Есть работающее ядро на 7600-х. в ядре поднят VPLS, к ядру приходят кольца из свитчей с терминацией вланов по 802,1Q.
Пришел ME3600x, надо подружить его с VPLS. Подняли линк к одному из роутеров ядра.
Конфиги,
7600:
interface Loopback0
ip address 10.1.208.50 255.255.255.255
interface TenGigabitEthernet2/4 // порт карты ES+
mtu 1600
ip address 10.21.0.1 255.255.255.252
mpls ip
mpls label protocol ldp
l2 vfi vl950 manual
vpn id 950
neighbor 10.1.208.51 encapsulation mpls
neighbor 10.1.208.52 encapsulation mpls
neighbor 10.11.12.13 encapsulation mpls no-split-horizon //коннект к ME3600х
interface Vlan950
ip address 10.0.52.233 255.255.255.0
xconnect vfi vl950
router ospf 15
log-adjacency-changes
passive-interface default
no passive-interface TenGigabitEthernet2/2
no passive-interface TenGigabitEthernet2/3
no passive-interface TenGigabitEthernet2/4
network 10.20.0.4 0.0.0.3 area 1
network 10.20.0.8 0.0.0.3 area 1
network 10.21.0.0 0.0.0.3 area 1
network 10.1.208.50 0.0.0.0 area 1
ME3600x
interface Loopback0
ip address 10.11.12.13 255.255.255.255
interface TenGigabitEthernet0/1
no switchport
mtu 1600
ip address 10.21.0.2 255.255.255.252
mpls ip
interface Vlan950
no ip address
xconnect 10.1.208.50 950 encapsulation mpls
interface GigabitEthernet0/2
switchport access vlan 950
spanning-tree portfast
router ospf 15
no passive-interface TenGigabitEthernet0/1
network 10.11.12.13 0.0.0.0 area 1
самое интересное, что OSPF поднимается, LDP тоже, xconnect тоже
ME3600#sh xconnect int vl 950 det
XC ST Segment 1 S1 Segment 2 S2
UP pri ac Vl950:950(Eth VLAN) UP mpls 217.19.208.50:950 UP
Interworking: ethernet Local VC label 18
Remote VC label 57
ME3600#sh mpls l2transport vc 950 det
Local interface: Vl950 up, line protocol up, Eth VLAN 950 up
Interworking type is Ethernet
Destination address: 10.1.208.50, VC ID: 950, VC status: up
Output interface: Te0/1, imposed label stack {57}
Preferred path: not configured
Default path: active
Next hop: 10.21.0.1
Create time: 00:46:16, last status change time: 00:36:23
Signaling protocol: LDP, peer 217.19.208.50:0 up
Targeted Hello: 10.11.12.13(LDP Id) -> 10.1.208.50, LDP is UP
Status TLV support (local/remote) : enabled/supported
LDP route watch : disabled
Label/status state machine : established, LruRru
Last local dataplane status rcvd: No fault
Last BFD dataplane status rcvd: Not sent
Last BFD peer monitor status rcvd: No fault
Last local AC circuit status rcvd: No fault
Last local AC circuit status sent: No fault
Last local LDP TLV status sent: No fault
Last remote LDP TLV status rcvd: No fault
Last remote LDP ADJ status rcvd: No fault
MPLS VC labels: local 18, remote 57
Group ID: local 0, remote 0
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
Control Word: On (configured: autosense)
Dataplane:
SSM segment/switch IDs: 4099/12290 (used), PWID: 3
VC statistics:
transit packet totals: receive 1372, send 538
transit byte totals: receive 118162, send 44907
transit packet drops: receive 0, seq error 0, send 0
С другой стороны все так же.
