V1talya Posted August 24, 2009 Posted August 24, 2009 (edited) Очень плохо соединяется Dlink 2500U_C с pptpd сервером, из 20-30 попыток удачных может быть 1-2, windows клиенты подключаются без проблем. Device Info BoardID: DSL-2500U Software Version: RU_1.21 Bootloader (CFE) Version: 1.0.37-12.1 прошивки пробовал рызные вот что пишется в логах pptpd: ... Aug 24 16:57:43 gw-01 pptpd[3905]: CTRL: Client 192.168.189.12 control connection finished Aug 24 16:57:43 gw-01 pptpd[3915]: CTRL: Client 192.168.189.12 control connection started Aug 24 16:57:44 gw-01 pptpd[3915]: CTRL: Starting call (launching pppd, opening GRE) Aug 24 16:57:44 gw-01 pppd[3916]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded. Aug 24 16:57:44 gw-01 pppd[3916]: pptpd-logwtmp: $Version$ Aug 24 16:57:44 gw-01 pppd[3916]: pppd 2.4.4 started by root, uid 0 Aug 24 16:57:44 gw-01 pppd[3916]: using channel 32 Aug 24 16:57:44 gw-01 pppd[3916]: Using interface ppp1 Aug 24 16:57:44 gw-01 pppd[3916]: Connect: ppp1 <--> /dev/pts/1 Aug 24 16:57:44 gw-01 pppd[3916]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x5d8af299> <pcomp> <accomp>] Aug 24 16:57:44 gw-01 pppd[3916]: rcvd [LCP ConfReq id=0x9 <asyncmap 0x0> <magic 0x819e49ea> <pcomp> <accomp>] Aug 24 16:57:44 gw-01 pppd[3916]: sent [LCP ConfAck id=0x9 <asyncmap 0x0> <magic 0x819e49ea> <pcomp> <accomp>] Aug 24 16:57:47 gw-01 pppd[3916]: rcvd [LCP ConfReq id=0x9 <asyncmap 0x0> <magic 0x819e49ea> <pcomp> <accomp>] Aug 24 16:57:47 gw-01 pppd[3916]: sent [LCP ConfAck id=0x9 <asyncmap 0x0> <magic 0x819e49ea> <pcomp> <accomp>] Aug 24 16:57:47 gw-01 pppd[3916]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x5d8af299> <pcomp> <accomp>] Aug 24 16:57:50 gw-01 pppd[3916]: rcvd [LCP ConfReq id=0x9 <asyncmap 0x0> <magic 0x819e49ea> <pcomp> <accomp>] Aug 24 16:57:50 gw-01 pppd[3916]: sent [LCP ConfAck id=0x9 <asyncmap 0x0> <magic 0x819e49ea> <pcomp> <accomp>] Aug 24 16:57:50 gw-01 pppd[3916]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x5d8af299> <pcomp> <accomp>] Aug 24 16:57:53 gw-01 pptpd[3915]: CTRL: Reaping child PPP[3916] Aug 24 16:57:53 gw-01 pppd[3916]: Modem hangup Aug 24 16:57:53 gw-01 pppd[3916]: Connection terminated. Aug 24 16:57:53 gw-01 pppd[3916]: Exit. Aug 24 16:57:53 gw-01 pptpd[3915]: CTRL: Client 192.168.189.12 control connection finished Aug 24 16:57:53 gw-01 pptpd[3925]: CTRL: Client 192.168.189.12 control connection started Aug 24 16:57:54 gw-01 pptpd[3925]: CTRL: Starting call (launching pppd, opening GRE) Aug 24 16:57:54 gw-01 pppd[3926]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded. Aug 24 16:57:54 gw-01 pppd[3926]: pptpd-logwtmp: $Version$ Aug 24 16:57:54 gw-01 pppd[3926]: pppd 2.4.4 started by root, uid 0 Aug 24 16:57:54 gw-01 pppd[3926]: using channel 33 Aug 24 16:57:54 gw-01 pppd[3926]: Using interface ppp1 Aug 24 16:57:54 gw-01 pppd[3926]: Connect: ppp1 <--> /dev/pts/1 Aug 24 16:57:54 gw-01 pppd[3926]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0xebc3885f> <pcomp> <accomp>] Aug 24 16:57:54 gw-01 pppd[3926]: rcvd [LCP ConfReq id=0xa <asyncmap 0x0> <magic 0x1d25c939> <pcomp> <accomp>] Aug 24 16:57:54 gw-01 pppd[3926]: sent [LCP ConfAck id=0xa <asyncmap 0x0> <magic 0x1d25c939> <pcomp> <accomp>] Aug 24 16:57:57 gw-01 pppd[3926]: rcvd [LCP ConfReq id=0xa <asyncmap 0x0> <magic 0x1d25c939> <pcomp> <accomp>] Aug 24 16:57:57 gw-01 pppd[3926]: sent [LCP ConfAck id=0xa <asyncmap 0x0> <magic 0x1d25c939> <pcomp> <accomp>] Aug 