Wyclef Posted September 1, 2010 Posted September 1, 2010 Есть сервер FreeBSD 8.0-RELEASE-p3 (шлюз) - две сетевые карты, внешний ip - "белый", внутренний - из 10.0.0.0/24 - локалка 10.0.0.0/8 установлен mpd5 из портов, работает, используется для выдачи "белых" ip-адресов клиентам конфигурация: mpd.conf startup: set user admin xxxxxx set console self 127.0.0.1 5005 set console open set web self 10.0.0.10 5006 set web open default: load pptp0 pptp0: set ippool add poolstat 95.xxx.xxx.xxx 95.xxx.xxx.xxx create bundle template B set iface disable proxy-arp set iface idle 0 set iface enable tcpmssfix set ipcp yes vjcomp set ipcp ranges 10.0.0.10/32 ippool poolstat set ipcp dns 10.0.0.10 set bundle enable compression set ccp yes mppc set mppc yes compress e40 e56 e128 stateless create link template L pptp set link disable multilink set link yes acfcomp protocomp set link action bundle B set link no pap chap set link enable chap set link enable chap-msv1 set link enable chap-msv2 set link keep-alive 10 75 set link mtu 1460 set pptp self 10.0.0.10 load radius set link enable incoming radius: set radius server localhost xxxxxx 1812 1813 set radius retries 3 set radius timeout 3 set radius me 10.0.0.10 set auth acct-update 300 set auth enable radius-auth set auth enable radius-acct set radius enable message-authentic log mpd при первом подключении клиента Sep 1 10:43:51 srv1 mpd: [L-1] Accepting PPTP connection Sep 1 10:43:51 srv1 mpd: [L-1] Link: OPEN event Sep 1 10:43:51 srv1 mpd: [L-1] LCP: Open event Sep 1 10:43:51 srv1 mpd: [L-1] LCP: state change Initial --> Starting Sep 1 10:43:51 srv1 mpd: [L-1] LCP: LayerStart Sep 1 10:43:51 srv1 mpd: [L-1] PPTP: attaching to peer's outgoing call Sep 1 10:43:51 srv1 mpd: [L-1] Link: UP event Sep 1 10:43:51 srv1 mpd: [L-1] LCP: Up event Sep 1 10:43:51 srv1 mpd: [L-1] LCP: state change Starting --> Req-Sent Sep 1 10:43:51 srv1 mpd: [L-1] LCP: SendConfigReq #1 Sep 1 10:43:51 srv1 mpd: [L-1] ACFCOMP Sep 1 10:43:51 srv1 mpd: [L-1] PROTOCOMP Sep 1 10:43:51 srv1 mpd: [L-1] MRU 1500 Sep 1 10:43:51 srv1 mpd: [L-1] MAGICNUM 3f383f58 Sep 1 10:43:51 srv1 mpd: [L-1] AUTHPROTO CHAP MSOFTv2 Sep 1 10:43:51 srv1 mpd: [L-1] MP MRRU 2048 Sep 1 10:43:51 srv1 mpd: [L-1] MP SHORTSEQ Sep 1 10:43:51 srv1 mpd: [L-1] ENDPOINTDISC [802.1] 00 15 17 de 59 f8 Sep 1 10:43:51 srv1 mpd: [L-1] LCP: rec'd Configure Request #0 (Req-Sent) Sep 1 10:43:51 srv1 mpd: [L-1] MRU 1400 Sep 1 10:43:51 srv1 mpd: [L-1] MAGICNUM 4ff910ae Sep 1 10:43:51 srv1 mpd: [L-1] PROTOCOMP Sep 1 10:43:51 srv1 mpd: [L-1] ACFCOMP Sep 1 10:43:51 srv1 mpd: [L-1] CALLBACK 6 Sep 1 10:43:51 srv1 mpd: [L-1] LCP: SendConfigRej #0 Sep 1 10:43:51 srv1 mpd: [L-1] CALLBACK 6 Sep 1 10:43:51 srv1 mpd: [L-1] LCP: rec'd Configure Request #1 (Req-Sent) Sep 1 10:43:51 srv1 mpd: [L-1] MRU 1400 Sep 1 10:43:51 srv1 mpd: [L-1] MAGICNUM 4ff910ae Sep 1 10:43:51 srv1 mpd: [L-1] PROTOCOMP Sep 1 10:43:51 srv1 mpd: [L-1] ACFCOMP Sep 1 10:43:51 srv1 mpd: [L-1] LCP: SendConfigAck #1 Sep 1 10:43:51 srv1 mpd: [L-1] MRU 1400 Sep 1 10:43:51 srv1 mpd: [L-1] MAGICNUM 4ff910ae Sep 1 10:43:51 srv1 mpd: [L-1] PROTOCOMP Sep 1 10:43:51 srv1 mpd: [L-1] ACFCOMP Sep 1 10:43:51 srv1 mpd: [L-1] LCP: state change Req-Sent --> Ack-Sent Sep 1 10:43:53 srv1 mpd: [L-1] LCP: SendConfigReq #2 Sep 1 10:43:53 srv1 mpd: [L-1] ACFCOMP Sep 1 10:43:53 srv1 mpd: [L-1] PROTOCOMP Sep 1 10:43:53 srv1 mpd: [L-1] MRU 1500 Sep 1 10:43:53 srv1 mpd: [L-1] MAGICNUM 3f383f58 Sep 1 10:43:53 srv1 mpd: [L-1] AUTHPROTO CHAP MSOFTv2 Sep 1 10:43:53 srv1 mpd: [L-1] MP MRRU 2048 Sep 1 10:43:53 srv1 mpd: [L-1] MP SHORTSEQ Sep 1 10:43:53 srv1 mpd: [L-1] ENDPOINTDISC [802.1] 