Есть сервер FreeBSD 8.0-RELEASE-p3 (шлюз) - две сетевые карты, внешний ip - "белый", внутренний - из 10.0.0.0/24 - локалка 10.0.0.0/8
установлен mpd5 из портов, работает, используется для выдачи "белых" ip-адресов клиентам
конфигурация:
mpd.conf
startup:
set user admin xxxxxx
set console self 127.0.0.1 5005
set console open
set web self 10.0.0.10 5006
set web open
default:
load pptp0
pptp0:
set ippool add poolstat 95.xxx.xxx.xxx 95.xxx.xxx.xxx
create bundle template B
set iface disable proxy-arp
set iface idle 0
set iface enable tcpmssfix
set ipcp yes vjcomp
set ipcp ranges 10.0.0.10/32 ippool poolstat
set ipcp dns 10.0.0.10
set bundle enable compression
set ccp yes mppc
set mppc yes compress e40 e56 e128 stateless
create link template L pptp
set link disable multilink
set link yes acfcomp protocomp
set link action bundle B
set link no pap chap
set link enable chap
set link enable chap-msv1
set link enable chap-msv2
set link keep-alive 10 75
set link mtu 1460
set pptp self 10.0.0.10
load radius
set link enable incoming
radius:
set radius server localhost xxxxxx 1812 1813
set radius retries 3
set radius timeout 3
set radius me 10.0.0.10
set auth acct-update 300
set auth enable radius-auth
set auth enable radius-acct
set radius enable message-authentic
log mpd при первом подключении клиента
Sep 1 10:43:51 srv1 mpd: [L-1] Accepting PPTP connection
Sep 1 10:43:51 srv1 mpd: [L-1] Link: OPEN event
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: Open event
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: state change Initial --> Starting
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: LayerStart
Sep 1 10:43:51 srv1 mpd: [L-1] PPTP: attaching to peer's outgoing call
Sep 1 10:43:51 srv1 mpd: [L-1] Link: UP event
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: Up event
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: state change Starting --> Req-Sent
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: SendConfigReq #1
Sep 1 10:43:51 srv1 mpd: [L-1] ACFCOMP
Sep 1 10:43:51 srv1 mpd: [L-1] PROTOCOMP
Sep 1 10:43:51 srv1 mpd: [L-1] MRU 1500
Sep 1 10:43:51 srv1 mpd: [L-1] MAGICNUM 3f383f58
Sep 1 10:43:51 srv1 mpd: [L-1] AUTHPROTO CHAP MSOFTv2
Sep 1 10:43:51 srv1 mpd: [L-1] MP MRRU 2048
Sep 1 10:43:51 srv1 mpd: [L-1] MP SHORTSEQ
Sep 1 10:43:51 srv1 mpd: [L-1] ENDPOINTDISC [802.1] 00 15 17 de 59 f8
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: rec'd Configure Request #0 (Req-Sent)
Sep 1 10:43:51 srv1 mpd: [L-1] MRU 1400
Sep 1 10:43:51 srv1 mpd: [L-1] MAGICNUM 4ff910ae
Sep 1 10:43:51 srv1 mpd: [L-1] CALLBACK 6
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: SendConfigRej #0
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: rec'd Configure Request #1 (Req-Sent)
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: SendConfigAck #1
Sep 1 10:43:51 srv1 mpd: [L-1] LCP: state change Req-Sent --> Ack-Sent
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: SendConfigReq #2
Sep 1 10:43:53 srv1 mpd: [L-1] ACFCOMP
Sep 1 10:43:53 srv1 mpd: [L-1] PROTOCOMP
Sep 1 10:43:53 srv1 mpd: [L-1] MRU 1500
Sep 1 10:43:53 srv1 mpd: [L-1] MAGICNUM 3f383f58
Sep 1 10:43:53 srv1 mpd: [L-1] AUTHPROTO CHAP MSOFTv2
Sep 1 10:43:53 srv1 mpd: [L-1] MP MRRU 2048
Sep 1 10:43:53 srv1 mpd: [L-1] MP SHORTSEQ
Sep 1 10:43:53 srv1 mpd: [L-1] ENDPOINTDISC [802.1] 00 15 17 de 59 f8
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: rec'd Configure Reject #2 (Ack-Sent)
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: SendConfigReq #3
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: rec'd Configure Ack #3 (Ack-Sent)
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: state change Ack-Sent --> Opened
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: auth: peer wants nothing, I want CHAP
Sep 1 10:43:53 srv1 mpd: [L-1] CHAP: sending CHALLENGE #1 len: 21
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: LayerUp
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: rec'd Ident #2 (Opened)
Sep 1 10:43:53 srv1 mpd: [L-1] MESG: MSRASV5.10
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: rec'd Ident #3 (Opened)
