Товарищи подскажите как мне настроить cisco 3500XL, для того чтобы она пропускала все вланы выше 1005, а то ругается:
Command rejected: Bad VLAN list - character #9 (EOL) delimits a VLAN
number (1100) out of the range 1 to 1005.
возможно ли это в ней вообще?
конфиг:
GigaCisco-SW2#show running-config
Building configuration...
Current configuration:
version 12.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname GigaCisco-SW2
logging buffered 16384 debugging
logging console errors
logging monitor errors
aaa new-model
aaa authentication password-prompt "password: "
aaa authentication username-prompt "login: "
aaa authentication login default local
aaa authentication enable default enable
enable secret 5 [clean]
username max privilege 15 password 7 [clean]
username admin privilege 15 password 7 [clean]
clock timezone MSK 3
ip subnet-zero
no ip domain-lookup
interface GigabitEthernet0/1
duplex full
no flowcontrol
no negotiation auto
switchport trunk encapsulation dot1q
switchport trunk native vlan 1000
switchport trunk allowed vlan 1,2,1002-1005
switchport mode trunk
interface GigabitEthernet0/2
duplex full
no flowcontrol
no negotiation auto
interface GigabitEthernet0/3
duplex full
no flowcontrol
no negotiation auto
interface GigabitEthernet0/4
duplex full
no flowcontrol
no negotiation auto
interface GigabitEthernet0/5
duplex full
no flowcontrol
no negotiation auto
interface GigabitEthernet0/6
duplex full
no flowcontrol
no negotiation auto
interface GigabitEthernet0/7
duplex full
no flowcontrol
no negotiation auto
interface GigabitEthernet0/8
duplex full
no flowcontrol
no negotiation auto
interface VLAN1
no ip address
no ip directed-broadcast
no ip route-cache
shutdown
interface VLAN2
ip address 10.100.10.51 255.255.255.0
no ip route-cache
snmp-server engineID local 000000090200000785A40240
snmp-server community private RW
snmp-server community public RO
banner login ^C3DAPOBA TOPMO3!!!
UNAUTHORIZED ACCESS TO THIS DEVICE IS PROHIBITED
You must have explicit, authorized permission to access
or configure this device. Unauthorized attempts and
actions to access or use this system may result in civil
and/or criminal penalties. All activities performed on
this device are logged and monitored.
^C
line con 0
transport input none
stopbits 1
line vty 0 4
password 7 [clean]
line vty 5 15
password 7 [clean]
end
GigaCisco-SW2#
А
switchport trunk allowed vlan all
поможет? чтоб работал как хаб.
и
switchport trunk native vlan 2
чтобы управлять к примеру во втором влане? Edited by iMax