00 15 17 de 59 f8 Sep 1 10:43:53 srv1 mpd: [L-1] LCP: rec'd Configure Reject #2 (Ack-Sent) Sep 1 10:43:53 srv1 mpd: [L-1] MP MRRU 2048 Sep 1 10:43:53 srv1 mpd: [L-1] MP SHORTSEQ Sep 1 10:43:53 srv1 mpd: [L-1] ENDPOINTDISC [802.1] 00 15 17 de 59 f8 Sep 1 10:43:53 srv1 mpd: [L-1] LCP: SendConfigReq #3 Sep 1 10:43:53 srv1 mpd: [L-1] ACFCOMP Sep 1 10:43:53 srv1 mpd: [L-1] PROTOCOMP Sep 1 10:43:53 srv1 mpd: [L-1] MRU 1500 Sep 1 10:43:53 srv1 mpd: [L-1] MAGICNUM 3f383f58 Sep 1 10:43:53 srv1 mpd: [L-1] AUTHPROTO CHAP MSOFTv2 Sep 1 10:43:53 srv1 mpd: [L-1] LCP: rec'd Configure Ack #3 (Ack-Sent) Sep 1 10:43:53 srv1 mpd: [L-1] ACFCOMP Sep 1 10:43:53 srv1 mpd: [L-1] PROTOCOMP Sep 1 10:43:53 srv1 mpd: [L-1] MRU 1500 Sep 1 10:43:53 srv1 mpd: [L-1] MAGICNUM 3f383f58 Sep 1 10:43:53 srv1 mpd: [L-1] AUTHPROTO CHAP MSOFTv2 Sep 1 10:43:53 srv1 mpd: [L-1] LCP: state change Ack-Sent --> Opened Sep 1 10:43:53 srv1 mpd: [L-1] LCP: auth: peer wants nothing, I want CHAP Sep 1 10:43:53 srv1 mpd: [L-1] CHAP: sending CHALLENGE #1 len: 21 Sep 1 10:43:53 srv1 mpd: [L-1] LCP: LayerUp Sep 1 10:43:53 srv1 mpd: [L-1] LCP: rec'd Ident #2 (Opened) Sep 1 10:43:53 srv1 mpd: [L-1] MESG: MSRASV5.10 Sep 1 10:43:53 srv1 mpd: [L-1] LCP: rec'd Ident #3 (Opened) Sep 1 10:43:53 srv1 mpd: [L-1] MESG: MSRAS-0-LAPTOP Sep 1 10:43:53 srv1 mpd: [L-1] CHAP: rec'd RESPONSE #1 len: 58 Sep 1 10:43:53 srv1 mpd: [L-1] Name: "test" Sep 1 10:43:53 srv1 mpd: [L-1] AUTH: Trying RADIUS Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Authenticating user 'test' Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Rec'd RAD_ACCESS_ACCEPT for user 'test' Sep 1 10:43:53 srv1 mpd: [L-1] AUTH: RADIUS returned: authenticated Sep 1 10:43:53 srv1 mpd: [L-1] CHAP: Auth return status: authenticated Sep 1 10:43:53 srv1 mpd: [L-1] CHAP: Reply message: S=935A56F6DAB2802AD6675D979DB3067113EB0121 Sep 1 10:43:53 srv1 mpd: [L-1] CHAP: sending SUCCESS #1 len: 46 Sep 1 10:43:53 srv1 mpd: [L-1] LCP: authorization successful Sep 1 10:43:53 srv1 mpd: [L-1] Link: Matched action 'bundle "B" ""' Sep 1 10:43:53 srv1 mpd: [L-1] Creating new bundle using template "B". Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: Interface ng0 created Sep 1 10:43:53 srv1 mpd: [L-1] Link: Join bundle "B-1" Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: Status update: up 1 link, total bandwidth 64000 bps Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: Open event Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Initial --> Starting Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: LayerStart Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Open event Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Initial --> Starting Sep 1 10:43:53 srv1 mpd: [B-1] CCP: LayerStart Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: Up event Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Starting --> Req-Sent Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendConfigReq #1 Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 10.0.0.10 Sep 1 10:43:53 srv1 mpd: [B-1] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Up event Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Starting --> Req-Sent Sep 1 10:43:53 srv1 mpd: [B-1] CCP: SendConfigReq #1 Sep 1 10:43:53 srv1 mpd: [B-1] MPPC Sep 1 10:43:53 srv1 mpd: [B-1] 0x010000e0:MPPE(40, 56, 128 bits), stateless Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Accounting user 'test' (Type: 1) Sep 1 10:43:53 srv1 mpd: [B-1] CCP: rec'd Configure Request #4 (Req-Sent) Sep 1 10:43:53 srv1 mpd: [B-1] MPPC Sep 1 10:43:53 srv1 mpd: [B-1] 0x010000e1:MPPC, MPPE(40, 56, 128 bits), stateless Sep 1 10:43:53 