имеется шасси 6506
с супом SUP720-3BXL + плата WS-X6748-GE-TX с DFC3BXL
пытаюсь влить bgp full view и получаю
Jan 16 09:08:41: %SYS-DFC1-2-MALLOCFAIL: Memory allocation of 18180 bytes failed from 0x209BD724, alignment 8
Pool: Processor  Free: 21560  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "XDR LC Background", ipl= 0, pid= 253
-Traceback= 2098FC50 20996264 209BD72C 206FEAF8 20741074 20A832EC 20A83980 20A84B38 20679134 20A1842C 20D3C84C 20A206D0 20A21468 2097A7A4 2097A790
*Jan 16 09:08:42: %FIB-2-FIBDISABLE: Fatal error, slot 1/0 (1): CEF-IPv4: no memry
Jan 16 09:08:41: %LFD-DFC1-3-NOOCE: Attempt to get labels from OCE failed - Clearing all OCEs.
-Traceback= 206D2E94 20741428 20A832EC 20A83980 20A84B38 20679134 20A1842C 20D3C84C 20A206D0 20A21468 2097A7A4 2097A790
Jan 16 09:08:42: %COMMON_FIB-DFC1-3-NOMEM: Memory allocation failure for fib entry insertion in IPv4 CEF [0x20429600] (fatal) (3946 subsequent failures).
Jan 16 09:08:42: %COMMON_FIB-DFC1-4-DISABLING: IPv4 CEF is being disabled due to a fatal error.
Jan 16 09:08:42: %XDR-DFC1-6-XDRLCDISABLEREQUEST: Client CEF push requested to be disabled.
-Traceback= 20A21DFC 20A7DB24 20A807AC 2042A390 204303F0 20428554 20428718 2097A7A4 2097A790
*Jan 16 09:08:47: %FIB-2-FIBDISABLE: Fatal error, slot 1/0 (1): CEF-Common: no memory
00:06:50: DFC1: cfib_enqueue_object_delete: no memory for cfib_fibmsg_chunk
*Jan 16 09:11:27: %MLSCEF-SP-4-FIB_EXCEPTION_THRESHOLD: Hardware CEF entry usage is at 95% capacity for IPv4 unicast protocol.
%Packets to the router's IP will be subject to the output ACLs of the input VLAN
*Jan 16 09:11:37: %C6K_MPLS_LC-SP-5-TCAM_EXCEPTION: TCAM exception occured for MPLS, traffic will be software switched
*Jan 16 09:11:37: %CFIB-SP-7-CFIB_EXCEPTION: FIB TCAM exception, Some entries will be software switched
Jan 16 09:12:08: %MLSCEF-DFC3-4-FIB_EXCEPTION_THRESHOLD: Hardware CEF entry usage is at 95% capacity for MPLS protocol.
Jan 16 09:12:19: %CFIB-DFC3-7-CFIB_EXCEPTION: FIB TCAM exception, Some entries will be software switched
Jan 16 09:12:19: %C6K_MPLS_LC-DFC3-5-TCAM_EXCEPTION: TCAM exception occured for MPLS, traffic will be software switched
после этого на 1 модуле вырубается cef
sh cef linecard
Slot   Flags
6/0    up
1/0    disabled
статус cef-a
sh cef state
CEF Status:
RP instance
common CEF enabled
IPv4 CEF Status:
CEF enabled/running
dCEF enabled/running
CEF switching enabled/running
universal per-destination load sharing algorithm, id 4084E4E5
IPv6 CEF Status:
CEF disabled/not running
dCEF disabled/not running
RRP state:
I am standby RRP:                   no
RF Peer Presence:                   no
RF PeerComm reached:                no
RF Progression blocked:             never
Redundancy mode:                    sso(3)
CEF NSF sync:                       disabled/not running
sh ip cef summary
IPv4 CEF is enabled for distributed and running
VRF base:
17 prefixes (17/0 fwd/non-fwd)
Table id 0
Database epoch:        6 (17 entries at this epoch)
на плате памяти, хотя должно быть 1G http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_12409.html
remote command module 1 show memory summary
               Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   254DF320   179440672   157982204    21458468       20680      240908
кто с таким сталкивался?