24 16:57:57 gw-01 pppd[3926]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0xebc3885f> <pcomp> <accomp>] Aug 24 16:58:00 gw-01 pppd[3926]: rcvd [LCP ConfReq id=0xa <asyncmap 0x0> <magic 0x1d25c939> <pcomp> <accomp>] Aug 24 16:58:00 gw-01 pppd[3926]: sent [LCP ConfAck id=0xa <asyncmap 0x0> <magic 0x1d25c939> <pcomp> <accomp>] Aug 24 16:58:00 gw-01 pppd[3926]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0xebc3885f> <pcomp> <accomp>] Aug 24 16:58:03 gw-01 pptpd[3925]: CTRL: Reaping child PPP[3926] Aug 24 16:58:03 gw-01 pppd[3926]: Modem hangup Aug 24 16:58:03 gw-01 pppd[3926]: Connection terminated. Aug 24 16:58:03 gw-01 pppd[3926]: Exit. Aug 24 16:58:03 gw-01 pptpd[3925]: CTRL: Client 192.168.189.12 control connection finished ... 10 а то и 15 попыток и результат есть: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded. pptpd-logwtmp: $Version$ using channel 34 Using interface ppp1 Connect: ppp1 <--> /dev/pts/1 sent [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x6bff9227> <pcomp> <accomp>] rcvd [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x93873205> <pcomp> <accomp>] sent [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x93873205> <pcomp> <accomp>] rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x6bff9227> <pcomp> <accomp>] sent [LCP EchoReq id=0x0 magic=0x6bff9227] sent [CHAP Challenge id=0x70 <4b5d45e0358c4bd04d12783d6af031b1bf45bc5372ea>, name = "pptpd"] rcvd [LCP EchoRep id=0x0 magic=0x93873205] rcvd [CHAP Response id=0x70 <b7f238e94f2a48a605daced9160af4a1>, name = "extra0"] sent [CHAP Success id=0x70 "Access granted"] sent [IPCP ConfReq id=0x1 <addr 10ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>] sent [IPCP ConfRej id=0x1 <compress VJ 0f 01>] rcvd [IPCP ConfAck id=0x1 <addr 10.250.250.1>] rcvd [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>] sent [IPCP ConfNak id=0x2 <addr 10.250.250.102> <ms-dns1 10.250.250.1> <ms-dns3 10.250.250.1>] rcvd [IPCP ConfReq id=0x3 <addr 10.250.250.102> <ms-dns1 10.250.250.1> <ms-dns3 10.250.250.1>] sent [IPCP ConfAck id=0x3 <addr 10.250.250.102> <ms-dns1 10.250.250.1> <ms-dns3 10.250.250.1>] Cannot determine ethernet address for proxy ARP local IP address 10.250.250.1 remote IP address 10.250.250.102 pptpd-logwtmp.so ip-up ppp1 extra0 192.168.189.12 Script /etc/ppp/ip-up started (pid 4335) Script /etc/ppp/ip-up finished (pid 4335), status = 0x0 Как можно решить проблему ? ( выкинуть длинк не предлагать :) ) Edited August 24, 2009 by V1talya Вставить ник Quote
V1talya Posted August 24, 2009 Author Posted August 24, 2009 (edited) Нашел вот что: 20:47:55.981357 IP xxxx > 192.168.189.47: GREv1, call 3072, seq 36, length 1480: IP truncated-ip - 33 bytes missing! Кто знает с чем это связанно ? и как лечить ? и может из-за этого не устанавливаться впн соединение между длинком и линукс сервером ? Edited August 24, 2009 by V1talya Вставить ник Quote
Ivan_83 Posted August 24, 2009 Posted August 24, 2009 У меня были похожие проблемы только на Acorp LAN422, тоже pptp не хотел цепляться к freebsd+mpd5, к windows2003+rras цеплялся, но работал с лагами. Проблема где то в прошивке, он в логи постоянно пишет что пакеты потерялись. В вашем случае я бы попробовал уменьшить MTU до 1400 в pppoe подключении или через чего вы пытаетесь законектится. Вставить ник Quote
sfstudio Posted August 24, 2009 Posted August 24, 2009 Со стороны модема логи бы глянуть. Вставить ник Quote
