Кто нибудь использует для авторизации сабскрабера сам интерфейс?
"ip subscriber interface"
Попробовал, сервисы вешаются, трафик в сервисы попадает, но нет аккаутинга по сервисам, ни стоповых, ни стартовых пакетов вообще не приходит ни по одному сервису.
Если пробовать ip subscriber routed или l2-connectde все приходит.
Копал cisco, упоминание про аккаутинг при использовании "ip subscriber interface" не нашел...
Вот сессия
Unique Session ID: 99
Identifier: test
SIP subscriber access type(s): IP-Interface
Current SIP options: None
Session Up-time: 00:00:09, Last Changed: 00:00:09
Interface: GigabitEthernet0/1.10
Policy information:
  Context 0684C37C: Handle E1000C76
  AAA_id 00023BA0: Flow_handle 0
  Authentication status: authen
  Downloaded User profile, excluding services:
    ssg-account-info     "Aservice_unauth"
    idletime             300 (0x12C)
    timeout              21600 (0x5460)
    reply-message        "Hello, R1:0/0/1/10"
    username             "test"
    reply-message        "Hello, test"
    ssg-account-info     "Aservice_inet512"
    ssg-account-info     "Aservice_inet2pre"
    ssg-account-info     "Aservice_local5120"
  Downloaded User profile, including services:
    username             "test"
    accounting-list      “rad”
    ssg-service-info     "QU;512000;96000;192000;D;512000;96000;192000"
    clid                 "0030.18a0.4ec6"
    sss-service          6 [local-termination]
    service-type         5 [Outbound]
    traffic-class        "in default drop"
    traffic-class        "out default drop"
    traffic-class        "in access-group name service_inet2pre_in priority 400"
    traffic-class        "out access-group name service_inet2pre_out priority 400"
  Config history for session (recent to oldest):
    Access-type: Web-service-logon Client: SM
     Policy event: Apply Config Success (Service)
      Profile name: service_inet2pre, 4 references
     Policy event: Service Selection Request (Service)
      Profile name: service_unauth, 178 references
        username             "service_unauth"
        password             <hidden>
        traffic-class        "input default drop"
        traffic-class        "output default drop"
      Profile name: service_inet512, 58 references
        traffic-class        "in access-group name service_inet_in priority 500"
        traffic-class        "out access-group name service_inet_out priority 500"
      Profile name: service_local5120, 12 references
        traffic-class        "in access-group name service_local_in priority 200"
        traffic-class        "out access-group name service_local_out priority 200"
        ssg-service-info     "QU;5120000;960000;1920000;D;5120000;960000;1920000"
    Access-type: IP-Interface Client: SM
      Profile name: nas-port:0.0.0.0:0/0/1/10, 2 references
        username             "test"
  Active services associated with session:
    name "service_inet2pre"
    name "service_inet512"
    name "service_local5120"
  Rules, actions and conditions executed:
    subscriber rule-map isg_sss_initif
      condition always event session-start
        20 authorize aaa list pppoe identifier nas-port
Session inbound features:
Traffic classes:
  Traffic class session ID: 682
   ACL Name: service_local_in, Packets = 3, Bytes = 232
  Traffic class session ID: 230
   ACL Name: service_inet_in, Packets = 0, Bytes = 0
  Traffic class session ID: 662
   ACL Name: service_inet2pre_in, Packets = 1, Bytes = 76
Default traffic is dropped
Unmatched Packets = 0, Re-classified packets (redirected) = 0
Feature: IP Idle Timeout
  Timeout value is 300
  Idle time is 00:00:31
Session outbound features:
Traffic classes:
   ACL Name: service_local_out, Packets = 3, Bytes = 980
   ACL Name: service_inet_out, Packets = 0, Bytes = 0
   ACL Name: service_inet2pre_out, Packets = 0, Bytes = 0
Non-datapath features:
Feature: Session Timeout
  Timeout value is 21600 seconds
  Time remaining is 05:58:52
Configuration sources associated with this session:
Service: service_inet2pre, Active Time = 00:01:07
  AAA Service ID = 3724542134
Service: service_unauth, Active Time = 00:01:07
Service: service_inet512, Active Time = 00:01:07
  AAA Service ID = 2634023719
Service: service_local5120, Active Time = 00:01:07
  AAA Service ID = 1979711499
Interface: GigabitEthernet0/1.10, Active Time = 00:01:07
Edited by ya4ya
Попробовал поднять на dynamips'е на разных ios'ах тоже самое.
ip subscriber routed или l2-connectde аккаутинг есть с ip subscriber interface - нету совсем.