снял с платы WS-X6748-GE-TX - DFC и прикрутил на нее CFC, табличка bgp влилась без проблем и ошибок
но тогда модуль работает в режиме
sh fab
show fabric active:
Active fabric card in slot 6
No backup fabric card in the system
show fabric mode:
Global switching mode is Compact
dCEF mode is not enforced for system to operate
Fabric module is not  required for system to operate
Modules are allowed to operate in bus mode
Truncated mode is allowed, due to presence of DFC, CEF720 module
Module Slot     Switching Mode
   1                 Crossbar
   6                     dCEF
но так использовать не хочется
show platform hardware pfc mode
PFC operating mode : PFC3BXL
думаю (но пока не уверен) мало памяти на модуле WS-X6748-GE-TX
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Module_Installation/Mod_Install_Guide/0adtrcrd.html
циска пишет что для WS-F6700-DFC3BXL - 1 GB (и сноска - Requires a memory upgrade on the base module. Refer to the Catalyst 6500 Series DFC3A, DFC3B, DFC3BXL, DFC3C, and DFC3CXL Installation Note for additional information.)
с модуля где установлена DFC
remote command module 2 sh ver
Cisco IOS Software, c6lc2 Software (c6lc2-SP-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 01:29 by prod_rel_team
ROM: System Bootstrap, Version 12.2(18r)S1, RELEASE SOFTWARE (fc1)
core uptime is 2 hours, 50 minutes
System returned to ROM by power-on
System restarted at 07:22:02 MSK Mon Jan 17 2000
Running default software
cisco Catalyst 6000 (SB1121) processor with 262144K bytes of memory.
Processor board ID SAL1429NCQ9
SB1121 Processor (Rev 48)
Unknown CPU at 400Mhz, Implementation 0x410, Rev 5.0
Last reset from power-on
123K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x100
remote command module 2 sh mem su
Processor   254DF320   179440672   109269652    70171020           0    14945948
Edited by dmitry_
Что-то мне кажется не в количестве памяти тут дело. Маршруты в tcam устанавливаются и с ним какие-то проблемы. Может иос поменять?
Еще циска говорит про такую команду mls cef maximum-routes ... ?
Можно еще вывод команды до загрузки full view?
show mls cef summary module 2
Edited by dead0001
общие настройки
#sh mod
Mod Ports Card Type                              Model              Serial No.
 1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
 2   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
 3    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE
 6    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL
Mod MAC addresses                       Hw    Fw           Sw           Status
 1  ...   2.0   12.2(14r)S5  12.2(33)SXI5 Ok
 2  ...   4.4   12.2(18r)S1  12.2(33)SXI5 Ok
 3  ...   1.5   12.2(18r)S1  12.2(33)SXI5 Ok
 6  ...   4.3   8.1(3)       12.2(33)SXI5 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
 1  Centralized Forwarding Card WS-F6700-CFC       XXX 2.0    Ok
 2  Distributed Forwarding Card WS-F6700-DFC3BXL   XXX 5.3    Ok
 3  Distributed Forwarding Card WS-F6700-DFC3CXL   XXX 1.2    Ok
 6  Policy Feature Card 3       WS-F6K-PFC3BXL     XXX 1.6    Ok
 6  MSFC3 Daughterboard         WS-SUP720          XXX 2.3    Ok
#sh mls cef maximum-routes
FIB TCAM maximum routes :
Current :-
IPv4                - 500k
MPLS                - 400k
IPv6 + IP Multicast - 56k (default)
без Full view
#show mls cef summary module 2
Total routes:                                    48
   IPv4 unicast routes:                         31
       IPv4 non-vrf routes:                     13
       IPv4 vrf routes:                         18
   IPv4 Multicast routes:                       4
   MPLS routes:                                 8
   IPv6 unicast routes:                         1
       IPv6 non-vrf routes:                     1
       IPv6 vrf routes:                         0
   IPv6 multicast routes:                       3
   EoM routes:                                  1
sh cef linecard
Slot   Flags
6/0    up
2/0    up
3/0    up
VRF IPv4:__Platform_iVRF:_ID00_, 11 routes
Slot    I/Fs State    Flags
6/0        0 Active   sync, table-up
2/0        0 Active   sync, table-up
3/0        0 Active   sync, table-up
VRF IPv4:FV, 18 routes
VRF IPv4:Default, 12 routes
6/0        5 Active   sync, table-up
2/0       27 Active   sync, table-up
3/0       11 Active   sync, table-up
VRF IPv6:Default, 2 routes
show platform hardware capacity forwarding
L2 Forwarding Resources
          MAC Table usage:   Module  Collisions  Total       Used       %Used
