не могу собрать шифрованый тунель между mikrotik и cisco
# apr/23/2014 09:21:44 by RouterOS 6.12
# software id = J46A-68XZ
/interface gre
add local-address=1.1.1.5 name=gre-tunnel10 remote-address=2.2.2.2
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
   mac-cookie-timeout=3d
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=md5 enc-algorithms=3des
/port
set 0 name=serial0
set 1 name=serial1
/routing ospf area
set [ find default=yes ] disabled=yes name="area 10"
add area-id=0.0.0.10 name=area1
/routing ospf instance
set [ find default=yes ] redistribute-connected=as-type-2 router-id=\
   10.0.90.25
/ip address
add address=1.1.1.5/24 comment="default configuration" interface=ether1 \
   network=1.1.1.0
add address=172.16.0.17/16 interface=ether2 network=172.16.0.0
add address=10.0.90.25/30 interface=gre-tunnel10 network=10.0.90.24
/ip dns
set servers=172.16.0.5
/ip firewall filter
add action=drop chain=input comment=drop_all disabled=yes in-interface=ether1 \
   protocol=tcp
add action=drop chain=input disabled=yes in-interface=ether1 protocol=udp
add chain=output comment=out protocol=udp
add chain=output protocol=tcp
add chain=input comment="Allow IPSec-esp" protocol=ipsec-esp
add chain=input comment="Allow IKE" dst-port=500 protocol=udp
add chain=input comment="Allow IPSec-ah" protocol=ipsec-ah
add chain=input comment=icp_input protocol=icmp
add chain=input comment=ssh dst-port=22 protocol=tcp
add chain=input dst-port=22 protocol=tcp
add action=add-src-to-address-list address-list=ssh_blacklist \
   address-list-timeout=3h chain=input connection-state=new dst-port=22 \
   protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage2 \
   address-list-timeout=1m chain=input connection-state=new dst-port=22 \
   protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage3 \
   protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage1 \
   protocol=tcp
add chain=input comment=www dst-port=80 protocol=tcp
add chain=input dst-port=443 protocol=tcp
add chain=input comment="access to winbox" dst-port=8291 in-interface=ether1 \
   protocol=tcp
add chain=input dst-port=8291 in-interface=ether2 protocol=tcp
add chain=input connection-state=new dst-port=8291,65522 protocol=tcp
add chain=input comment=dns dst-port=53 in-interface=all-ethernet protocol=\
   udp
add chain=input dst-port=53 in-interface=all-ethernet protocol=tcp
add chain=input connection-state=established
add chain=input connection-state=related
add chain=input dst-port=1723 protocol=tcp
add action=drop chain=input comment="drop ftp brute forcers" dst-port=21 \
   protocol=tcp src-address-list=ftp_blacklist
add chain=output content="530 Login incorrect" dst-limit=\
   1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist \
   address-list-timeout=1h chain=output content="530 Login incorrect" \
   protocol=tcp
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip ipsec peer
add address=2.2.2.2/32 enc-algorithm=3des hash-algorithm=md5 secret=\
   "pass"
/ip route
add distance=1 gateway=1.1.1.1
add disabled=yes distance=1 dst-address=10.0.90.26/32 gateway=gre-tunnel10
/ip upnp
set allow-disable-external-interface=no
/lcd interface
set sfp-sfpplus1 interface=sfp-sfpplus1
set sfp-sfpplus2 interface=sfp-sfpplus2
set ether1 interface=ether1
set ether2 interface=ether2
set ether3 interface=ether3
set ether4 interface=ether4
set ether5 interface=ether5
set ether6 interface=ether6
set ether7 interface=ether7
set ether8 interface=ether8
/routing ospf interface
