Сегодня 2 сервака, с интревалов в 6 часов ушли в кернел-паник.
Конфигурация софта одинаковая, отличаются процессорами с материнкой.
Fatal trap 12: page fault while in kernel mode
cpuid = 1; apic id = 01
fault virtual address   = 0x4
fault code              = supervisor read, page not present
instruction pointer     = 0x20:0x808fc903
stack pointer           = 0x28:0xa616da54
frame pointer           = 0x28:0xa616da54
code segment            = base 0x0, limit 0xfffff, type 0x1b
                        = DPL 0, pres 1, def32 1, gran 1
processor eflags        = interrupt enabled, resume, IOPL = 0
current process         = 29 (em0_rx_kthread_0)
trap number             = 12
panic: page fault
cpuid = 0
Uptime: 1d3h44m56s
Physical memory: 981 MB
Dumping 215 MB: 200 184 168 152 136 120 104 88 72 56 40 24 8
Dump complete
Automatic reboot in 15 seconds - press a key on the console to abort
Rebooting...
cpu_reset: Stopping other CPUs
/boot/loader.conf
vpn2# cat /boot/loader.conf
kern.ipc.maxpipekva=32000000
kern.ipc.maxsockbuf=1048576
kern.maxusers=512
net.inet.tcp.tcbhashsize=32768
net.graph.maxalloc=4096
hw.em.rxd=2048
hw.em.txd=2048
hw.em.rx_int_delay=900
hw.em.tx_int_delay=900
hw.em.rx_abs_int_delay=1800
hw.em.tx_abs_int_delay=1800
sysctl.conf
net.inet.icmp.icmplim=100
#kern.maxfilesperproc=32768
#kern.maxfiles=65536
kern.ipc.somaxconn=2048
kern.ipc.maxsockets=100000
kern.ipc.nmbclusters=100000
#net.inet.ip.intr_queue_maxlen=10000
#net.inet.ip.fw.debug=0
net.inet.ip.fw.dyn_max=20480
net.inet.ip.fw.dyn_buckets=4096
##net.inet.ip.fastforwarding=1
#net.inet.tcp.msl=7500
#net.inet.tcp.rfc1323=1
net.inet.ip.portrange.first=8192
net.inet.ip.portrange.last=65535
net.inet.ip.portrange.randomized=0
net.inet.ip.intr_queue_maxlen=4096
net.inet.tcp.blackhole=2
net.inet.udp.blackhole=1
net.inet.ip6.redirect=0
net.inet.ip.redirect=1  #prin 0 normalno ne rabotaet
#net.inet.udp.maxdgram=57344
net.inet.udp.recvspace=65536
net.inet.tcp.sendspace=65536
net.inet.tcp.recvspace=65536
net.graph.maxdgram=128000
net.graph.recvspace=128000
net.local.stream.recvspace=65535
net.local.stream.sendspace=65535
# Intel(R) PRO/1000 Network Connection 6.9.6
dev.em.0.rx_int_delay=900
dev.em.0.tx_int_delay=900
dev.em.0.rx_abs_int_delay=1800
dev.em.0.tx_abs_int_delay=1800
dev.em.0.rx_processing_limit=400
стоят дрова от Яндекса
Что можно посмотреть ? может чего-то лишнего накрутил ?
  • 2 weeks later...
уберите весь тюнинг к чертям, кроме таймингов на сетёвки.
пы.сы. два браса имхо так просто не уходят в панику
минимизировал тюнинг на них, ситуация стабилизировалась, но на одном серваке
второй временами с разным периодом может уйти в панику
причем ребут связан с сетевушкой pro1000ET дрова igb от intel 1.84
с предыдущими версиями дров система ребутится при старте
cpuid = 0; apic id = 00
fault virtual address   = 0x472a8b02
instruction pointer     = 0x20:0x8074b72e
stack pointer           = 0x28:0x8768abf8
frame pointer           = 0x28:0x8768ac14
current process         = 39 (irq263: igb1)
trap number             = 12
panic: page fault
cpuid = 0
[font="Arial Black"]Uptime: 2d11h34m15s[/font]
Physical memory: 3557 MB
Dumping 345 MB:kernel trap 9 with interrupts disabled
fault virtual address   = 0x98
fault code              = supervisor write, page not present
instruction pointer     = 0x20:0x8072d3f6
stack pointer           = 0x28:0x8778087c
frame pointer           = 0x28:0x87780894
current process         = 49 (irq21: uhci1++)
trap number             = 12
330 314 298 282 266 250 234 218 202 186 170 154 138 122 106 90 74 58 42 26 10
Dump complete
Automatic reboot in 16 seconds - press a key on the console to abort
Rebooting...
panic: igb_get_buf: dmamap load failure
cpuid = 0
Uptime: 21h12m45s
Dumping 317 MB: 302 286
fault virtual address   = 0xfffeffff
instruction pointer     = 0x20:0xfffeffff
stack pointer           = 0x28:0x8762b94c
frame pointer           = 0x28:0x0
current process         = 30 (irq258: igb0)
trap number             = 12
panic: page fault
cpuid = 0
[font="Arial Black"]Uptime: 21h12m45s[/font]
Rebooting...
я просил убрать вообще а не минимизировать
это для чего: у вас же igb
hw.em.rxd=2048
hw.em.txd=2048
какое железо используется?
какой софт крутится?
у меня вот вообще странности были с операционкой и тюнингом со включеными набортными сетевыми платами,
шопотом: попробуйте поотключать всё ненужное в бивисе.
Edited by Giga-Byte
в биосе com,lpt,fdd -выключены
усб пришлось оставить, тк юзаю усб клавиатуру
материнка intel DQ35JOE+Core2Duo E8400 3GHz
внутр сетевушка в биосе вкл. , но сейчас не не активна, хотя вместе в ней он тоже ребутился
данные sysctl для нее прописаны
для igb прописаны похожие параметры
подозрение на железо, но я заменил уже и память и сетевушку, остается только саму материнку сменить, хотя сегодня попробую заменить бп48В заменить на обычный
  • 3 weeks later...
заменил материнку, поставил дрова от яндекса , система проработала неделю без нареканий и сегодня вівалилась (без перезагрузки) в панику только со ссылкой на очереди em0
Ожидаю комплекта на ксеоне , но все же интересна текущая конфигурация, почему валится система ?
вот поставил сейчас в работу с 6.9.21, оч странно, до єтого стояла сетевушка ЕТ с дровами igb1.8.4 , были такиеже ситуации