                             2                0  65536         20          1%
                             3                0  98304         20          1%
                             6                0  65536         20          1%
            VPN CAM usage:                       Total       Used       %Used
                                                   512          1          1%
L3 Forwarding Resources
            FIB TCAM usage:                     Total        Used       %Used
                 72 bits (IPv4, MPLS, EoM)     933888          51          1%
                144 bits (IP mcast, IPv6)       57344           8          1%
                    detail:      Protocol                    Used       %Used
                                 IPv4                          42          1%
                                 MPLS                           8          1%
                                 EoM                            1          1%
                                 IPv6                           1          1%
                                 IPv4 mcast                     4          1%
                                 IPv6 mcast                     3          1%
           Adjacency usage:                     Total        Used       %Used
                                              1048576         174          1%
с Full view (влил 2 FV)
Total routes:                                    15
   IPv4 unicast routes:                         2
       IPv4 non-vrf routes:                     2
       IPv4 vrf routes:                         0
   MPLS routes:                                 5
   IPv6 unicast routes:                         0
       IPv6 non-vrf routes:                     0
       IPv6 vrf routes:                         0
   EoM routes:                                  1
#sh cef linecard
Slot   Flags
6/0    up
3/0    up
2/0    disabled
2/0        0 Inactive table-disabled
VRF IPv4:FV, 385602 routes
VRF IPv4:Default, 13 routes
2/0       27 Active   table-disabled
2/0        0 Active   table-disabled
#show platform hardware capacity forwarding
                             2                0  65536         19          1%
                             3                0  98304         19          1%
                             6                0  65536         19          1%
                                                   512          1          1%
                 72 bits (IPv4, MPLS, EoM)     933888      771490         83%
                                 IPv4                      385761         41%
                                 MPLS                      385728         41%
                                 EoM                            1          1%
                                 IPv6                           1          1%
                                 IPv4 mcast                     4          1%
                                 IPv6 mcast                     3          1%
                                              1048576      385895         37%
When you upgrade your Ethernet module with either a DFC3BXL or DFC3CXL daughter card, you must also install a 1-GB memory upgrade (part number MEM-XCEF720-1GB) on the Ethernet module. This 1-GB memory upgrade is included with your DFC3BXL or DFC3CXL upgrade kit and installs on the Ethernet module in a small-outline dual-inline memory module (SODIMM) chip socket located underneath the DFC daughter card.
You must perform the memory upgrade procedure after you remove the CFC or the DFC daughter card from the Ethernet module and before you install either the DFC3BXL or DFC3CXL daughter card upgrade.
Написано, что память должна идти в комплекте к DFC. Забыли поставить?
А вы случаем не пытаетесь залить фул в VRF (естественно не default) ?
Вот это
как-то сильно много для fullview...
Ощущение что полученный фул попадает не только в default но и ещё в какой-то VRF.
Количество записей в TCAM длиной 72 бита сейчас примерно 385529 должно быть, а у
вас в 2 раза больше.
Вот это
из-за vrf-a (mpls) он каждый маршрут складывает в tcam 2 раза
  • 4 months later...
кому интересно решилось вводом команды (ну и конечно же установкой планки памяти 1Г на плату где стоит WS-F6K-PFC3BXL ):
mpls label mode all-vrfs protocol bgp-vpnv4 per-vrf
на ios-e:
s72033-adventerprisek9_wan-mz.122-33.SXI5
таким образом маршруты mpls все метятся 1 меткой
памяти сразу стало много свободной
Edited by dmitry_
