Всем привет.
Кто-нибудь использует X2-SFP+ переходник наговский с 4900M?
Если да, то можете показать логи sh int tenx/x cap? и др?
Всем привет.
наговские переходники проигрывают оригинальным по цене + завязка только с наговскими модулями + недоказанность стабилизции в них заложенной... чем они вас столь прельстили?
что понимается под оригинальными? партнамбер скажите, плз.
отвечаю на свой вопрос
Switch#sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 12:19 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x12C41C68
ROM: 12.2(44r)SG10
Sushi Revision 11, Tatooine Revision 141, Forerunner Revision 1.78
A0B-011-C uptime is 1 day, 9 hours, 47 minutes
System returned to ROM by power-on
System restarted at 05:58:44 UTC Thu Jul 14 2011
System image file is "bootflash:cat4500e-ipbasek9-mz.122-54.SG1.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C4900M (MPC8548) processor (revision 2) with 524288K bytes of memory.
Processor board ID JAE15170B56
MPC8548 CPU at 1.33GHz, Cisco Catalyst 4900M
Last reset from PowerUp
2 Virtual Ethernet interfaces
40 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Switch#
Switch#sh inventory
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4900M 3 slot switch "
PID: MIDPLANE          , VID:      , SN: JAE15170B56
NAME: "Linecard(slot 1)", DESCR: "4900M 10GE (X2) with 8 10GE X2 ports"
PID: WS-C4900M         , VID: V08  , SN: JAE1519058N
NAME: "TenGigabitEthernet1/1", DESCR: "10Gbase-LR"
PID: X2-10GB-LR        , VID: V03  , SN: XX96L011
NAME: "TenGigabitEthernet1/5", DESCR: "10Gbase-LR"
PID: X2-10GB-LR        , VID: V04  , SN: ECL122203UK
NAME: "TenGigabitEthernet1/8", DESCR: "10Gbase-LR"
PID: X2 to SFP+        , VID: V02  , SN: X2ABV530060
NAME: "Linecard(slot 2)", DESCR: "10/100/1000BaseT (RJ45) with 20 10/100/1000 baseT "
PID: WS-X4920-GB-RJ45  , VID: V03  , SN: JAE15140BIC
NAME: "Linecard(slot 3)", DESCR: "10/100/1000BaseT (RJ45) with 20 10/100/1000 baseT "
PID: WS-X4920-GB-RJ45  , VID: V03  , SN: JAE15140BN4
NAME: "Fan", DESCR: "FanTray"
PID: WS-X4992          , VID: V02  , SN: FOX1511G02W
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 960W )"
PID: PWR-C49M-1000AC   , VID: V01  , SN: SNI1507CA15
Switch#
Switch#sh int ten1/8 cap
  Model:                 WS-C4900M-X2
  Type:                  10GBase-LR
  Speed:                 10000
  Duplex:                full
  Auto-MDIX:             no
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100), hw
  Multicast suppression: percentage(0-100), hw
  Flowcontrol:           rx-(off,on),tx-(off,on)
  VLAN Membership:       static, dynamic
  Fast Start:            yes
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  SPAN:                  source/destination
  UDLD:                  yes
  Link Debounce:         yes
  Link Debounce Time:    yes
  Port Security:         yes
  Dot1x:                 yes
  Maximum MTU:           9198 bytes (Jumbo Frames)
  Multiple Media Types:  no
  Diagnostic Monitoring: yes
  Queuing:               rx-(N/A), tx-(1p7q1t)
Switch#
Switch#sh int ten1/8 transc
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                 Optical   Optical
           Temperature  Voltage  Tx Power  Rx Power
Port       (Celsius)    (Volts)  (dBm)     (dBm)
Te1/8        28.5       3.29       2.6      -7.6
Switch#
Switch#sh idprom interface ten1/8
X2 Serial EEPROM Contents:
Non-Volatile Register (NVR) Fields
 X2 Version                           :0x1E = MSA Version 0x1E
 NVR Size in bytes                    :0x100
 Number of bytes used                 :0x100
 Basic Field Address                  :0xB
 Customer Field Address               :0x77
 Vendor Field Address                 :0xA7
 Extended Vendor Field Address        :0x0
 Reserved                             :0x0
 Transceiver type                     :0x2 =X2
 Optical connector type               :0x1 =SC