Но на 7600-й не видно маков в 950 влане с ME3600x, а на ME3600x я вижу такую картину:
ME3600#sh mac add vl 950
Mac Address Table
Vlan Mac Address Type Ports
All 0100.0000.0000 STATIC CPU
All 0100.0ccc.cccc STATIC CPU
All 0100.0ccc.cccd STATIC CPU
All 0100.0ccc.ccce STATIC CPU
All 0100.0ccd.cdd0 STATIC CPU
All 0100.0cdd.dddd STATIC CPU
All 0180.c200.0000 STATIC CPU
All 0180.c200.0001 STATIC CPU
All 0180.c200.0002 STATIC CPU
All 0180.c200.0003 STATIC CPU
All 0180.c200.0004 STATIC CPU
All 0180.c200.0005 STATIC CPU
All 0180.c200.0006 STATIC CPU
All 0180.c200.0007 STATIC CPU
All 0180.c200.0008 STATIC CPU
All 0180.c200.0009 STATIC CPU
All 0180.c200.000a STATIC CPU
All 0180.c200.000b STATIC CPU
All 0180.c200.000c STATIC CPU
All 0180.c200.000d STATIC CPU
All 0180.c200.000e STATIC CPU
All 0180.c200.000f STATIC CPU
All 0180.c200.0010 STATIC CPU
All ffff.ffff.ffff STATIC CPU
950 0080.3782.5c5a DYNAMIC 0.0.0.0, 0
950 0080.3782.5d6d DYNAMIC 0.0.0.0, 0
950 0080.3782.769b DYNAMIC 0.0.0.0, 0
950 1cc1.dea0.2760 DYNAMIC Gi0/2
950 8843.e1df.1580 DYNAMIC 0.0.0.0, 0
Т.е. маки с 7600 приходят (и я даже вижу броадкаст от них на порту G0/2), но как-то странно пишется порт, откуда они пришли (0.0.0.0, 0)
А вот на 7600 мака 1cc1.dea0.2760 не видно, хотя он постоянно пытается пинговать узлы за VPLS.
Да, версии софта:
ME3600#sh ver
Cisco IOS Software, ME360x Software (ME360x-UNIVERSAL-M), Version 15.2(2)S1, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2012 by Cisco Systems, Inc.
Compiled Tue 22-May-12 21:21 by prod_rel_team
ROM: Bootstrap program is WHALES boot loader
BOOTLDR: ME360x Boot Loader (ME360X-HBOOT-M), Version 12.2 [sourdutt-loader_release_ledfix 100]
Switch uptime is 1 hour, 8 minutes
System returned to ROM by power-on
System image file is "flash:/me360x-universal-tar.152-2.S1/me360x-universal-mz.152-2.S1/me360x-universal-mz.152-2.S1.bin"
Last reload reason: Unknown reason
License Level: AdvancedMetroIPAccess
License Type: Permanent
Next reload license Level: AdvancedMetroIPAccess
cisco ME-3600X-24FS-M (PowerPC8572) processor (revision A0) with 1015808K/32760K bytes of memory.
Processor board ID FOC1614V1JB
Last reset from power-on
3 Virtual Ethernet interfaces
25 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
1536K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 2C:36:F8:B2:05:00
Motherboard assembly number : 73-12693-07
Motherboard serial number : FOC16110YCH
Model revision number : A0
Motherboard revision number : B0
Model number : ME-3600X-24FS-M
System serial number : FOC1614V1JB
Top Assembly Part Number : 800-32951-01
Top Assembly Revision Number : B0
Version ID : V01
CLEI Code Number : IPML500KRA
Configuration register is 0xF
7600#sh ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE3, RELEASE SOFTWARE (fc1)
Copyright © 1986-2011 by Cisco Systems, Inc.
Compiled Tue 25-Jan-11 11:09 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRB4, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE3, RELEASE SOFTWARE (fc1)
CORE-U uptime is 1 year, 15 weeks, 5 days, 2 hours, 55 minutes
Uptime for this control processor is 1 year, 15 weeks, 5 days, 29 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 14:06:35 MET Wed Mar 2 2011
System image file is "bootdisk:/c7600rsp72043-adventerprisek9-mz.122-33.SRE3.bin"
Last reload type: Normal Reload
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco CISCO7604 (M8500) processor (revision 2.0) with 1900544K/131072K bytes of memory.
