UTP
Пользователи
  • Posts
    23
  • Joined
  • Last visited
About UTP
  • Rank
    Абитуриент
    Абитуриент
Контакты
  • ICQ
    Array
  1. man igb hw.igb.rxd Number of receive descriptors allocated by the driver. The default value is 256. The minimum is 80, and the maximum is 4096. hw.igb.txd Number of transmit descriptors allocated by the driver. The default value is 256. The minimum is 80, and the maximum is 4096.
  2. pfctl -si Status: Enabled for 3 days 20:25:50 Debug: Urgent State Table Total Rate current entries 17935 searches 54378409558 163421.2/s inserts 61485264 184.8/s removals 61467329 184.7/s Counters match 51300951214 154172.7/s bad-offset 0 0.0/s fragment 29290 0.1/s short 3345 0.0/s normalize 0 0.0/s memory 0 0.0/s bad-timestamp 0 0.0/s congestion 0 0.0/s ip-option 57391 0.2/s proto-cksum 1086994 3.3/s state-mismatch 3762063 11.3/s state-insert 0 0.0/s state-limit 0 0.0/s src-limit 0 0.0/s synproxy 0 0.0/s
  3. PID USERNAME PRI NICE SIZE RES STATE C TIME WCPU COMMAND 11 root 171 ki31 0K 16K CPU7 7 68.9H 100.00% idle: cpu7 12 root 171 ki31 0K 16K RUN 6 68.8H 100.00% idle: cpu6 13 root 171 ki31 0K 16K CPU5 5 68.3H 100.00% idle: cpu5 15 root 171 ki31 0K 16K CPU3 3 69.4H 97.36% idle: cpu3 17 root 171 ki31 0K 16K CPU1 1 69.0H 94.09% idle: cpu1 14 root 171 ki31 0K 16K CPU4 4 65.1H 83.89% idle: cpu4 18 root 171 ki31 0K 16K CPU0 0 61.1H 83.06% idle: cpu0 16 root 171 ki31 0K 16K CPU2 2 61.6H 75.20% idle: cpu2 76727 root 43 - 0K 16K WAIT 0 291:12 10.99% em1_rx_kthread_2 76728 root 43 - 0K 16K WAIT 2 291:43 10.60% em1_rx_kthread_3 67 root 43 - 0K 16K WAIT 2 301:31 10.50% em1_rx_kthread_0 68 root 43 - 0K 16K WAIT 0 302:00 10.06% em1_rx_kthread_1 76662 root 43 - 0K 16K WAIT 0 248:41 8.59% em0_rx_kthread_3 76661 root 43 - 0K 16K WAIT 5 248:32 8.59% em0_rx_kthread_2 64 root 43 - 0K 16K WAIT 3 259:46 8.40% em0_rx_kthread_1 63 root 43 - 0K 16K WAIT 0 259:20 8.15% em0_rx_kthread_0 19 root -32 - 0K 16K WAIT 7 173:56 1.66% swi4: clock sio 72280 root 96 0 83240K 32568K select 6 31:30 0.20% mpd5 66 root -68 - 0K 16K WAIT 4 32:45 0.00% em1_txcleaner 62 root -68 - 0K 16K WAIT 4 19:23 0.00% em0_txcleaner 41 root 44 - 0K 16K - 2 4:32 0.00% yarrow 84 root 20 - 0K 16K syncer 4 1:22 0.00% syncer 79 root 8 - 0K 16K pftm 6 1:02 0.00% pfpurge 3452 root 44 0 5856K 1448K select 7 0:23 0.00% syslogd 5 root -68 - 0K 16K sleep 4 0:21 0.00% ng_queue3 7 root -68 - 0K 16K sleep 4 0:21 0.00% ng_queue5 3 root -68 - 0K 16K sleep 4 0:21 0.00% ng_queue1 4 root -68 - 0K 16K sleep 4 0:21 0.00% ng_queue2 9 root -68 - 0K 16K sleep 2 0:21 0.00% ng_queue7 8 root -68 - 0K 16K sleep 4 0:21 0.00% ng_queue6 packets errs bytes packets errs bytes colls 335185 0 209992823 254527 0 169373415 0 338935 0 214580075 255092 0 169751118 0 335443 0 211247010 254734 0 170707083 0 327842 0 205201850 247467 0 161428697 0 328424 0 205379409 246017 0 162671318 0 ifconfig |grep ng |wc -l 845 Вот теперь скажите мне wsimons, почему у меня процесс ng_queue совсем не грузит систему. Почему работают яндекс драйвера, и таки работают в классическом понимании SMP(а не в вашем) что я делаю не так?
  4. Пробуй обновиться до STABLE pf нат, или хоть чтото другое..только не то зло что у тебя P.S. У всех работает а у тебя нет, меняй прокладку (с)
  5. Надоело #echo >> /boot/loader.conf net.isr.maxthreads=8 net.isr.direct=0 net.isr.direct_force=0 net.inet.ip.intr_queue_maxlen=1024 net.route.netisr_maxqlen=1024 hw.em.rxd=4096 hw.em.txd=4096 #reboot Обновиться до STABLE ipnat заменить лучьше на pf
  6. Вот я и нашел причину своей проблемы, и даже не знаю радоваться или нет :) А обрадовал провайдинг как всегда торрент. И беда в том что и резать UDP не выход, жалеть нужно тот же скайп, онлайн игры, иначе хомячки разорвут техподдержку. Пока добавили еще один сервер. Будем думать что делать дальше. Но вопрос в другом, во сколько выростет pps через месяц-другой?:) Интересен опыт тех, кто еще держит акцесы на Freebsd какое количетво пакетов он сможет прожевать. У меня начались потери где-то при 400-450к. И поделитесь как с помощью мртж отрисовать pps с FreeDSD.
  7. :) а трафика сколько должен пророутить? Инет по дефалту или full view?
  8. а этот пипелац только на терминацию PPPoE, или еще и шейпинг с натом?:) Ну только на mpd 2 Гб хватит за глаза.
  9. Попробуйте передавать правила с УТМ с помощью радиус атрибутов, а не заворачивать ng_car через ipfw, тогда процесс nq-queue должен уйти в нули. Хотя при трафике в 100 Мб должно и так работать, если не сильно накручено с правилами.
  10. На таких аппаратных мощностях только фри или линузе, и правила в ручную вбивать Можно пробовать Абилс ставить, но модули на вебманю стоят денег.
  11. С консоли самого клиента DC 1) !modplug lua -a1 ---- Добавь плагин в автозагрузку 2) !onplug lua --- включение плагина 3) !lstplug --- список плагинов потом !luaload /usr/local/etc/verlihub/scripts/xxx.lua -- путь к скрипту
  12. Если оба аплинка отдают вам полные таблицы то вообще проблем нет, все решается через local preference.