add cost=700 interface=gre-tunnel10 network-type=broadcast
/routing ospf network
add area=area1 network=10.0.90.0/24
/system clock
set time-zone-name=Europe/Moscow
/system leds
set 0 type=interface-speed
set 2 type=interface-speed
/system ntp client
set enabled=yes mode=unicast primary-ntp=194.149.67.129 secondary-ntp=\
   172.16.0.5
/system routerboard settings
set cpu-frequency=1200MHz memory-frequency=1066DDR
на cisco
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key pass address 0.0.0.0 0.0.0.0
crypto ipsec transform-set tr-3des esp-3des
crypto ipsec profile prof_tun
set transform-set tr-3des
interface Tunnel10
bandwidth 30
ip address 10.0.90.26 255.255.255.252
ip mtu 1476
ip virtual-reassembly in
ip route-cache policy
ip ospf cost 700
ip ospf 100 area 10
tunnel source 2.2.2.2
tunnel mode ipsec ipv4
tunnel destination 1.1.1.5
tunnel protection ipsec profile prof_tun
с cisco
show interfaces tunnel 10
Tunnel10 is up, line protocol is down
 Hardware is Tunnel
 Internet address is 10.0.90.26/30
 MTU 17940 bytes, BW 30 Kbit/sec, DLY 50000 usec,
    reliability 255/255, txload 1/255, rxload 1/255
 Encapsulation TUNNEL, loopback not set
 Keepalive not set
 Tunnel source 83.167.101.203, destination 91.216.48.5
 Tunnel protocol/transport IPSEC/IP
 Tunnel TTL 255
 Tunnel transport MTU 1500 bytes
 Tunnel transmit bandwidth 8000 (kbps)
 Tunnel receive bandwidth 8000 (kbps)
 Tunnel protection via IPSec (profile "prof_tun")
 Last input 01:30:07, output 01:30:08, output hang never
 Last clearing of "show interface" counters never
 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
 Queueing strategy: fifo
 Output queue: 0/0 (size/max)
 5 minute input rate 0 bits/sec, 0 packets/sec
 5 minute output rate 0 bits/sec, 0 packets/sec
    24660 packets input, 2397924 bytes, 0 no buffer
    Received 0 broadcasts (0 IP multicasts)
    0 runts, 0 giants, 0 throttles
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    24417 packets output, 3108372 bytes, 0 underruns
    0 output errors, 0 collisions, 0 interface resets
    0 unknown protocol drops
    0 output buffer failures, 0 output buffers swapped out
с microtik ping 10.0.90.26
HOST                                     SIZE TTL TIME  STATUS
10.0.90.26                                              timeout
10.0.90.26                                              timeout
10.0.90.26                                              timeout
10.0.90.26                                              timeout
10.0.90.26                                              timeout
10.0.90.26                                              timeout
На микротике:
ip ipsec proposal add name="AES-128" auth-algorithms=md5 enc-algorithms=aes-128 lifetime=8m20s
ip ipsec policy add src-address=2.2.2.2/32 src-port=any dst-address=1.1.1.1/32 dst-port=any
protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=no
sa-src-address=2.2.2.2 sa-dst-address=1.1.1.1 proposal=AES-128
priority=10
ip ipsec add address=1.1.1.1/32 port=500 auth-method=pre-shared-key secret="PASS" generate-policy=yes exchange-mode=main send-initial-contact=yes nat-traversal=no my-id-user-fqdn="" proposal-check=obey hash-algorithm=sha1 enc-algorithm=3des dh-group=modp1536 lifetime=8m20s lifebytes=0 dpd-interval=disable-dpd dpd-maximum-failures=1
На циске:
crypto isakmp policy 66
encr 3des
group 5
lifetime 500
crypto isakmp key PASS address 2.2.2.2 no-xauth
crypto ipsec transform-set ipsec-transform esp-3des esp-md5-hmac
mode transport require
crypto ipsec transform-set ipsec-transform-aes esp-aes esp-md5-hmac
