привет.собственно досттался комутатор по халявной цене и решили его заюзать чисто под BGP дефольт+украина, так вот: когда начал настраивать то оказалось что номер АС у нас на 6 цифр, а в комутаторе поддержка до 5 цифр, знаю что на вишестоящем провайдере на 3750 такая проблема устранялась установкой IOS толи новее, толи как то тюнингованного...как можно запустить BGP на моей циске с 6 цифрами?
вот что показивает команда show version
sh version
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(52)SE, R ELEASE SOFTWARE (fc3)
Copyright © 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 09:05 by sasyamal
Image text-base: 0x00003000, data-base: 0x015DB684
ROM: Bootstrap program is C3550 boot loader
LANPRO_BGP_router uptime is 25 minutes
System returned to ROM by power-on
System image file is "flash:/c3550-ipservicesk9-mz.122-52.SE.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco WS-C3550-48 (PowerPC) processor (revision P0) with 65526K/8192K bytes of memory.
Processor board ID CAT0829N4KC
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 4 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:11:93:9D:5A:00
Motherboard assembly number: 73-5701-09
Power supply part number: 34-0967-02
Motherboard serial number: CAT08290TVL
Power supply serial number: DTH08275SPH
Model revision number: P0
Motherboard revision number: A0
Model number: WS-C3550-48-SMI
System serial number: CAT0829N4KC
Configuration register is 0x10F
Edited by fastvd
Это называется ASN32 capability. В 3550 его нет и не будет.
хм, интересно, и какой выход тогда? неужели циско взяли себе и забили на поддержку на старых платформах...может как-то обойти можно?
Вас не смущает что для 3550 EoS/EoL объявили еще в 2005м? 2 февраля 2011 закрыли все сервис-контракты по 3550, а 2 мая 2011 заканчивается любая поддержка по данному оборудованию.
Понимаю что 3550 бронебойные и очень живучие - у самих несколько таких годами без нареканий на полной нагрузке живут, но требовать от них сверхъестественного - не правильно.
для 3560/3750 поддержка ASN32 анонсирована только в X линейке, и только в новых IOS. Реализовали уже или нет - не знаю, анонс в том году на глаза попадался.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6554/ps6599/data_sheet_C78-521821.html
http://www.gossamer-threads.com/lists/cisco/nsp/140495
