Структура следующая:
CE1[10.250.0.249/30] -- PE11[10.255.3.1] ---- MPLS CORE ---- PE22[10.255.1.114] -- [10.142.27.73/30]CE1
PE11:
Код
ip vrf vpn1
rd 100:110
route-target export 100:1000
route-target import 100:1000
interface Loopback0
ip vrf forwarding vpn1
ip address 10.142.27.73 255.255.255.252
end
router bgp 100
no synchronization
bgp log-neighbor-changes
neighbor 10.255.3.1 remote-as 100
no auto-summary
address-family vpnv4
neighbor 10.255.3.1 activate
neighbor 10.255.3.1 send-community both
neighbor 10.255.3.1 next-hop-self
neighbor 10.255.3.1 distribute-list default out
exit-address-family
address-family ipv4 vrf vpn1
redistribute connected
redistribute static
no synchronization
exit-address-family
ip prefix-list default: 2 entries
seq 5 permit 0.0.0.0/0
seq 10 permit 10.142.27.72/29
Сеть СЕ1 видим:
Цитата
sh ip bgp vpnv4 vrf vpn1
BGP table version is 5, local router ID is 10.142.16.114
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 100:110 (default for vrf vpn1)
*>i10.250.0.248/30 10.255.3.1 0 100 0 ?
*> 10.142.27.72/30 0.0.0.0 0 32768 ?
PE22:
Код
ip vrf vpn1
rd 100:110
router bgp 100
no synchronization
neighbor 10.255.1.114 remote-as 100
no auto-summary
neighbor 10.255.1.114 activate
neighbor 10.255.1.114 send-community both
exit-address-family
no synchronization
exit-address-family
interface GigabitEthernet4/2
description test-stand
ip address 10.250.0.250 255.255.255.252
wrr-queue random-detect min-threshold 1 70 70
wrr-queue random-detect min-threshold 2 70 70
wrr-queue random-detect max-threshold 1 100 100
wrr-queue random-detect max-threshold 2 100 100
wrr-queue cos-map 2 1 4 6 7
rcv-queue threshold 1 70 100
rcv-queue cos-map 1 1 0 1 2 3 4 6 7
rcv-queue cos-map 1 2 5
mls qos trust cos
end
И тут видим:
BGP table version is 23, local router ID is 10.255.3.1
*> 10.250.0.248/30 0.0.0.0 0 32768 ?
*>i10.142.27.72/30 10.255.1.114 0 100 0 ?
По лдп связность видна:
Цитата
sh mpls ldp neighbor 10.255.3.1
Peer TDP Ident: 10.255.3.1:0; Local TDP Ident 10.255.1.114:0
TCP connection: 10.255.3.1.16209 - 10.255.1.114.711
State: Oper; PIEs sent/rcvd: 0/292; Downstream
Up time: 04:03:20
TDP discovery sources:
Directed Hello 10.255.1.114 -> 10.255.3.1, active, passive
Addresses bound to peer TDP Ident:
10.250.0.13 10.7.37.33 10.142.22.33 10.7.32.1
10.7.33.1 10.7.34.1 10.7.35.1 10.7.36.1
10.7.34.65 10.255.3.1 10.7.37.1
А вот пакеты не ходят:
Цитата
PE11#ping vrf vpn1 10.142.27.73
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 79.142.27.73, timeout is 2 seconds:
Success rate is 0 percent (0/5)
PE11#ping vrf vpn1 10.250.0.249
Sending 5, 100-byte ICMP Echos to 10.250.0.249, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
Помогите, пожалуйста разобраться!
Edited by chainick
А что за подсеть 79.142.27.73в vrf vpn1 ? И почему ее нет в таблице ?
Считаем, что это сеть 10.142.27.73, не хотел светить реальные адреса, но спалился :)
Так какая разница, ведь метки RT ведь с обеих сторон одинаковые, я правильно понимаю?
У меня есть еще подозрение, что трафик с РЕ1 уходит не в тот канал, где находится РЕ2. Пытаюсь это проверить так:
#traceroute mpls ipv4 10.142.27.73/32
Tracing MPLS Label Switched Path to 10.142.27.73/32, timeout is 2 seconds
Codes: '!' - success, 'Q' - request not transmitted,
'.' - timeout, 'U' - unreachable,
'R' - downstream router but not target,
'M' - malformed request
Q 1 *
Может быть причина в этом?
show ip cef <loopback PE>/32 internal
#sh ip cef 10.142.27.73 internal
0.0.0.0/0, epoch 5, RIB, refcount 7, per-destination sharing
sources: RIB, D/N, DRH
feature space:
LFD: 0.0.0.0/0 0 local labels
contains path extension list
label switch chain 0x47363978
IPRM: 0x00028000
Broker: linked
subblocks:
DefNet source: 0.0.0.0/0
ifnums:
GigabitEthernet5/1(340): 10.250.0.14
path 50F90138, path list 50F8A9E0, share 1/1, type attached nexthop, for IPv4
MPLS short path extensions: MOI flags = 0x0 label implicit-null
nexthop 10.250.0.14 GigabitEthernet5/1, adjacency IP adj out of GigabitEthernet5/1, addr 10.250.0.14 46764C40
output chain: IP adj out of GigabitEthernet5/1, addr 10.250.0.14 46764C40
Задал еще один вопрос, чтобы не плодить темы.
С предыдущим вопросом разобрался. Теперь появился вопрос - предположим, у меня есть впн, клиент живет в своем vrf, впн работает. Теперь клиент хочет интернет. Насколько я правильно понимаю, для этого я анонсирую сеть клиентского vrf в свою глобальную таблицу.
Но, соответственно, клиент начинает видеть и мою сеть! А мне этого не хочется, зачем он мне тут нужен?
