cat /proc/interrupts
            CPU0       CPU1       CPU2       CPU3       CPU4       CPU5       CPU6       CPU7
   0: 1887460523          0          0          0          0          0          0          0   IO-APIC-edge      timer
   1:          5          0          0          0          0          0          0          0   IO-APIC-edge      i8042
   4:          1          0          0          0          0          0          0          0   IO-APIC-edge
   8:         60          0          0          0          0          0          0          0   IO-APIC-edge      rtc0
   9:          0          0          0          0          0          0          0          0   IO-APIC-fasteoi   acpi
  14:     756618          0          0          0          0          0          0          0   IO-APIC-edge      ata_piix
  15:          0          0          0          0          0          0          0          0   IO-APIC-edge      ata_piix
  16:         38          0          0          0          0          0          0          0   IO-APIC-fasteoi   uhci_hcd:usb3
  18:          2          0          0          0          0          0          0          0   IO-APIC-fasteoi   ehci_hcd:usb1, uhci_hcd:usb6
  19:          0          0          0          0          0          0          0          0   IO-APIC-fasteoi   ata_piix, uhci_hcd:usb5
  23:          0          0          0          0          0          0          0          0   IO-APIC-fasteoi   ehci_hcd:usb2, uhci_hcd:usb4
  55:          4          0          0          0          0          0          0          0   PCI-MSI-edge      eth0
  56: 1643532664          0          0          0          0          0          0          0   PCI-MSI-edge      eth0-rx-0
  57:          5 1737203636          0          0          0          0          0          0   PCI-MSI-edge      eth0-rx-1
  58:          5          0 2561956177          0          0          0          0          0   PCI-MSI-edge      eth0-tx-0
  59:          5          0          0 2618170981          0          0          0          0   PCI-MSI-edge      eth0-tx-1
  60:          4          0          0          0          0          0          0          0   PCI-MSI-edge      eth1
  61:          5          0          0          0 1960894818          0          0          0   PCI-MSI-edge      eth1-rx-0
  62:          4          0          0          0          0 1994152509          0          0   PCI-MSI-edge      eth1-rx-1
  63:          4          0          0          0          0          0 3343611560          0   PCI-MSI-edge      eth1-tx-0
  64:          4          0          0          0          0          0          0    2065419   PCI-MSI-edge      eth1-tx-1
NMI:    7704654      41605     160940     106106     199608     239168      20572       9129   Non-maskable interrupts
LOC:  103085495 1351629945  360371307  359123490 2010271296 2028174767  362856000  362785890   Local timer interrupts
SPU:          0          0          0          0          0          0          0          0   Spurious interrupts
PMI:          0          0          0          0          0          0          0          0   Performance monitoring interrupts
PND:          0          0          0          0          0          0          0          0   Performance pending work
RES:       7248       3475       2349       2309        366       3244       2217       2073   Rescheduling interrupts
CAL:         26         38         42         41     460157         40         41         42   Function call interrupts
TLB:       1532        884        169         10       5119       5934        151          8   TLB shootdowns
ERR:          0
MIS:          0
cat /proc/irq/0/smp_affinity
ffff
cat /sys/devices/system/clocksource/clocksource0/current_clocksource
tsc
На других серверах прерывания от таймера (irq 0) обрабатываются всеми CPU и их кол-во ничтожно мало:
           CPU0       CPU1       CPU2       CPU3
  0:       6374       5798       6369       5844   IO-APIC-edge      timer
  9:          0          0          0          0   IO-APIC-fasteoi   acpi
14:          0          0          0          0   IO-APIC-edge      ata_piix
15:          0          0          0          0   IO-APIC-edge      ata_piix
16:          0          0          0          0   IO-APIC-fasteoi   uhci_hcd:usb5
18:          0          0          0          0   IO-APIC-fasteoi   uhci_hcd:usb4
19:     724106     677568     724901     676228   IO-APIC-fasteoi   ata_piix, uhci_hcd:usb3
23:         10          9         10         10   IO-APIC-fasteoi   ehci_hcd:usb1, uhci_hcd:usb2
79: 1056044290          2 1055924526          0   PCI-MSI-edge      eth1
80:          0 3371465553          1 3371183698   PCI-MSI-edge      eth0
NMI:          0          0          0          0   Non-maskable interrupts
LOC: 3358006264 2708537017 3306706609 2491989335   Local timer interrupts
SPU:          0          0          0          0   Spurious interrupts
CNT:          0          0          0          0   Performance counter interrupts
PND:          0          0          0          0   Performance pending work
RES:       2418       3978       4110       3360   Rescheduling interrupts
CAL:        132        112        131        123   Function call interrupts
TLB:     107845     358113     109483     360469   TLB shootdowns
ERR:          0
MIS:          0
Куда копать?
