Подскажите почему переполняются очереди и дропаются пакеты?
с одной стороны 3750E(по счетчикам дропов нет) - с другой 7606 (см ниже)
TenGigabitEthernet1/1 is up, line protocol is up (connected)
Hardware is C6k 10000Mb 802.3, address is 0018.7383.57b0 (bia 0018.7383.57b0)
Description: Link-10G
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
reliability 255/255, txload 71/255, rxload 80/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 10Gb/s
input flow-control is off, output flow-control is off
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:30, output 00:00:11, output hang never
Last clearing of "show interface" counters 00:31:21
Input queue: 0/2000/34692376/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3168815000 bits/sec, 685151 packets/sec
5 minute output rate 2809675000 bits/sec, 509848 packets/sec
1290488983 packets input, 750730664300 bytes, 0 no buffer
Received 6288878 broadcasts (4631800 multicasts)
7606#sh int summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* TenGigabitEthernet1/1 0 35075363 0 0 3168346000 685623 2808938000 509391 0
* TenGigabitEthernet1/2 0 0 0 0 162663000 40477 457168000 80242 0
* TenGigabitEthernet1/3 0 0 0 0 374956000 126190 978998000 15463
7606# sh processes cpu sorted | ex 0.00
CPU utilization for five seconds: 3%/0%; one minute: 3%; five minutes: 3%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
10 18282132 232233547 78 1.11% 0.87% 0.89% 0 ARP Input
188 31714340 508301128 62 0.95% 0.82% 0.90% 0 IP Input
241 625164 2857125 218 0.07% 0.03% 0.02% 0 IPC LC Message H
63 996 19053 52 0.07% 0.29% 0.08% 2 Virtual Exec
7606#sh int te1/1 switching
TenGigabitEthernet1/1 Link-10G
Throttle count 0
Drops RP 37161885 SP 0
SPD Flushes Fast 0 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 0 Drops 0
Protocol Path Pkts In Chars In Pkts Out Chars Out
CDP Process 62557 26023712 62590 29292120
Cache misses 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
странно, но похоже счетчики в sh int te1/1 switching не обновляются
Full-duplex, 10Gb/s
7606#sh int summary
*: interface is up
Throttle count 0
SPD Aggress Fast 0
Cache misses 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
sh ip int TenGigabitEthernet1/1 ?
Cisco IOS Interface and Hardware Component Command Reference
Entering the default fabric buffer-reserve queue command is the same as entering the fabric buffer-reserve queue command.
You can enter the fabric buffer-reserve command to improve the system throughput by reserving ASIC buffers.
This command is supported on the following modules:
•WS-X6704-10GE
•WS-X6748-SFP
•WS-X6748-GE-TX
•WS-X6724-SFP
Examples
This example shows how to reserve the high (0x5050) ASIC buffer spaces:
Router(config)# fabric buffer-reserve high
Router(config)#
This example shows how to reserve the low (0x3030) ASIC buffer spaces:
Router(config)# fabric buffer-reserve low
Router(config)#
http://www.cisco.com/en/US/products/hw/rou...0800a7b80.shtml
caution Caution: Use this command only under the direction of Cisco TAC.
These are common circumstances where this command is useful:
* Line protocol goes down for multiple interfaces
* Overruns are seen on multiple interfaces
* Ports frequently leave and join EtherChannel
* TestMacNotification test repeatedly fails for line cards with DFC
Buffer Leaks
Below is an example of the output of the show buffers command:
Big buffers, 1524 bytes (total 1556, permanent 50):
52 in free list (5 min, 150 max allowed)
43670437 hits, 5134 misses, 0 trims, 1506 created
756 failures (0 no memory)
This output indicates a buffer leak in the big buffers pool. There is a total of 1556 big buffers in the router and only 52 are in the free list. Something is using all the buffers, and not freeing them. For more information on buffer leaks, see Troubleshooting Buffer Leaks.