crypto ipsec df-bit clear
crypto ipsec profile ipsec-ipsec-aes
set transform-set ipsec-transform-aes
interface Tunnel123
description # Tunnel123 #
ip address 172.16.0.1 255.255.255.252
ip mtu 1450
ip ospf network point-to-point
ip ospf cost 10
ip ospf mtu-ignore
ip ospf 1 area 0.0.0.0
tunnel source 1.1.1.1
tunnel mode ipip
tunnel destination 2.2.2.2
tunnel protection ipsec profile ipsec-ipsec-aes
invalid value for argument enc-algorithms
ip ipsec proposal add name="AES-128" auth-algorithms=md5 enc-algorithms=aes-128-
aes-128-cbc  aes-128-ctr  aes-128-gcm
add нету
/ip ipsec>
IP security supports secure (encrypted) communications over IP networks
.. -- go up to ip
export -- Print or save an export script that can be used to restore configuration
installed-sa -- Currently installed security associations
key --
mode-config --
peer -- IKE peer configuration
policy -- Security policies
proposal -- phase2 IKE proposal settings
remote-peers -- Remote peers
statistics --
user --
/ip ipsec peer> add address=1.1.1.5 port=500 auth-method=pre-shared-key secret=PASS generate-policy=
eneratePolicy ::= no | port-override | port-strict
 port-override -- force policy to use any port
 port-strict -- use ports from peer's proposal
Edited by svetogor82
не хочет по прежнему соединяться
/ip ipsec policy> print detail
Flags: T - template, X - disabled, D - dynamic, I - inactive
0    src-address=1.1/1.5/32 src-port=any dst-address=2.2.2.2/32 dst-port=any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=no sa-src-address=1.1.1.5 sa-dst-address=2.2.2.2 proposal=AES-128 priority=10
/ip ipsec peer> print detail
Flags: X - disabled
0   address=2.2.2.2/32 local-address=0.0.0.0 passive=no port=500 auth-method=pre-shared-key secret="pass" generate-policy=port-override exchange-mode=main send-initial-contact=yes nat-traversal=no proposal-check=obey
/ip ipsec remote-peers> print detail
local-address=1.1.1.5 remote-address=2.2.2.2 state=message-3-sent side=initiator
/ip ipsec proposal> print detail
Flags: X - disabled, * - default
0 X* name="default" auth-algorithms=md5 enc-algorithms=3des lifetime=30m pfs-group=modp1024
1    name="AES-128" auth-algorithms=md5 enc-algorithms=aes-128-cbc lifetime=8m20s pfs-group=modp1024
с cisco
crypto isakmp key pass address 2.2.2.2 255.255.255.0 no-xauth
interface Tunnel20
ip mtu 1450
ip ospf cost 700
ip ospf mtu-ignore
ip ospf 100 area 10
tunnel mode ipip
show interfaces tunnel 20
Tunnel20 is up, line protocol is up
 Hardware is Tunnel
 Description: odincovo
 MTU 17920 bytes, BW 100 Kbit/sec, DLY 50000 usec,
 Keepalive not set
 Tunnel source 2.2.2.2, destination 1.1.1.5
 Tunnel protocol/transport IP/IP
 Tunnel TTL 255, Fast tunneling enabled
 Tunnel transport MTU 1480 bytes
 Tunnel protection via IPSec (profile "ipsec-ipsec-aes")
 Last input never, output 02:03:53, output hang never
 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 809
    0 packets input, 0 bytes, 0 no buffer
    810 packets output, 78480 bytes, 0 underruns
ping 10.0.90.25 source 10.0.90.26
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 10.0.90.25, timeout is 2 seconds:
Packet sent with a source address of 10.0.90.26
Success rate is 0 percent (0/5)
да работает если выключить ipsec
Включай дебаг IPSEC на циске и смотри что происходит.
Я дал полностью рабочий конфиг у меня так работают десятки девайсов.
Edited by myst
на cisco в логах только
%CRYPTO-4-IKMP_BAD_MESSAGE: IKE message from 1.1.1.5 failed its sanity check or is malformed
Время синхронизовать не пробовали ?
