Схема сети:
NAS - машина на FreeBSD с mpd5 в качестве vpn сервера.
Конфиг mpd5:
startup:
set netflow peer 192.168.100.254 9996
default:
load pptp_server
pptp_server:
create bundle template B
set iface enable proxy-arp
set iface enable netflow-in
set iface enable netflow-out
set iface idle 1800
set iface enable tcpmssfix
set ipcp yes vjcomp
set ipcp ranges 192.168.100.231/32 10.10.0.0/16
set ipcp dns 192.168.1.1
set bundle enable compression
set ccp yes mppc
set mppc yes e40
set mppc yes e128
set mppc yes stateless
create link template L pptp
set link action bundle B
set link enable multilink
set link yes acfcomp protocomp
set link no pap chap
set link enable chap
load radius
set link keep-alive 10 60
set link mtu 1460
set pptp self 192.168.100.231
set pptp disable windowing
set pptp enable always-ack
set link enable incoming
radius:
set radius config /usr/local/etc/mpd5/radius.conf
set radius server 192.168.100.254 PASSWD 1812 1813
set radius retries 3
set radius timeout 3
#set radius me 192.168.100.231
set auth acct-update 300
set auth enable radius-auth
set auth enable radius-acct
set radius enable message-authentic
radius.conf:
auth 192.168.100.254 PASSWD
acct 192.168.100.254 PASSWD
Лог radius ideco:
Fri Sep 9 13:21:51 2011 : Info: rlm_eap_tls: Loading the certificate file as a chain
Fri Sep 9 13:21:51 2011 : Info: WARNING: rlm_eap_tls: Unable to set DH parameters. DH cipher suites may not work!
Fri Sep 9 13:21:51 2011 : Info: rlm_sql (sql): Driver rlm_sql_firebird (module rlm_sql_firebird) loaded and linked
Fri Sep 9 13:21:51 2011 : Info: rlm_sql (sql): Attempting to connect to KNL_USER@127.0.0.1://var/db/ics_main.gdb
Fri Sep 9 13:21:51 2011 : Info: Ready to process requests.
Эти записи в лог попадают при запуске сервера.
Результат tcpdump -nvi any udp port 1812 or udp port 1813 :
13:25:44.368435 192.168.100.231.18181 > 192.168.100.254.1812: rad-access-req 280 [id 15] Attr[ NAS_id{localhost.localdomain} NAS_ipaddr{192.168.100.231} [|radius] (ttl 64, id 9419, len 308)
13:25:47.369929 192.168.100.231.18181 > 192.168.100.254.1812: rad-access-req 280 [id 15] Attr[ NAS_id{localhost.localdomain} NAS_ipaddr{192.168.100.231} [|radius] (ttl 64, id 9421, len 308)
13:25:50.371423 192.168.100.231.18181 > 192.168.100.254.1812: rad-access-req 280 [id 15] Attr[ NAS_id{localhost.localdomain} NAS_ipaddr{192.168.100.231} [|radius] (ttl 64, id 9424, len 308)
13:25:53.372916 192.168.100.231.18181 > 192.168.100.254.1812: rad-access-req 280 [id 15] Attr[ NAS_id{localhost.localdomain} NAS_ipaddr{192.168.100.231} [|radius] (ttl 64, id 9426, len 308)
13:27:12.597463 192.168.100.231.37795 > 192.168.100.254.1812: rad-access-req 274 [id 21] Attr[ NAS_id{localhost.localdomain} [|radius] (ttl 64, id 9588, len 302)
13:27:15.598445 192.168.100.231.37795 > 192.168.100.254.1812: rad-access-req 274 [id 21] Attr[ NAS_id{localhost.localdomain} [|radius] (ttl 64, id 9592, len 302)
13:27:18.599937 192.168.100.231.37795 > 192.168.100.254.1812: rad-access-req 274 [id 21] Attr[ NAS_id{localhost.localdomain} [|radius] (ttl 64, id 9595, len 302)
13:27:21.601431 192.168.100.231.37795 > 192.168.100.254.1812: rad-access-req 274 [id 21] Attr[ NAS_id{localhost.localdomain} [|radius] (ttl 64, id 9597, len 302)
ip странные какие-то.
NAS добавлено в биллинг.
У пользователя стоит авторизация через RADIUS, нас так же указан.
При авторизации сообщение о том, что не найдена пара логин:пароль.
Авторизуюсь с машины на ОС Win 7 x64
freeRadius?
запустите с -XXX (в режиме отладки)
relam модуль включён?
withntdomainhack=1?
для DH надо файл сгенерить, как показан в /raddb/eap.conf
PS: А у Вас купленна Ideco-вская поддержка, а то тоже выбираю биллинговую систему (переползаю с FreeNIBS)? Задача не стандартная, а денег на норм. билинг как всегда нет....
Edited by NewUse
freeRadius?
withntdomainhack=1?
Поставил mikrotik и решаю задачу с помощью него. Проблема впринципе та же.
Да куплена лицензия.
У них так мутно написано о том, что 2 разные версии биллинга работают по разным схемам. Та что дешевле - без NAT. А при скачивании demo (она одна) ты даже и не подозреваешь что качаешь версию с NAT, та что дороже на 40к в моем случае. Так что при выборе будьте внимательнее. Не напоритесь как я.