Sep 1 10:43:53 srv1 mpd: [L-1] MESG: MSRAS-0-LAPTOP
Sep 1 10:43:53 srv1 mpd: [L-1] CHAP: rec'd RESPONSE #1 len: 58
Sep 1 10:43:53 srv1 mpd: [L-1] Name: "test"
Sep 1 10:43:53 srv1 mpd: [L-1] AUTH: Trying RADIUS
Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Authenticating user 'test'
Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Rec'd RAD_ACCESS_ACCEPT for user 'test'
Sep 1 10:43:53 srv1 mpd: [L-1] AUTH: RADIUS returned: authenticated
Sep 1 10:43:53 srv1 mpd: [L-1] CHAP: Auth return status: authenticated
Sep 1 10:43:53 srv1 mpd: [L-1] CHAP: Reply message: S=935A56F6DAB2802AD6675D979DB3067113EB0121
Sep 1 10:43:53 srv1 mpd: [L-1] CHAP: sending SUCCESS #1 len: 46
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: authorization successful
Sep 1 10:43:53 srv1 mpd: [L-1] Link: Matched action 'bundle "B" ""'
Sep 1 10:43:53 srv1 mpd: [L-1] Creating new bundle using template "B".
Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: Interface ng0 created
Sep 1 10:43:53 srv1 mpd: [L-1] Link: Join bundle "B-1"
Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: Status update: up 1 link, total bandwidth 64000 bps
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: Open event
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Initial --> Starting
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: LayerStart
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Open event
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Initial --> Starting
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: LayerStart
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: Up event
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Starting --> Req-Sent
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendConfigReq #1
Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 10.0.0.10
Sep 1 10:43:53 srv1 mpd: [B-1] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Up event
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Starting --> Req-Sent
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: SendConfigReq #1
Sep 1 10:43:53 srv1 mpd: [B-1] MPPC
Sep 1 10:43:53 srv1 mpd: [B-1] 0x010000e0:MPPE(40, 56, 128 bits), stateless
Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Accounting user 'test' (Type: 1)
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: rec'd Configure Request #4 (Req-Sent)
Sep 1 10:43:53 srv1 mpd: [B-1] 0x010000e1:MPPC, MPPE(40, 56, 128 bits), stateless
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: SendConfigNak #4
Sep 1 10:43:53 srv1 mpd: [B-1] 0x01000040:MPPE(128 bits), stateless
Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Rec'd RAD_ACCOUNTING_RESPONSE for user 'test'
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Configure Request #5 (Req-Sent)
Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 0.0.0.0
Sep 1 10:43:53 srv1 mpd: [B-1] NAKing with 95.xxx.xxx.xxx
Sep 1 10:43:53 srv1 mpd: [B-1] PRIDNS 0.0.0.0
Sep 1 10:43:53 srv1 mpd: [B-1] NAKing with 10.0.0.10
Sep 1 10:43:53 srv1 mpd: [B-1] PRINBNS 0.0.0.0
Sep 1 10:43:53 srv1 mpd: [B-1] SECDNS 0.0.0.0
Sep 1 10:43:53 srv1 mpd: [B-1] SECNBNS 0.0.0.0
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendConfigRej #5
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Configure Reject #1 (Req-Sent)
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendConfigReq #2
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: rec'd Configure Nak #1 (Req-Sent)
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: SendConfigReq #2
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: rec'd Configure Request #6 (Req-Sent)
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: SendConfigAck #6
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Req-Sent --> Ack-Sent
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Configure Request #7 (Req-Sent)
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendConfigNak #7
Sep 1 10:43:53 srv1 mpd: [B-1] IPADDR 95.xxx.xxx.xxx
Sep 1 10:43:53 srv1 mpd: [B-1] PRIDNS 10.0.0.10
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Configure Ack #2 (Req-Sent)
