Добрый день
Купили мы cisco sce 2020 дабы шейпить трафик.
начали ставить sybase на red hat 6.4 и тут уже уперлись в стену. ставлю по инструкции, но при распаковки sybase выскакивает сообщение
[root@sce sybase]# ./installsyb.sh --sybhome=/home/sybase --datadir=/home/sybase_db/
Starting Sybase install sequence
testing dist file integrity...done
Running platform-specific check file...done
Adding sybase user...done
NOTE: if this installation aborts or fails, you may want
to remove the sybase process/user before attempting again. This
can be done with the command:
pkill -9 -xU sybase; userdel -r sybase
Extracting dist file to /usr/tmp/sybinstall17807...done
Running Sybase installer - this will take a while...done
Configuring Sybase ASE ...
Port number '4100' is being reserved or currently in use by a running server.
Building Adaptive Server 'pqbsyb1':
Writing entry into directory services...
Directory services entry complete.
Building master device...
sh: line 1: 18024 Segmentation fault (core dumped) /home/sybase/ASE-15_0/bin/dataserver -d/home/sybase/data/master.dat -b240M -z16k -spqbsyb1 -e/home/sybase/ASE-15_0/install/pqbsyb1.log -T1623 -f > /tmp/sbm2nvHw 2>&1
Task failed
dataserver: master device size for this server: 240.0 Mb
dataserver: master database size for this server: 104.0 Mb
dataserver: model database size for this server: 24.0 Mb
00:00000:00000:2013/06/24 13:13:15.97 kernel SySAM: Using licenses from: /home/sybase/SYSAM-2_0/licenses
00:00000:00000:2013/06/24 13:13:16.04 kernel SySAM: Checked out license for 1 ASE_CORE (2010.04040/permanent/148F 853E 92A9 E302).
00:00000:00000:2013/06/24 13:13:16.04 kernel This product is licensed to: CISCO SYSTEMS, an OEM license from Sybase, Inc.
00:00000:00000:2013/06/24 13:13:16.04 kernel Checked out license ASE_CORE
00:00000:00000:2013/06/24 13:13:16.04 kernel Adaptive Server Enterprise (Small Business Edition)
00:00000:00000:2013/06/24 13:13:16.17 kernel Initializing device /home/sybase/data/master.dat from offset 0 with zeros.
00:00000:00000:2013/06/24 13:13:18.85 kernel Finished initialization.
00:00000:00000:2013/06/24 13:13:18.85 kernel Using config area from primary master device.
00:00000:00000:2013/06/24 13:13:18.85 server Configuration Error: Configuration file, '/home/sybase/pqbsyb1.cfg', does not exist.
00:00000:00000:2013/06/24 13:13:18.94 kernel Warning: A configuration file was not specified and the default file '/home/sybase/pqbsyb1.cfg' does not exist. ASE creates the default file with the default configuration.
00:00000:00000:2013/06/24 13:13:18.96 kernel Warning: Using default file '/home/sybase/pqbsyb1.cfg' since a configuration file was not specified. Specify a configuration file name in the RUNSERVER file to avoid this message.
00:00000:00000:2013/06/24 13:13:18.98 kernel Internal run-time model set for Linux - Native
00:00000:00000:2013/06/24 13:13:18.99 kernel Using 4096 file descriptors.
00:00000:00000:2013/06/24 13:13:18.99 kernel Adaptive Server Enterprise/15.0.2/EBF 14331/P/Linux Intel/Linux 2.4.21-47.ELsmp i686/ase1502/2486/32-bit/FBO/Thu May 24 08:15:50 2007
00:00000:00000:2013/06/24 13:13:18.99 kernel Confidential property of Sybase, Inc.
00:00000:00000:2013/06/24 13:13:18.99 kernel Copyright 1987, 2007
00:00000:00000:2013/06/24 13:13:18.99 kernel Sybase, Inc. All rights reserved.
00:00000:00000:2013/06/24 13:13:18.99 kernel Unpublished rights reserved under U.S. copyright laws.
00:00000:00000:2013/06/24 13:13:18.99 kernel This software contains confidential and trade secret information of Sybase,
00:00000:00000:2013/06/24 13:13:18.99 kernel Inc. Use, duplication or disclosure of the software and documentation by
00:00000:00000:2013/06/24 13:13:18.99 kernel the U.S. Government is subject to restrictions set forth in a license
00:00000:00000:2013/06/24 13:13:18.99 kernel agreement between the Government and Sybase, Inc. or other written
00:00000:00000:2013/06/24 13:13:18.99 kernel agreement specifying the Government's rights to use the software and any
00:00000:00000:2013/06/24 13:13:18.99 kernel applicable FAR provisions, for example, FAR 52.227-19.
00:00000:00000:2013/06/24 13:13:18.99 kernel Sybase, Inc. One Sybase Drive, Dublin, CA 94568, USA
00:00000:00000:2013/06/24 13:13:18.99 kernel Using /home/sybase as the 'SYBASE' environment variable, found during startup.
00:00000:00000:2013/06/24 13:13:18.99 kernel Using OCS-15_0 as the 'SYBASE_OCS' environment variable, found during startup.