вам наверно нужно посмотреть show buffers
что там пишет в Big buffers
по идее у вас in free list должден быть равен 0 или 64
и дропы должны быть
Edited by alks
7600#sh fabric utilization
slot channel speed Ingress % Egress %
1 0 20G 1 5
1 1 20G 19 13
3 0 20G 7 8
4 0 20G 0 20
4 1 20G 14 8
5 0 20G 22 29
6 0 8G 7 0
7600#show buffers | in fail
0 failures (0 no memory)
7600#show buffers
Buffer elements:
1060 in free list (500 max allowed)
247412142 hits, 0 misses, 1119 created
Public buffer pools:
Small buffers, 104 bytes (total 1024, permanent 1024):
1013 in free list (128 min, 2048 max allowed)
173898231 hits, 0 misses, 0 trims, 0 created
Medium buffers, 256 bytes (total 3000, permanent 3000):
3000 in free list (64 min, 3000 max allowed)
7848641 hits, 0 misses, 0 trims, 0 created
Middle buffers, 600 bytes (total 512, permanent 512):
510 in free list (64 min, 1024 max allowed)
9107110 hits, 0 misses, 0 trims, 0 created
Big buffers, 1536 bytes (total 1000, permanent 1000):
998 in free list (64 min, 1000 max allowed)
7214593 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 10, permanent 10):
10 in free list (0 min, 300 max allowed)
491 hits, 0 misses, 0 trims, 0 created
Large buffers, 9240 bytes (total 8, permanent 8):
8 in free list (0 min, 10 max allowed)
261 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 2, permanent 2, peak 4 @ 5d02h):
1 in free list (0 min, 4 max allowed)
29159 hits, 15 misses, 30 trims, 30 created
Interface buffer pools:
Syslog ED Pool buffers, 600 bytes (total 150, permanent 150):
118 in free list (150 min, 150 max allowed)
2305 hits, 0 misses
LI Middle buffers, 600 bytes (total 512, permanent 256, peak 512 @ 5d02h
256 in free list (256 min, 768 max allowed)
171 hits, 85 fallbacks, 0 trims, 256 created
256 max cache size, 256 in cache
0 hits in cache, 0 misses in cache
DMA-2 buffers, 1536 bytes (total 512, permanent 512):
256 in free list (0 min, 512 max allowed)
256 hits, 0 misses
BFD Private Pool buffers, 1536 bytes (total 2400, permanent 2400):
2400 in free list (100 min, 3000 max allowed)
0 hits, 0 fallbacks, 0 trims, 0 created
LI Big buffers, 1536 bytes (total 512, permanent 256, peak 512 @ 5d02h):
EOBC0/0 buffers, 1686 bytes (total 1536, permanent 1536):
654 in free list (0 min, 3072 max allowed)
882 hits, 0 fallbacks
768 max cache size, 364 in cache
28602163 hits in cache, 114 misses in cache
FIFO0/2 buffers, 1686 bytes (total 1536, permanent 1536):
258 in free list (0 min, 3072 max allowed)
1278 hits, 0 fallbacks
768 max cache size, 753 in cache
14359994 hits in cache, 510 misses in cache
IPC buffers, 4096 bytes (total 672, permanent 672):
590 in free list (224 min, 2240 max allowed)
856603 hits, 0 fallbacks, 0 trims, 0 created
LI Very Big buffers, 4520 bytes (total 257, permanent 128, peak 257 @ 5d
129 in free list (128 min, 384 max allowed)
85 hits, 43 fallbacks, 91 trims, 220 created
128 max cache size, 128 in cache
Private Huge IPC buffers, 18024 bytes (total 2, permanent 2):
2 in free list (1 min, 4 max allowed)
Private Huge buffers, 65280 bytes (total 2, permanent 2, peak 3 @ 1d03h)
44388 hits, 0 misses, 1 trims, 1 created
Header pools:
Particle Clones:
1024 clones, 0 hits, 0 misses
Public particle pools:
Normal buffers, 1532 bytes (total 1024, permanent 1024):
1024 in free list (512 min, 2048 max allowed)
F/S buffers, 1590 bytes (total 512, permanent 512):
0 in free list (0 min, 512 max allowed)
512 hits, 0 misses
512 max cache size, 512 in cache
Private particle pools:
IBC0/0 buffers, 640 bytes (total 512, permanent 512):
512 hits, 0 fallbacks
512 max cache size, 256 in cache
220490525 hits in cache, 0 misses in cache
похоже дело в rspan часть трафика который терминируется на SVI откидывался в RSPAN . Снял мониторинг - дропов в очереди нет.
а по поводу fabric buffer-reserve high что-то много предупреждений от TAC