Полисинг работает...
Странно блин.
Может я много хочу?
Приходит влан с пользователем, на которого кроме /30 зароучена сеть /26. Необходимо все это расценивать(считать/полисить) как одного пользователя. Возможно можно как нибудь по другому?
Странно блин.
Может я много хочу?
Попробуйте в профиле сервисов атрибутами передать название радиус схемы для аккаунтинга и апдейт интервал.
ещё не понятно как вы добились Unique Session ID: 99
Identifier: test
при
username "test"
идентификатором (юзернеймом) при ip subscriber interface
является же интерфейс, то есть R1:0/0/1/10
Передаю :(
Вот например.
service_inet512              Huntgroup-Name == "ASCONFIG"
                        cisco-avpair = "accounting-list=rad",
                        cisco-avpair += "ip:traffic-class=in default drop",
                        cisco-avpair += "ip:traffic-class=out default drop",
                        cisco-avpair += "ip:traffic-class=in access-group name service_inet_in priority 500",
                        cisco-avpair += "ip:traffic-class=out access-group name service_inet_out priority 500",
                        Cisco-Service-Info += "QU;512000;96000;192000;D;512000;96000;192000",
                        Service-Type = Outbound-User
А идентификатор из-за того что при авторизация радиусом выдаю User-Name := "test" - атрибут. Соответственно authed username становиться "test". На него и ведеться весь аккаутинг когда он работает :((с ip subscriber routed или l2-connectde, pppoe...) и т.д. и т.п., удобно.
Edited by ya4ya
Передаю :(
Вот например.
Да сорь, не заметил accounting-list “rad”,
действительно странно.
Попробуйте два атрибута отдавать, второй хоть и опциональный но может багофича.
1. Cisco-Avpair="accounting-list=accounting-mlist-name"
2. IETF RADIUS attribute Acct-Interim-Interval (attribute 85)
Попробовал, не помогло :(
А можно тогда
show run | inc aaa
show run | inc radius
show version | inc image
и атрибуты радиуса которые отдаются по основной сессии
конечно.
aaa new-model
aaa group server radius radius-def
aaa authentication login default local group radius-def enable
aaa authentication ppp rad group radius-def
aaa authorization exec default local group radius-def
aaa authorization network rad group radius-def
aaa authorization subscriber-service default local group radius-def
aaa accounting delay-start all
aaa accounting suppress null-username
aaa accounting update periodic 10
aaa accounting exec rad start-stop group radius-def
aaa accounting network default start-stop group radius-def
aaa accounting network rad start-stop group radius-def
aaa server radius dynamic-author
aaa session-id unique
  20 authorize aaa list rad password ISG identifier nas-port
radius-server attribute 44 include-in-access-req
radius-server attribute 8 include-in-access-req
radius-server attribute 32 include-in-access-req
radius-server attribute 32 include-in-accounting-req
radius-server attribute 55 include-in-acct-req
radius-server attribute 55 access-request include
radius-server attribute nas-port format e UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
radius-server attribute 31 mac format unformatted
radius-server attribute 31 send nas-port-detail mac-only
radius-server host xxxxxxx auth-port 1645 acct-port 1646
radius-server retransmit 5
radius-server key xxxxxxx
radius-server vsa send cisco-nas-port
radius-server vsa send accounting
radius-server vsa send authentication
System image file is "disk0:c7200p-advipservicesk9_li-mz.122-33.SRD3.bin"
Попробовал уже на трех железках, на двух из них на разных иосах. Может я просто не умею его готовить конечно. Но уже в который раз перечитываю cisco.com по этому поводу...
в aaa group server radius radius-def только адрес сервера.
Например вот, пробовал добавить Session-Timeout и к основной сессии и к сервису. К сервсису тотже реплай к примеру на service_inet512.
Sun Feb 14 04:45:18 2010
        Packet-Type = Access-Accept
        Cisco-Account-Info += "Aservice_unauth"
        Idle-Timeout := 300
        Session-Timeout := 21600
        Reply-Message = "Hello, AS1:0/0/1/10"
        User-Name := "test"
        Reply-Message += "Hello, test"
        Cisco-Account-Info += "Aservice_inet512"
        Cisco-Account-Info += "Aservice_inet2pre"
        Cisco-Account-Info += "Aservice_local5120"
Если есть возможность попробуйте сами у себя. И скажите результат. Если будет хотябы стартовый acct пакет этого будет достаточно.
Edited by ya4ya
  • 10 months later...
И ещё вопрос... кто-нибудь может подсказать как при авторизации ip subscriber interface деактивировать сервис или наоборот активировать ?