00:00000:00000:2013/06/24 13:13:18.99 kernel ASE booted on Linux release 2.6.32-358.el6.i686 version #1 SMP Tue Jan 29 11:48:01 EST 2013.
00:00000:00000:2013/06/24 13:13:18.99 kernel Using '/home/sybase/pqbsyb1.cfg' for configuration information.
00:00000:00000:2013/06/24 13:13:18.99 kernel Logging ASE messages in file '/home/sybase/ASE-15_0/install/pqbsyb1.log'.
00:00000:00000:2013/06/24 13:13:18.99 kernel Platform TCP network is forced to IPv4-only.
00:00000:00000:2013/06/24 13:13:19.00 kernel ASE booted with TCP_NODELAY enabled.
00:00000:00000:2013/06/24 13:13:19.01 kernel SSL Plus v5.0.4 security modules loaded successfully.
00:00000:00000:2013/06/24 13:13:19.01 kernel Network and device connection limit is 4081.
00:00Server 'pqbsyb1' was not created.
000:00000:2013/06/24 13:13:19.15 server Number of blocks left for proc headers: 6960.
00:00000:00000:2013/06/24 13:13:19.15 server Proc header memory allocated 1392 pages for each per engine cache
00:00000:00000:2013/06/24 13:13:19.25 server Size of the 16K memory pool: 8192 Kb
00:00000:00000:2013/06/24 13:13:19.25 server Memory allocated for the default data cache cachelet 1: 8192 Kb
00:00000:00000:2013/06/24 13:13:19.25 kernel Enabling Linux Native Kernel asynchronous disk I/O strategy.
00:00000:00000:2013/06/24 13:13:19.25 kernel Initializing virtual device 0, '/home/sybase/data/master.dat' with dsync 'off'.
00:00000:00000:2013/06/24 13:13:19.25 kernel Virtual device 0 started using asynchronous i/o.
00:00000:00000:2013/06/24 13:13:19.36 server Loaded default Unilib conversion handle.
00:00000:00000:2013/06/24 13:13:19.42 kernel Worker Thread Manager is not enabled for use in ASE.
00:00000:00000:2013/06/24 13:13:19.43 kernel Either the config parameter 'use security services' is set to 0, or ASE does not support use of external security mechanisms on this platform. The Security Control Layer will not be initialized. No external security mechanisms will be supported.
00:00000:00000:2013/06/24 13:13:19.43 kernel Unix interval timer enabled for sysclk interrupts.
00:00000:00000:2013/06/24 13:13:19.57 kernel Begin processing to generate RSA keypair.
00:00000:00000:2013/06/24 13:13:19.71 kernel Completed processing to generate RSA keypair.
00:00000:00000:2013/06/24 13:13:19.71 kernel Encryption provider initialization succeeded on engine 0.
00:00000:00000:2013/06/24 13:13:19.71 kernel engine 0, os pid 18024 online
Error - sybase ASE server configuration did not complete successfully - exiting.
[root@sce sybase]# ../install-scripts/uninstall.sh --sybase
Are you sure you want to uninstall the sybase ? (yes/no)[yes]: yes
Stopping Sybase server...
../install-scripts/uninstall.sh: line 65: /etc/init.d/sybase: Нет такого файла или каталога
Removing sybase process....
Removing sybase user...
Removing all sybase related symbolic links...
rm: невозможно удалить «/etc/rc*.d/[sK]*sybase»: Нет такого файла или каталога
Done
и на этом затык, подскажите что можно сэти сделатьили с чем это связано?
Это:
И это:
Взаимоисключающие параграфы.
Вы пытаетесь удалить то, что не установлено.
Stopping sybase server...
Done
Это действие я выполняю после неудачной установки, все по инструкции, чтобы удалить все хвосты от sybase и начать заново
у вас инсталлер падает. поковыряйте корку дебагером.
можно ещё пальцем в небо попробовать:
[root@sce sybase]# export LD_POINTER_GUARD=0; ./installsyb.sh --sybhome=/home/sybase --datadir=/home/sybase_db/
или
[root@sce sybase]# export LD_POINTER_GUARD=1; ./installsyb.sh --sybhome=/home/sybase --datadir=/home/sybase_db/
Есть подозрение, что если ТС поставит 5-ю шапку, то все взлетит.
Не помню что конкретно, но на 6-м центосе что-то из цисковского софта не вставало, а на 5-м вставало сразу и без вопросов.
установил я шапочку 5,3 и на ней действительно пошла установка, доходит до конца. но при проверки работоспособности sybase выдает "Sybase is not properly installed and configured".
как его нужно правильно сконфгурировать и запустить чтобы он нормально заработал?
Почему Вы так хотите поставить Sybase? У вас есть большой опыт работы с ним? Если нет, то зачем страдать, когда у большинства есть какой-то опыт работы с MySQL, на нём и ставьте.Только не забудьте доки почитать в части послеустановочного тюнинга - ну там скрипты, разрешающие агрегирование, разделение таблиц и пр.
Edited by MATPOC
Только сегодня перешел с редхата на центос 5.9 386 и обновился, установка на всё заняла около 1 часа. Не вижу проблем ни с sybase, ни mysql