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Req-Sent --> Ack-Rcvd
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: rec'd Configure Ack #2 (Ack-Sent)
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Ack-Sent --> Opened
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: LayerUp
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Compress using: mppc (MPPE(128 bits), stateless)
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Decompress using: mppc (MPPE(128 bits), stateless)
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Configure Request #8 (Ack-Rcvd)
Sep 1 10:43:53 srv1 mpd: [B-1] 95.xxx.xxx.xxx is OK
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendConfigAck #8
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Ack-Rcvd --> Opened
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: LayerUp
Sep 1 10:43:53 srv1 mpd: [B-1] 10.0.0.10 -> 95.xxx.xxx.xxx
Sep 1 10:43:53 srv1 mpd: [B-1] IFACE: Adding IPv4 address to ng0 failed: File exists
Sep 1 10:43:53 srv1 mpd: [B-1] IFACE: IfaceChangeAddr() error, closing IPCP
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: parameter negotiation failed
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Opened --> Stopping
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: SendTerminateReq #3
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: LayerDown
Sep 1 10:43:53 srv1 mpd: [B-1] rec'd unexpected protocol IP
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: rec'd Terminate Ack #3 (Stopping)
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Stopping --> Stopped
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: LayerFinish
Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: No NCPs left. Closing links...
Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: closing link "L-1"...
Sep 1 10:43:53 srv1 mpd: [L-1] Link: CLOSE event
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: Close event
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: state change Opened --> Closing
Sep 1 10:43:53 srv1 mpd: [L-1] Link: Leave bundle "B-1"
Sep 1 10:43:53 srv1 mpd: [L-1] RADIUS: Accounting user 'test' (Type: 2)
Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: Status update: up 0 links, total bandwidth 9600 bps
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: Close event
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Stopped --> Closed
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Close event
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Opened --> Closing
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: SendTerminateReq #3
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: LayerDown
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: Down event
Sep 1 10:43:53 srv1 mpd: [B-1] IPCP: state change Closed --> Initial
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: Down event
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: LayerFinish
Sep 1 10:43:53 srv1 mpd: [B-1] CCP: state change Closing --> Initial
Sep 1 10:43:53 srv1 mpd: [B-1] Bundle: Shutdown
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: SendTerminateReq #4
Sep 1 10:43:53 srv1 mpd: [L-1] LCP: LayerDown
Sep 1 10:43:54 srv1 mpd: [L-1] PPTP call terminated
Sep 1 10:43:54 srv1 mpd: [L-1] Link: DOWN event
Sep 1 10:43:54 srv1 mpd: [L-1] LCP: Down event
Sep 1 10:43:54 srv1 mpd: [L-1] LCP: LayerFinish
Sep 1 10:43:54 srv1 mpd: [L-1] LCP: state change Closing --> Initial
Sep 1 10:43:54 srv1 mpd: [L-1] Link: SHUTDOWN event
Sep 1 10:43:54 srv1 mpd: [L-1] Link: Shutdown
Вопросы:
1. При первом подключении пользователю всегда выдается ошибка 629 или окно подключения просто исчезает, при переподключении - все ок.
2. Сейчас ip-пул один, в будущем будет расширен или добавлен новый. Как прикрутить несколько ip-пулов?
3. При подключении клиента теряется связь с мультикастом (работает, пока не остановишь) - определил, что если удалить маршрут до 224.0.0.0 (созданный pptp на клиенте) то начинает работать - как реализовать, чтобы автоматом удалялся или не добавлялся?
