Подскажите как работать с саском. Вещаю через getstream. Хочу сделать связку с саском. Но не могу понять как он будет снимать кодировку с каналов.
Вот лог запуска.
iptv2:~# LD_LIBRARY_PATH=/usr/local/src/sc/contrib/sasc-ng/sc/PLUGINS/lib/ /usr/bin/sasc-ng -j 0:2 --cam-budget
Jun 27 13:12:11.023 : Version: 0.0.2-1cc3497be31c+
Jun 27 13:12:11.023 CAM: initializing plugin: SoftCam (1.0.0pre-HG-1cc3497be31c+): A software emulated CAM
Jun 27 13:12:11.023 [general.info] SC version 1.0.0pre-HG-1cc3497be31c+ initializing (VDR 1.6.0)
Jun 27 13:12:11.023 CAM: starting plugin:
Jun 27 13:12:11.023 [general.info] SC version 1.0.0pre-HG-1cc3497be31c+ starting (VDR 1.6.0)
Jun 27 13:12:11.023 [core.load] ** Plugin config:
Jun 27 13:12:11.023 [core.load] ** Key updates (AU) are enabled (active CAIDs) (no prestart)
Jun 27 13:12:11.023 [core.load] ** Local systems DON'T take priority over cached remote
Jun 27 13:12:11.023 [core.load] ** Concurrent FF recordings are NOT allowed
Jun 27 13:12:11.023 [core.load] ** Force transfermode with digital audio
Jun 27 13:12:11.023 [core.load] ** ECM cache is set to enabled
Jun 27 13:12:11.023 [core.load] ** ScCaps are 1 2 0 0 0 0 0 0 0 0
Jun 27 13:12:11.023 [general.error] failed open ./sc_files/cardclient.conf: No such file or directory
Jun 27 13:12:11.023 [general.error] failed open ./sc_files/SoftCam.Key: No such file or directory
Jun 27 13:12:11.023 [general.error] failed open ./sc_files/smartcard.conf: No such file or directory
Jun 27 13:12:11.023 [general.error] failed open ./sc_files/cardslot.conf: No such file or directory
Jun 27 13:12:11.023 [general.error] failed open ./sc_files/override.conf: No such file or directory
Jun 27 13:12:11.023 [general.error] no keys loaded for softcam!
Jun 27 13:12:11.023 [core.load] ** registered systems:
Jun 27 13:12:11.023 [core.load] ** Cardclient        (pri -15)
Jun 27 13:12:11.023 [core.load] ** Conax             (pri -10)
Jun 27 13:12:11.023 [core.load] ** ConstCW           (pri -20)
Jun 27 13:12:11.023 [core.load] ** Cryptoworks       (pri -10)
Jun 27 13:12:11.023 [core.load] ** Irdeto            (pri -10)
Jun 27 13:12:11.023 [core.load] ** Irdeto2           (pri  -8)
Jun 27 13:12:11.023 [core.load] ** Nagra             (pri -10)
Jun 27 13:12:11.023 [core.load] ** Nagra2            (pri -10)
Jun 27 13:12:11.023 [core.load] ** Fake-NDS          (pri -12)
Jun 27 13:12:11.023 [core.load] ** SC-Conax          (pri  -5)
Jun 27 13:12:11.023 [core.load] ** SC-Cryptoworks    (pri  -5)
Jun 27 13:12:11.023 [core.load] ** SC-Irdeto         (pri  -5)
Jun 27 13:12:11.023 [core.load] ** SC-Nagra          (pri  -5)
Jun 27 13:12:11.023 [core.load] ** SC-Seca           (pri  -5)
Jun 27 13:12:11.023 [core.load] ** SC-Viaccess       (pri  -5)
Jun 27 13:12:11.023 [core.load] ** SC-VideoGuard2    (pri  -5)
Jun 27 13:12:11.023 [core.load] ** Seca              (pri -10)
Jun 27 13:12:11.023 [core.load] ** @SHL              (pri -10)
Jun 27 13:12:11.023 [core.load] ** Viaccess          (pri -10)
Jun 27 13:12:12.025 frontend: Starting thread on /dev/dvb/adapter2/frontend1
The thread scheduling parameters indicate:
policy = 0
priority = 0
Jun 27 13:12:12.026 demux: Starting thread on /dev/dvb/adapter2/demux1
policy = 0
priority = 0
Jun 27 13:12:12.026 dvr: Starting thread on /dev/dvb/adapter2/dvr1
policy = 1
priority = 99
Jun 27 13:12:12.026 : Listening on port 5456
^CJun 27 13:12:58.411 [general.debug] SC cleanup done
Jun 27 13:12:58.411 : Exiting...
Где брать вот эти файлы.
можно выбрать любое место параметром --cam-dir
Попробовал.
Теперь вот так
Jun 27 17:11:32.204 [general.info] loading keys from /usr/sc_files/SoftCam.Key
Jun 27 17:11:32.204 [core.load] unknown key type 'F', adding dummy
Jun 27 17:11:32.204 [general.error] file /usr/sc_files/SoftCam.Key has error in line #1
Jun 27 17:11:32.204 [general.error] file /usr/sc_files/SoftCam.Key has error in line #2
Jun 27 17:11:32.204 [general.error] file /usr/sc_files/SoftCam.Key has error in line #3
Jun 27 17:11:32.204 [general.error] file /usr/sc_files/SoftCam.Key has error in line #4
Jun 27 17:11:32.204 [general.error] file /usr/sc_files/SoftCam.Key has error in line #5
Jun 27 17:11:32.204 [general.error] file /usr/sc_files/SoftCam.Key has error in line #6
Jun 27 17:11:32.204 [general.error] file /usr/sc_files/SoftCam.Key has error in line #7
Jun 27 17:11:32.204 [general.error] file /usr/sc_files/SoftCam.Key has error in line #8
Jun 27 17:11:32.204 [core.load] loaded 0 keys from /usr/sc_files/SoftCam.Key
Вот код SoftCam.Key
F 08341646 00 begin_of_the_skype_highlighting              08341646 00      end_of_the_skype_highlighting C12345296789AB9B; STS (+4h) (Yamal 201) 01/12/08 19:32
F 08341646 01 C12345296789AB9B; STS (+4h) (Yamal 201) 01/12/08 19:32
F 00011FFF 00 C12345296789AB9B; STS (+7h) (LMI 75E) 01/12/08 19:34
F 00011FFF 01 C12345296789AB9B; STS (+7h) (LMI 75E) 01/12/08 19:34
F 00011FFF 00 C12345296789AB9B; STS (+7h) (Yamal 201) 01/12/08 19:33
F 00011FFF 01 C12345296789AB9B; STS (+7h) (Yamal 201) 01/12/08 19:33
F 00011FFF 00 C12345006789AB00; STS (AM22-53) 01/12/08 18:41
F 00011FFF 01 C12345006789AB00; STS (AM22-53) 01/12/08 18:42
Если убираю букву F тогда при запуске пишет
[core.load] unknown key type '0', adding dummy
Edited by FATHER_FBI