Edited by shaytan
Tickless System - в ядре не включена на всех серверах.
clocksource везде tsc.
Единственное отличие в ядрах - это драйвер сетевой карты. Там где таймер грузит CPU0 используется igb.
Edited by shaytan
У меня так (igb)
# cat /proc/interrupts
           CPU0       CPU1       CPU2       CPU3       CPU4       CPU5       CPU6       CPU7       CPU8       CPU9       CPU10      CPU11      CPU12      CPU13      CPU14      CPU15
  0:         36          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   IO-APIC-edge      timer
  1:          2          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   IO-APIC-edge      i8042
  8:          1          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   IO-APIC-edge      rtc0
  9:          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   IO-APIC-fasteoi   acpi
12:          4          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   IO-APIC-edge      i8042
16:          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   IO-APIC-fasteoi   uhci_hcd:usb1
18:          2          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   IO-APIC-fasteoi   ehci_hcd:usb5, uhci_hcd:usb7
19:          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   IO-APIC-fasteoi   uhci_hcd:usb3, uhci_hcd:usb6
21:         55          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   IO-APIC-fasteoi   uhci_hcd:usb2
23:          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   IO-APIC-fasteoi   uhci_hcd:usb4, ehci_hcd:usb8
1251:    3673294          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI-edge      ahci
1252:          1          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0      none-edge
1258:          4          0          0          0          0          0          0          0          0          0          0          0          0          0          0 1376429509   PCI-MSI-edge      eth3-tx-0
1259:          3          0          0          0          0          0          0          0          0          0          0          0          0          0 1137924776          0   PCI-MSI-edge      eth3-rx-0
1260:          1          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI-edge      eth3
1261:          3          0          0          0          0          0          0          0          0          0          0          0          0 1451771203          0          0   PCI-MSI-edge      eth2-tx-0
1262:          3          0          0          0          0          0          0          0          0          0          0          0 1260105200          0          0          0   PCI-MSI-edge      eth2-rx-0
1263:          1          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI-edge      eth2
1264:          5          0          0          0          0          0          0          0          0          0          0 1407699724          0          0          0          0   PCI-MSI-edge      eth1-tx-0
1265:          3          0          0          0          0          0          0          0          0          0 1340320459          0          0          0          0          0   PCI-MSI-edge      eth1-rx-0
1266:          1          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI-edge      eth1
1267:          3          0          0          0          0          0          0          0          0     212826          0          0          0          0          0          0   PCI-MSI-edge      eth0-tx-3
1268:          3          0          0          0          0          0          0          0     212826          0          0          0          0          0          0          0   PCI-MSI-edge      eth0-tx-2
1269:          3          0          0          0          0          0          0     212826          0          0          0          0          0          0          0          0   PCI-MSI-edge      eth0-tx-1
1270:          5          0          0          0          0          0 3006023887          0          0          0          0          0          0          0          0          0   PCI-MSI-edge      eth0-tx-0
1271:         23          0          0          0          0 1106456484          0          0          0          0          0          0          0          0          0          0   PCI-MSI-edge      eth0-rx-3
1272:         32          0          0          0 1145335785          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI-edge      eth0-rx-2
1273:         15          0          0 1140364416          0          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI-edge      eth0-rx-1
1274:         31          0 1139908203          0          0          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI-edge      eth0-rx-0
1275:         62          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI-edge      eth0
NMI:          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   Non-maskable interrupts
LOC:   18807804    4373216   89325354   89162889   88248477   88152167   85669410   37755936   42128777   33831256   91893902   81404190   91082055   81226957   90725347   80677291   Local timer interrupts
RES:      22957       5729      17056      12600       9526      11853       9136    2806176    1745684      20939      50450      16084      19530      21003      19434      14494   Rescheduling interrupts
CAL:    1901491    1901278    1901750    1901752    1901754    1901755    1901752    1901749    1878408     106813    1888688    1892285    1898810    1897068    1853277    1897696   function call interrupts
TLB:       8743       5191       9529      10972      11727      10176      16533       8996      38335     142299      80560      61786      65239     166810      97358      84900   TLB shootdowns
TRM:          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   Thermal event interrupts
THR:          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   Threshold APIC interrupts
SPU:          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0   Spurious interrupts
ERR:          0
# cat /proc/irq/0/smp_affinity
0000ffff
# cat /sys/devices/system/clocksource/clocksource0/current_clocksource
tsc
Похоже проблема в железе (PIC)
На железе HP DL160G5 (Intel 5400 Chipset) проблемы нет, а стоит переставить систему на HP DL160G6 (Intel 5520 Chipset) так проблема появляется.
Здесь описана аналогичная ситуация.
Edited by shaytan