поменял на cisco
на
crypto isakmp key pass address 1.1.1.5 255.255.255.0 no-xauth
ошибка пропала время на устройствах стоит одинаковое
может на cisco забыл какие-нибудь логи включить сейчас включено
General-purpose tunnel:
 Tunnel Interface debugging is on
Cryptographic Subsystem:
 Crypto ISAKMP debugging is on
 Crypto IPSEC Error debugging is on
 Crypto IPSEC High Availability debugging is on
EzVPN:
 EzVPN debugging is on
еще в логах
 Tunnel20: IP/IP encapsulated 2.2.2.2->1.1.1.5 (linktype=7, len=96)
Тут надо с азов видимо проверять. Ipsec поднимется, если все параметры с обоих концов совпадут, поднимал между разными железяками. И еще надо проверить маршрутизацию меж сетями клиентов, что должно идти в туннель, а что - мимо... Нельзя например в ipsec завернуть весь интернет, только описанные сети и маски, и уж одинаковые сети завернуть в ipsec мне ни разу не удалось, только маршутизируемые.
еще в логах
В IPsec можно завернуть что угодно.
Было бы желание.
после перезагруздки cisco в логах поевилось
*Apr 24 05:59:55.251: IPSEC(key_engine): request timer fired: count = 2,
 (identity) local= 2.2.2.2:0, remote= 1.1.1.5:0,
   local_proxy= 2.2.2.2/255.255.255.255/4/0 (type=1),
   remote_proxy= 1.1.1.5/255.255.255.255/4/0 (type=1)
*Apr 24 05:59:55.275: IPSEC(key_engine): got a queue event with 1 KMI message(s)
*Apr 24 06:00:02.871: IPSEC(sa_request): ,
 (key eng. msg.) OUTBOUND local= 2.2.2.2:500, remote= 1.1.1.5:500,
   remote_proxy= 1.1.1.5/255.255.255.255/4/0 (type=1),
   protocol= ESP, transform= esp-aes esp-md5-hmac  (Transport),
   lifedur= 3600s and 4608000kb,
   spi= 0x0(0), conn_id= 0, keysize= 128, flags= 0x0
*Apr 24 06:00:05.203: IPSEC(sa_request): ,
 (key eng. msg.) OUTBOUND local= 2.2.2.2:500, remote= 2.2.2.2:500,
   local_proxy= 0.0.0.0/0.0.0.0/0/0 (type=4),
   remote_proxy= 0.0.0.0/0.0.0.0/0/0 (type=4),
   protocol= ESP, transform= esp-3des  (Tunnel),
   spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x0
еще в логах
*Apr 24 08:57:36.551: ISAKMP: set new node 0 to QM_IDLE
*Apr 24 08:57:36.551: ISAKMP:(0):SA is still budding. Attached new ipsec request to it. (local 2.2.2.2, remote 1.1.1.5)
*Apr 24 08:57:36.551: ISAKMP: Error while processing SA request: Failed to initialize SA
*Apr 24 08:57:36.551: ISAKMP: Error while processing KMI message 0, error 2.
*Apr 24 08:57:40.247: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
*Apr 24 08:57:40.247: ISAKMP (0): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
*Apr 24 08:57:40.247: ISAKMP:(0): sending packet to 1.1.1.5 my_port 500 peer_port 500 (I) MM_NO_STATE
*Apr 24 08:57:40.247: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Apr 24 08:57:43.523: ISAKMP:(0):purging node -808193248
*Apr 24 08:57:43.523: ISAKMP:(0):purging node 412670883
*Apr 24 08:57:44.539: ISAKMP (0): received packet from 1.1.1.5 dport 500 sport 500 Global (R) MM_NO_STATE
*Apr 24 08:57:45.207: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
*Apr 24 08:57:45.207: ISAKMP (0): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
