 16:26:34 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] ATACtrl::processFxoLineAPOH on port 1:0, status = FXO_WAIT_DIAL_TONE/CALL_IDLE ... Jul 3 16:26:42 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] SIPStack(1)::run: Active call dialogs: 1 Jul 3 16:26:43 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] Dispatching event: 17 (CALL_FAILED) on port 1:0 Jul 3 16:26:43 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] SigCtrl::processCallFailed() on port 1:0 ptype 1 sCode 503, status FXO_WAIT_DIAL_TONE , sigReferred 0 Jul 3 16:26:43 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] ATACtrl::processCallFailed on port 1:0, status = FXO_WAIT_DIAL_TONE/CALL_IDLE stCode:503 canConf:0 ,sigReferred:0 Jul 3 16:26:43 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] ATACtrl::processCallFailed, FXO Port 1:0 On-hook sigReferred:0 Jul 3 16:26:43 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] Vinetic22::stopCidDetection on port 1:0 Jul 3 16:26:43 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] Vinetic::stopTone, Stop tone on port 1, direction 0 Jul 3 16:26:43 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] Vinetic::disableLEC, no need to disable LEC for port 1. Because LEC is not enabled. This could happen if FAX is involved and disableLEC set to YES Jul 3 16:26:43 HT-503 [00: 0B:82:5C:2D:7E]: [1.0.12.1] SIPStack::snd_message:(501)SIP/2.0 503 Service Unavailable Edited July 3, 2014 by mbike2000ru Вставить ник Quote
mbike2000ru Posted July 4, 2014 Author Posted July 4, 2014 Никто не подскажет, какие DIAL Tones надо в HT503 настраивать для Panasonic 308? Где то в этом причина, раз он ломается на этом шаге Вставить ник Quote
mbike2000ru Posted July 17, 2014 Author Posted July 17, 2014 РЕШЕНО. Проблему решила новая прошивка от Grandstream. Прошивку дали специальную, она не лежит на firmware.granstream.com. Вставить ник Quote
slapik Posted July 21, 2014 Posted July 21, 2014 Вообще по моему мнению новые шлюзы от Грандстрима - редкая кака. 4024 ставили мешками. Сейчас полностью перешли на линксис/циско и Элтекс. Вставить ник Quote
mbike2000ru Posted July 22, 2014 Author Posted July 22, 2014 у нас от Элтекса только smg1016. у Элтекса не было FXO,( у него только на много портов есть, а на 1-2 - нету), а Циску линскис (3102 например), как мне обьяснили -их уже сложно купить, вот поэтому чисто сидим на грандстримах. Поддержка у них оч хорошая, я проект уже сдал, так что несогласен по поводу низкого качества малопортовых грандстримов. У нас на сети HT502 в основном, ни одного сбоя. Вставить ник Quote
