shicoy Posted September 8, 2009 Posted September 8, 2009 # ifconfig eth0 eth0 Link encap:Ethernet HWaddr 00:30:48:5a:f2:6f inet addr:192.168.10.1 Bcast:192.168.255.7 Mask:255.255.255.248 inet6 addr: fe80::230:48ff:fe5a:f26f/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:2969654960 errors:0 dropped:172102 overruns:0 frame:0 TX packets:772760058 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:4000 RX bytes:533648381 (508.9 MiB) TX bytes:3848901318 (3.5 GiB) Base address:0x6000 Memory:ed400000-ed420000 # ethtool -g eth0 Ring parameters for eth0: Pre-set maximums: RX: 4096 RX Mini: 0 RX Jumbo: 0 TX: 4096 Current hardware settings: RX: 1024 RX Mini: 0 RX Jumbo: 0 TX: 1024 Cpu0 : 0.1%us, 0.0%sy, 0.0%ni, 61.1%id, 0.1%wa, 8.5%hi, 30.1%si, 0.0%st Cpu1 : 0.2%us, 0.1%sy, 0.0%ni, 98.7%id, 0.8%wa, 0.0%hi, 0.2%si, 0.0%st как посмотреть более детально из-за чего дропы пакетов идут? Вставить ник Quote
nuclearcat Posted September 8, 2009 Posted September 8, 2009 ethtool -S eth0 netstat -s На всякий случай, TX тоже проверять надо tc -s qdisc show Вставить ник Quote
shicoy Posted September 8, 2009 Author Posted September 8, 2009 ethtool -S eth0netstat -s На всякий случай, TX тоже проверять надо tc -s qdisc show # ethtool -S eth0 NIC statistics: rx_packets: 234262147207 tx_packets: 235979084334 rx_bytes: 164193382879966 tx_bytes: 129982113205169 rx_broadcast: 3031721 tx_broadcast: 4250 rx_multicast: 0 tx_multicast: 6 rx_errors: 0 tx_errors: 0 tx_dropped: 0 multicast: 0 collisions: 0 rx_length_errors: 0 rx_over_errors: 0 rx_crc_errors: 0 rx_frame_errors: 0 rx_no_buffer_count: 11700820 rx_missed_errors: 2930048 tx_aborted_errors: 0 tx_carrier_errors: 0 tx_fifo_errors: 0 tx_heartbeat_errors: 0 tx_window_errors: 0 tx_abort_late_coll: 0 tx_deferred_ok: 0 tx_single_coll_ok: 0 tx_multi_coll_ok: 0 tx_timeout_count: 0 tx_restart_queue: 80004 rx_long_length_errors: 0 rx_short_length_errors: 0 rx_align_errors: 0 tx_tcp_seg_good: 1841 tx_tcp_seg_failed: 0 rx_flow_control_xon: 0 rx_flow_control_xoff: 0 tx_flow_control_xon: 0 tx_flow_control_xoff: 0 rx_long_byte_count: 164193382879966 rx_csum_offload_good: 232556756524 rx_csum_offload_errors: 21424807 rx_header_split: 0 alloc_rx_buff_failed: 0 tx_smbus: 0 rx_smbus: 3040041 dropped_smbus: 0 Ip: 1187991187 total packets received 89278222 with invalid headers 5376 with invalid addresses 2472809580 forwarded 3207 with unknown protocol 0 incoming packets discarded 2526898068 incoming packets delivered 672891762 requests sent out 1143 outgoing packets dropped 2767018 fragments dropped after timeout 731955318 reassemblies required 350138269 packets reassembled ok 5637962 packet reassembles failed 25812221 fragments received ok 417 fragments failed 72833849 fragments created Tcp: 258821 active connections openings 13806939 passive connection openings 46344 failed connection attempts 2124304 connection resets received 6 connections established 569277148 segments received 522670647 segments send out 1366938 segments retransmited 8009837 bad segments received. 473666086 resets sent Udp: 1913708 packets received 1905362210 packets to unknown port received. 193663 packet receive errors 1917451 packets sent UdpLite: TcpExt: 46203 resets received for embryonic SYN_RECV sockets 29 packets pruned from receive queue because of socket buffer overrun 155 ICMP packets dropped because they were out-of-window 359063 TCP sockets finished time wait in fast timer 25 time wait sockets recycled by time stamp 240 packets rejects in established connections because of timestamp 3256784 delayed acks sent 148 delayed acks further delayed because of locked socket Quick ack mode was activated 24007 times 1462 times the listen queue of a socket overflowed 1462 SYNs to LISTEN sockets dropped 1617069 packets directly queued to recvmsg prequeue. 2872 bytes directly in process context from backlog 756117 bytes directly received in process context from prequeue 4099644 packet headers predicted 84 packets header predicted and directly queued to user 15936921 acknowledgments not containing data payload received 3361077 predicted acknowledgments 261 times recovered from packet loss by selective acknowledgements 18 congestion windows recovered without slow start by DSACK 6289 congestion windows recovered without slow start after partial ack 105 TCP data loss events 254 timeouts after reno fast retransmit 2044 timeouts after SACK recovery 60 timeouts in loss state 801 fast retransmits 25 forward retransmits 212 retransmits in slow start 332065 other TCP timeouts 10 SACK retransmits failed 7215 packets collapsed in receive queue due to low socket buffer 23923 DSACKs sent for old packets 13 DSACKs sent for out of order packets 20964 DSACKs received 9574596 connections reset due to unexpected data 2076456 connections reset due to early user close 3928 connections aborted due to timeout TCPDSACKIgnoredOld: 6720 TCPDSACKIgnoredNoUndo: 5293 IpExt: InTruncatedPkts: 1 InMcastPkts: 25594819 OutMcastPkts: 8287570 InBcastPkts: 62 шейпера нет. Я так понимаю проблема похоже с переполнением буфера в TCP стеке? Если не так, поправте. Вставить ник Quote
nuclearcat Posted September 8, 2009 Posted September 8, 2009 ethtool -G eth0 rx 2048 а потом и 4096 Сервер не тянет, перегружен скорее всего или шейперными или правилами firewall. Или еще чем-то "ядерным". Вставить ник Quote