Processor board ID FOX1420H5QQ
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
161 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
Configuration register is 0x2102
Уже замучился. Может это софтовый баг, или я что-то не так наконфигурил??
Ну хорошо, надо начать проверять все по порядку:
Во-первых, поддерживает такую конфигурацию ваша 3600 или нужна доп. Лицензия или еще чего :)
Во-вторых, точно такие же симптомы наблюдаются если сделать xconnect без es+ карт. См. Пункт первый :).
Ну и я ничего нового не скажу, если предложу проверить хождения трафика по меткам хоп за хопом.
Также нужно поснифать трафик на линках, приходят ли к вам пакетики через псевдопровод и совпадает ли там кол-во тегов dot1q ;)
Ну и я бы проверил сначала xconnect c 76 прямо в порт 3600. За одно и трафик поснифать получится.
командочка не помогла.
броадкастовый трафик из влана 950 приходит на 3600, маки в таблице я вижу. а вот на 7600 я маков, которые за 3600 находятся, не вижу.
пробовал делать xconnect на порт, та же ситуация, на порту броадкаст есть, а за роутер в обратную сторону ничего не проходит
Вот тут в презентации, вроде всё чётко http://www.cisco.com/application/pdf/en/us/guest/tech/tk891/c1482/ccmigration_09186a00801ed3ea.pdf
Настройки тоже вроде верные. Но может на что-то наведёт =)
А вот тут все варианты разобраны
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7600/es20lc/baldcfg.htm
Edited by triam
Другие neighbor в vfi как работают? Точнее Interworking type у них какой? А то 76-я в vfi умеет только одинаковые типы, а если тип vlan, то и тэги одинаковые должны быть.
в сторону других нейборов тоже Interworking type is Ethernet
я уж и vfi пробовал поднимать с ME3600, все равно не взлетает, 76-я не видит маков из-за 3600 хоть ты тресни!!!
drovorub
Если мне память не изменяет, ваша лицензия позволяет писать service instance на 3600
Попробуй вот так:
no switchport
service instance 11 ethernet
encapsulation untagged
mtu 1500
И ещё одна "хрень" за 76-й водится - если удалённая сторона на xconnect сначала прописана неправильно, а потом прописывается правильно, на 76-й надо всё убить и создать заново, чтобы заработало.
спасибо за совет! в понедельник попробую.
если не получится - буду обновлять софт на 7600. почему-то думается что проблема именно в 7600.
Я тут с похожей задачей. Только вместо 7600 у меня ASR1002
Пока решил не лепить похожую схему, официально ASR умеет VPLS, а 3600 - нет.
xconnect тут конечно все ясно и понятно, но вот будет ли работать - засомневался.
Кстати, что из имиджей gns умеет vpls ? :)
3600 в 15 ветке софта умеет VPLS. правда пока не знаю насколько надежно работает, но на тестовом стенде все ОК.
но мне VPLS в 3600 и не нужен пока. VPLS поднят в ядре на 7600, а оттуда будут xconnect в вланы на 3600, т.е. получается VPLS с доступом по MPLS (H-VPLS). Но как я писал выше, пока не получается стык с 7600, хотя на тестовом стенде я поднял на 3600 vpls и оттуда кинул xconnect на другую 3600 и все работало. думаю все-таки косяк с софтом на 7600. попробую поставить на 7600 софт из 15-й ветки, авось поможет.
на GNS не видел девайсов, которые поддерживают VPLS. 7200 поддерживает обычный MPLS, на ней можно и потренироваться, она есть в GNS.
Edited by drovorub
Да с MPLS на 7200 я и тренируюсь. По поводу 15 ветки спасибо, фичанафигатор по этой теме промолчал :(
Ок, попробуем-с