Сейчас картина такая:
cs-pe1.yar#sh sss session
Current Subscriber Information: Total sessions 3
Uniq ID Interface    State         Service      Identifier           Up-time
1799    Se1/0:0      unauthen      Ltm MLP Lnk  nas-port:0/1/0/0/0   02:45:55
3090    Se1/1:0      unauthen      Ltm MLP Lnk  nas-port:0/1/0/1/0   02:45:55
1675    Gi0/1.973    authen        Local Term   123                  00:07:00
140     Traffic-Clas unauthen      Ltm Internal                      00:07:00
n/a     Mu1          connected     Ltm Internal nas-port:0/1/0/0/0   02:45:55
cs-pe1.yar#sh sss session uid 1675 detailed
Unique Session ID: 1675
Identifier: 123
Session Up-time: 00:00:21, Last Changed: 00:00:21
Interface: GigabitEthernet0/1.973
Policy information:
  Context 6675E59C: Handle 85000A01
  AAA_id 000BB002: Flow_handle 0
    ssg-account-info     "AINTERNET"
    ssg-service-info     "NINTERNET"
    username             "123"
    username             "123"
    traffic-class        "in access-group 111 priority 10"
    traffic-class        "out access-group 111 priority 10"
    accounting-list      "ISG-AUTH-YAR"
    ssg-service-info     "IINTERNET"
      Profile name: INTERNET, 4 references
      Profile name: nas-port:x.x.x.x:0/0/1/973, 2 references
        username             "123"
    name "INTERNET"
    subscriber rule-map ISG-CUSTOMERS-POLICY
        10 authorize aaa list ISG-AUTH-YAR identifier nas-port
Traffic classes:
  Traffic class session ID: 2739
   ACL Name: 111, Packets = 6281, Bytes = 471592
Traffic classes:
   ACL Name: 111, Packets = 8306, Bytes = 10248704
Service: INTERNET, Active Time = 00:00:35
  AAA Service ID = 3623945013
Interface: GigabitEthernet0/1.973, Active Time = 00:00:35
хочется через CoA вырубить допустим сервис INTERNET абоненту и включить L4R.
пытаюсь элементарно получить статус текущей сессии
equity cisco # /bin/echo "User-Name=\"123\",cisco-avpair=\"subscriber:command=account-status-query\""  | /usr/bin/radclient -x х.х.х.х:1700 coa yarisg
Sending CoA-Request of id 193 to х.х.х.х port 1700
        User-Name = "123"
        Cisco-AVPair = "subscriber:command=account-status-query"
rad_recv: CoA-NAK packet from host х.х.х.х port 1700, id=193, length=76
        Cisco-Command-Code = "\0040"
        Cisco-AVPair = "sg-version=1.0"
        Reply-Message = "No valid Session"
        Error-Cause = Session-Context-Not-Found
во всех примерах, которые встречал - везде фигурирует аттрибут account-info со значением Sy.y.y.y, где y.y.y.y - IP абонента.
И совсем неясно, что туда подставить, если у абонента несколько IP, а авторизация в моем случае идет по интерфейсу.
Edited by stason
удалось добиться ответов только включив PBHK, чтобы можно было найти сессию по IP:<PBHK KEY>
equity cisco # /bin/echo "User-name=\"*\",Cisco-Account-Info=\"Sx.x.x.x:85\",cisco-avpair=\"subscriber:command=account-status-query\""  | /usr/bin/radclient -x x.x.x.x:1700 coa yarisg
Sending CoA-Request of id 213 to x.x.x.x port 1700
        User-Name = "*"
        Cisco-Account-Info = "Sx.x.x.x:85"
rad_recv: CoA-ACK packet from host x.x.x.x port 1700, id=213, length=233
        Cisco-Account-Info = "N1PBHK;194;123;0;0;0;0"
        Cisco-Account-Info = "N1INTERNET;194;123;10346;11577;1748367;12087110"
        User-Name = "123"
        Cisco-Account-Info = "$IGigabitEthernet0/1.973"
        Cisco-Command-Code = "\0041"
        Cisco-NAS-Port = "0/0/1/973"
        NAS-Port = 16778189
        NAS-Port-Id = "0/0/1/973"
искать по одному user-name или допустим Cisco-Account-Info = "$IGigabitEthernet0/1.973" ни в какую не хочет. только с указанием Cisco-Account-Info = "Sx.x.x.x:85" и никак иначе =\
есть у кого-нибудь опыт по применению этих фич ? должно ли оно себя так вести ? можно ли обойтись без применения portbundle ?
  • 5 weeks later...
