В недавнем времени произошло странное проишествие выключился и включился модуль 7600-ES20-2X10G.
Возможна ли аппаратная проблема?
Подобное происходит не в первый раз. так же выключался модуль в первом слоте.
Софт следующий.
c7600rsp72043_rp-ADVIPSERVICES-M), Version 12.2(33)SRC6
May 11 09:35:39.220 surgut: %OSPF-5-ADJCHG: Process 10, Nbr 10.19.6.1 on TenGigabitEthernet7/0/1 from FULL to DOWN, Neighbor Down: BFD node down
May 11 09:35:39.224 surgut: %OSPF-5-ADJCHG: Process 10, Nbr 10.40.6.10 on TenGigabitEthernet7/0/0 from FULL to DOWN, Neighbor Down: BFD node down
May 11 09:35:40.084 surgut: %LDP-5-NBRCHG: LDP Neighbor 10.19.6.1:0 (7) is DOWN (Interface not operational)
May 11 09:35:40.084 surgut: %SNMP-5-MODULETRAP: Module 7 [Down] Trap
May 11 09:35:40.088 surgut: %OIR-6-REMCARD: Card removed from slot 7, interfaces disabled
May 11 09:35:40.092 surgut: %SPA_OIR-6-OFFLINECARD: SPA (7600-ES20-2X10G) offline in subslot 7/0
May 11 09:35:40.112 surgut: %SPA_OIR-6-OFFLINECARD: SPA (7600-ES20-2X10G) offline in subslot 7/1
May 11 09:35:40.028 surgut: %OIR-SP-6-PWRFAILURE: Module 7 is being disabled due to power convertor failure 0x0
May 11 09:35:40.076 surgut: %C7600_PWR-SP-4-DISABLED: power to module in slot 7 set off (FRU-power failed)
May 11 09:37:03.326 surgut: %CWAN_RP-6-CARDRELOAD: Module reloaded on slot 7/0
May 11 09:37:03.326 surgut: %OIR-6-INSCARD: Card inserted in slot 7, interfaces administratively shut down
May 11 03:37:04.346: %FABRIC_INTF_ASIC-DFC7-5-FABRICSYNC_DONE: Fabric ASIC 0 Channel 1: Fabric sync done.
May 11 03:37:04.610: %FABRIC_INTF_ASIC-DFC7-5-FABRICSYNC_DONE: Fabric ASIC 1 Channel 1: Fabric sync done.
May 11 09:37:04.866 surgut: %OBFL_ERRMSG-DFC7-5-FILECREATEFAIL: OBFL Message App failed to open/create file disk0:errmsg_cont . Errno = 5
May 11 09:37:11.353 surgut: %DIAG-SP-6-RUN_MINIMUM: Module 7: Running Minimal Diagnostics...
May 11 09:37:11.973 surgut: %DIAG-SP-6-DIAG_OK: Module 7: Passed Online Diagnostics
May 11 09:37:12.401 surgut: %SNMP-5-MODULETRAP: Module 7 [up] Trap
May 11 09:37:12.374 surgut: %SCP-DFC7-5-ONLINE: Module online
May 11 09:37:12.402 surgut: %SPA_OIR-DFC7-6-INSCARD: Card inserted in Subslot 0
May 11 09:37:12.402 surgut: %SPA_OIR-DFC7-6-INSCARD: Card inserted in Subslot 1
May 11 09:37:13.914 surgut: %OIR-SP-6-INSCARD: Card inserted in slot 7, interfaces are now online
May 11 09:37:15.962 surgut: %DIAG-SP-6-RUN_MINIMUM: Module 7/0: Running Minimal Diagnostics...
May 11 09:37:25.461 surgut: %SPA_OIR-6-ONLINECARD: SPA (7600-ES20-2X10G) online in subslot 7/0
May 11 09:37:25.413 surgut: %DIAG-SP-6-DIAG_OK: Module 7/0: Passed Online Diagnostics
May 11 09:37:25.461 surgut: %DIAG-SP-6-RUN_MINIMUM: Module 7/1: Running Minimal Diagnostics...
May 11 09:37:25.473 surgut: %DIAG-SP-6-DIAG_OK: Module 7/1: Passed Online Diagnostics
May 11 09:37:27.304 surgut: %SPA_OIR-6-ONLINECARD: SPA (7600-ES20-2X10G) online in subslot 7/1
May 11 09:37:28.034 surgut: %LINK-DFC7-3-UPDOWN: Interface TenGigabitEthernet7/0/0, changed state to up
May 11 09:37:28.534 surgut: %LINK-DFC7-3-UPDOWN: Interface TenGigabitEthernet7/0/1, changed state to up
May 11 09:37:29.034 surgut: %LINEPROTO-DFC7-5-UPDOWN: Line protocol on Interface TenGigabitEthernet7/0/0, changed state to up
May 11 09:37:29.534 surgut: %LINEPROTO-DFC7-5-UPDOWN: Line protocol on Interface TenGigabitEthernet7/0/1, changed state to up
May 11 09:37:31.312 surgut: %LDP-5-NBRCHG: LDP Neighbor 10.19.6.1:0 (7) is UP
May 11 09:38:10.374 surgut: %OSPF-5-ADJCHG: Process 10, Nbr 10.40.6.10 on TenGigabitEthernet7/0/0 from LOADING to FULL, Loading Done
May 11 09:38:11.270 surgut: %OSPF-5-ADJCHG: Process 10, Nbr 10.19.6.1 on TenGigabitEthernet7/0/1 from LOADING to FULL, Loading Done
41 градус, как то подозрительно... можно рассматривать как проблему???
module 7:
module 7 power-output-fail: OK
module 7 outlet temperature: 28C
module 7 inlet temperature: 28C
module 7 device-1 temperature: 41C
module 7 device-2 temperature: 35C
module 7 EARL outlet temperature: 22C
module 7 EARL inlet temperature: 31C
А вот первый модуль вообще 53 показывает.
module 1:
module 1 power-output-fail: OK
module 1 outlet temperature: 53C
module 1 inlet temperature: 28C
В помещении 50 градусов - полёт нормальный.
Карточки рассыпались после 80С на железе, в помещении в это время нельзя было находиться... гул вентиляторов разбудил целый квартал.
Аппаратная проблема возможна --
что-то со питанием на плате
