blackjack Posted November 2, 2010 Posted November 2, 2010 Всем привет. Есть 6509, сейчас там работает иос 12,1, но нам нужен IP UNNUMBERED который есть в 12.2. Попробовал два иоса которые по фиченавигатору имеют указаный функционал , все завершается System software crash Вот они s222-adventerprisek9_wan-mz.122-18.SXF15.bin s222-ipservices_wan-mz.122-18.SXF8.bin Вот данные киски cisco6509#sh ver Cisco Internetwork Operating System Software IOS (tm) c6sup2_rp Software (c6sup2_rp-JK2O3SV-M), Version 12.1(26)E9, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2007 by cisco Systems, Inc. Compiled Fri 10-Aug-07 16:36 by hqluong Image text-base: 0x40008F90, data-base: 0x41D78000 ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1) BOOTLDR: c6sup2_rp Software (c6sup2_rp-JK2O3SV-M), Version 12.1(26)E9, RELEASE SOFTWARE (fc1) cisco6509 uptime is 55 minutes Time since cisco6509 switched to active is 54 minutes System returned to ROM by power-on (SP by error - a Software forced crash, PC 0x402DCC3C) System image file is "sup-bootflash:c6sup22-jk2o3sv-mz.121-26.E9.bin" This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco WS-C6509 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory. Processor board ID SCA0333009W R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache Last reset from power-on Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp). TN3270 Emulation software. 178 Virtual Ethernet/IEEE 802.3 interface(s) 48 FastEthernet/IEEE 802.3 interface(s) 18 Gigabit Ethernet/IEEE 802.3 interface(s) 381K bytes of non-volatile configuration memory. 32768K bytes of Flash internal SIMM (Sector size 512K). Configuration register is 0x2102 cisco6509#sh mod Mod Ports Card Type Model Serial No. --- ----- -------------------------------------- ------------------ ----------- 1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE SAL0732J21M 2 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL0605HBEM 3 16 16 port 1000mb GBIC ethernet WS-X6416-GBIC SAD05060THH Mod MAC addresses Hw Fw Sw Status --- ---------------------------------- ------ ------------ ------------ ------- 1 0008.7dc9.dc2c to 0008.7dc9.dc2d 4.3 7.1(1) 12.1(26)E9 Ok 2 0008.207c.671c to 0008.207c.674b 6.0 5.4(2) 8.5(0.9)TFW3 Ok 3 0002.fc44.c010 to 0002.fc44.c01f 1.2 5.4(2) 8.5(0.9)TFW3 Ok Mod Sub-Module Model Serial Hw Status --- --------------------------- --------------- --------------- ------- ------- 1 Policy Feature Card 2 WS-F6K-PFC2 SAL0731J12Q 3.4 Ok 1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAL0731J0PD 2.5 Ok 2 Inline Power Module WS-F6K-PWR 1.0 Ok Mod Online Diag Status --- ------------------- 1 Pass 2 Pass 3 Pass ..... boot system flash bootflash:c6sup22-jk2o3sv-mz.121-26.E9.bin boot bootldr bootflash:c6sup22-jk2o3sv-mz.121-26.E9.bin ..... помогите подобрать нормальный иос. Вставить ник Quote
Ivan Rostovikov Posted November 3, 2010 Posted November 3, 2010 У меня такой : s72033-adventerprisek9_wan-mz.122-33.SXI3.bin IP UNNUMBERED использую. Вставить ник Quote
blackjack Posted November 3, 2010 Author Posted November 3, 2010 поделитесь, vvb@pois.com.ua Вставить ник Quote
Ivan Rostovikov Posted November 4, 2010 Posted November 4, 2010 http://rutracker.org/forum/viewtopic.php?t=2141399 так проще. Вставить ник Quote
Дегтярев Илья Posted November 4, 2010 Posted November 4, 2010 Зачем предлагать человеку прошивку для SUP720 если у него SUP2? Они не совместимы. Вставить ник Quote
blackjack Posted November 5, 2010 Author Posted November 5, 2010 та да, у меня суп2 а не 720. Вообщето разобрался. Дело не в иосе, а в нехватке памяти. Теперь попрошу объяснить где какая память. cisco6509#rem com sw sh ver | inc bytes of memory cisco WS-C6509 (R7000) processor (revision 2.0) with 112640K/18432K bytes of memory. cisco6509#sh ver | inc bytes of memory cisco WS-C6509 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory. Вставить ник Quote
C@T Posted November 8, 2010 Posted November 8, 2010 Теперь попрошу объяснить где какая память. cisco6509#rem com sw sh ver | inc bytes of memory cisco WS-C6509 (R7000) processor (revision 2.0) with 112640K/18432K bytes of memory. память на switch processor'e (SP) cisco6509#sh ver | inc bytes of memory cisco WS-C6509 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory. память на RP (route processor), в вашем случае MSFC Вставить ник Quote
blackjack Posted November 10, 2010 Author Posted November 10, 2010 вчем спасибо, добавил вчера памяти на SP и иос загрузился. Вставить ник Quote