 Bit encoding                         :0x1 =NRZ
 Normal BitRate in multiple of 1M b/s :0x2848
 Protocol Type                        :0x1 =10GbE
Standards Compliance Codes :
 10GbE Code Byte 0                    :0x2 =10GBASE-LR
 10GbE Code Byte 1                    :0x0
 SONET/SDH Code Byte 0                :0x0
 SONET/SDH Code Byte 1                :0x0
 SONET/SDH Code Byte 2                :0x0
 SONET/SDH Code Byte 3                :0x0
 10GFC Code Byte 0                    :0x0
 10GFC Code Byte 1                    :0x0
 10GFC Code Byte 2                    :0x0
 10GFC Code Byte 3                    :0x0
 Transmission range in 10m            :0x1E
Fibre Type :
 Fibre Type Byte 0                    :0x20 =SM, Generic
 Fibre Type Byte 1                    :0x0 =Unspecified
 Centre Optical Wavelength in 0.01nm steps - Channel 0 :0x1 0xFF 0xB8
 Centre Optical Wavelength in 0.01nm steps - Channel 1 :0x0 0x0 0x0
 Centre Optical Wavelength in 0.01nm steps - Channel 2 :0x0 0x0 0x0
 Centre Optical Wavelength in 0.01nm steps - Channel 3 :0x0 0x0 0x0
 Package Identifier OUI  :0xC09820
 Transceiver Vendor OUI  :0x269800
 Transceiver vendor name :OEM
 Part number provided by transceiver vendor       :X2-10GB-LR
 Revision level of part number provided by vendor :A
 Vendor serial number           :X2ABV530060
 Vendor manufacturing date code :2010072701
Current Reference :
 5V Stressed Environment Reference 100 percent=1A   :0x10
 3.3V Stressed Environment Reference 100 percent=2A :0x20
 APS Stressed Environment Reference 100 percent=2A  :0x4
 Normal APS Voltage :0x4
 Digital Optical Monitoring Capability Byte  :0xC1
 Digital Optical Monitoring                  :Implemented
 Low Power Start-up(LPS) Mode Capability Bit :0x0
 Reserved             :0x0
 Basic Field Checksum :0x18
 Customer Writable Area :
  0x00: 58 32 20 74 6F 20 53 46 50 2B 20 20 20 20 20 20
  0x10: 20 56 30 32 20 58 32 41 42 56 35 33 30 30 36 30
  0x20: 31 30 2D 32 32 30 35 2D 30 32 20 20 41 30 20 20
 Vendor Specific :
  0x00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x10: 00 00 00 00 00 00 00 00 00 99 11 2B C0 7E 21 13
  0x20: C3 17 30 15 18 20 3C 00 00 00 00 00 00 00 00 00
  0x30: 00 00 00 00 08 CD D8 06 7D 66 3C BE FB 83 E8 18
  0x40: E8 6B FE 0A DA 00 00 00 00 00 00 00 00 00 3D D9
  0x50: 9F 38 00 00 00 00 00 00 00
- вы пробовали заказывать у Cisco только переходник и получать цену 120$?
- завязки на наговские модули там нет, да и не проблема ставить туда наговские модули, благо ни разу не подводили.
- про стабилизацию не знаю, может проявляется на больших расстояниях, когда OSNR играет роль. скорее всего так.
- срок поставки на Cisco какой? даже переплатить 30$ и получить модули через пару дней для меня выгоднее, чем ждать Cisco не известно сколько. завтра у них на таможне новые правила или передел дистрибьютеров...
Edited by Lut
Мутная информация если честно, Павел вот тоже говорит что вендор-лока нет, а вот Александр (Песков) в телефонном разговоре убеждал в обратном, и божился что кроме наговских модулей ничего не заведется и что остались какие то проблемы с 4900, при этом опять же Павел говорит что в новой ревизии с 4900 проблем нет.
ноу проблем, док. поштучно конечно никто не отдаст, но уже пару запросто.
p.s. в принципе относительно скоро (как повезет с поставкой) затестирую snr-x2-sfp+ в 4900M совместно с sfp+ другого вендора.
магазин SNR почитал тему и подвинулся на 10 баксов )
По рознице SNR ни один провайдер не покупает. Как и сиску по ГПЛ. ;-)
Так что разница от Сиски 10-15 баксов.
Что говорят китайцы - на этом чипсете OSNR порог меньше с ним и eye-diagram лучше. Так или нет - проверить не могу.
Может быть еще малость сдвинутся в цене, даже скорее всего.
По совместимости... Точно не знаю, там фирмваре оперативно подпиливали под разные модели, в итоге, если правильно помню, непофикшеных багов нет.