srv1 mpd: [B-1] CCP: SendConfigNak #4 Sep 1 10:43:53 srv1 mpd: [B-1] MPPC Sep 1 10:43:53 srv1 mpd: [B-1] 0x01000040:MPPE(128 bits), stateless Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Rec'd RAD_ACCOUNTING_RESPONSE for user 'test' Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Configure Request #5 (Req-Sent) Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 0.0.0.0 Sep 1 10:43:53 srv1 mpd: [B-1] NAKing with 95.xxx.xxx.xxx Sep 1 10:43:53 srv1 mpd: [B-1] PRIDNS 0.0.0.0 Sep 1 10:43:53 srv1 mpd: [B-1] NAKing with 10.0.0.10 Sep 1 10:43:53 srv1 mpd: [B-1] PRINBNS 0.0.0.0 Sep 1 10:43:53 srv1 mpd: [B-1] SECDNS 0.0.0.0 Sep 1 10:43:53 srv1 mpd: [B-1] SECNBNS 0.0.0.0 Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendConfigRej #5 Sep 1 10:43:53 srv1 mpd: [B-1] PRINBNS 0.0.0.0 Sep 1 10:43:53 srv1 mpd: [B-1] SECDNS 0.0.0.0 Sep 1 10:43:53 srv1 mpd: [B-1] SECNBNS 0.0.0.0 Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Configure Reject #1 (Req-Sent) Sep 1 10:43:53 srv1 mpd: [B-1] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendConfigReq #2 Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 10.0.0.10 Sep 1 10:43:53 srv1 mpd: [B-1] CCP: rec'd Configure Nak #1 (Req-Sent) Sep 1 10:43:53 srv1 mpd: [B-1] MPPC Sep 1 10:43:53 srv1 mpd: [B-1] 0x01000040:MPPE(128 bits), stateless Sep 1 10:43:53 srv1 mpd: [B-1] CCP: SendConfigReq #2 Sep 1 10:43:53 srv1 mpd: [B-1] MPPC Sep 1 10:43:53 srv1 mpd: [B-1] 0x01000040:MPPE(128 bits), stateless Sep 1 10:43:53 srv1 mpd: [B-1] CCP: rec'd Configure Request #6 (Req-Sent) Sep 1 10:43:53 srv1 mpd: [B-1] MPPC Sep 1 10:43:53 srv1 mpd: [B-1] 0x01000040:MPPE(128 bits), stateless Sep 1 10:43:53 srv1 mpd: [B-1] CCP: SendConfigAck #6 Sep 1 10:43:53 srv1 mpd: [B-1] MPPC Sep 1 10:43:53 srv1 mpd: [B-1] 0x01000040:MPPE(128 bits), stateless Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Req-Sent --> Ack-Sent Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Configure Request #7 (Req-Sent) Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 0.0.0.0 Sep 1 10:43:53 srv1 mpd: [B-1] NAKing with 95.xxx.xxx.xxx Sep 1 10:43:53 srv1 mpd: [B-1] PRIDNS 0.0.0.0 Sep 1 10:43:53 srv1 mpd: [B-1] NAKing with 10.0.0.10 Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendConfigNak #7 Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 95.xxx.xxx.xxx Sep 1 10:43:53 srv1 mpd: [B-1] PRIDNS 10.0.0.10 Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Configure Ack #2 (Req-Sent) Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 10.0.0.10 Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Req-Sent --> Ack-Rcvd Sep 1 10:43:53 srv1 mpd: [B-1] CCP: rec'd Configure Ack #2 (Ack-Sent) Sep 1 10:43:53 srv1 mpd: [B-1] MPPC Sep 1 10:43:53 srv1 mpd: [B-1] 0x01000040:MPPE(128 bits), stateless Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Ack-Sent --> Opened Sep 1 10:43:53 srv1 mpd: [B-1] CCP: LayerUp Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Compress using: mppc (MPPE(128 bits), stateless) Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Decompress using: mppc (MPPE(128 bits), stateless) Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Configure Request #8 (Ack-Rcvd) Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 95.xxx.xxx.xxx Sep 1 10:43:53 srv1 mpd: [B-1] 95.xxx.xxx.xxx is OK Sep 1 10:43:53 srv1 mpd: [B-1] PRIDNS 10.0.0.10 Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendConfigAck #8 Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 95.xxx.xxx.xxx Sep 1 10:43:53 srv1 mpd: [B-1] PRIDNS 10.0.0.10 Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Ack-Rcvd --> Opened Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: LayerUp Sep 1 10:43:53 srv1 mpd: [B-1] 10.0.0.10 -> 95.xxx.xxx.xxx Sep 1 10:43:53 srv1 mpd: [B-1] IFACE: Adding IPv4 address to ng0 failed: File exists Sep 1 10:43:53 srv1 mpd: [B-1] IFACE: IfaceChangeAddr() error, closing IPCP Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: parameter negotiation failed Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Opened --> Stopping Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendTerminateReq #3 Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: LayerDown Sep 1 10:43:53 srv1 mpd: [B-1] rec'd unexpected protocol IP Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Terminate Ack #3 (Stopping) Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Stopping --> Stopped Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: LayerFinish Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: No NCPs left. Closing links... Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: closing link "L-1"... Sep 1 10:43:53 srv1 mpd: [L-1] Link: CLOSE event Sep 1 10:43:53 srv1 mpd: [L-1] LCP: Close event Sep 1 10:43:53 srv1 mpd: [L-1] LCP: state change Opened --> Closing Sep 1 10:43:53 srv1 mpd: [L-1] Link: Leave bundle "B-1" Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Accounting user 'test' (Type: 2) Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: Status update: up 0 links, total bandwidth 9600 bps Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: Close event Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Stopped --> Closed Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Close event Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Opened --> Closing Sep 1 10:43:53 srv1 mpd: [B-1] CCP: SendTerminateReq #3 Sep 1 10:43:53 srv1 mpd: [B-1] CCP: LayerDown Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: Down event Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Closed --> Initial Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Down event Sep 1 10:43:53 srv1 mpd: [B-1] CCP: LayerFinish Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Closing --> Initial Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: Shutdown Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Rec'd RAD_ACCOUNTING_RESPONSE for user 'test' Sep 1 10:43:53 srv1 mpd: [L-1] LCP: SendTerminateReq #4 Sep 1 10:43:53 srv1 mpd: [L-1] LCP: LayerDown Sep 1 10:43:54 srv1 mpd: [L-1] PPTP call terminated Sep 1 10:43:54 srv1 mpd: [L-1] Link: DOWN event Sep 1 10:43:54 srv1 mpd: [L-1] LCP: Down event Sep 1 10:43:54 srv1 mpd: [L-1] LCP: LayerFinish Sep 1 10:43:54 srv1 mpd: [L-1] LCP: state change Closing --> Initial Sep 1 10:43:54 srv1 mpd: [L-1] Link: SHUTDOWN event Sep 1 10:43:54 srv1 mpd: [L-1] Link: Shutdown Вопросы: 1. При первом подключении пользователю всегда выдается ошибка 629 или окно подключения просто исчезает, при переподключении - все ок. 2. Сейчас ip-пул один, в будущем будет расширен или добавлен новый. Как прикрутить несколько ip-пулов? 3. При подключении клиента теряется связь с мультикастом (работает, пока не остановишь) - определил, что если удалить маршрут до 224.0.0.0 (созданный pptp на клиенте) то начинает работать - как реализовать, чтобы автоматом удалялся или не добавлялся? Вставить ник Quote
terrible Posted September 1, 2010 Posted September 1, 2010 Sep 1 10:43:53 srv1 mpd: [b-1] IFACE: Adding IPv4 address to ng0 failed: File existsSep 1 10:43:53 srv1 mpd: [b-1] IFACE: IfaceChangeAddr() error, closing IPCP http://yandex.ru/yandsearch?clid=9582&...IPCP&lr=213http://www.netup.ru/phpbb/viewtopic.php?t=6000 http://noted.org.ua/?p=984 Сами почему логи читать до сих пор не научились? Вставить ник Quote
