прошу помощи в настройке bdcom P3608
BDCOM(tm) P3608B Software, Version 10.1.0F Build 88803
С устройства epon0/1:1 (001f.167b.3563) нет пинга к микротику(10.45.0.1-vlan100, 10.45.1.1-vlan2300).
С консоли BDCOM пинг к микротику(10.45.0.1-vlan100, 10.45.1.1-vlan2300) есть.
MKO-OLT01#show running-config
Building configuration...
Current configuration:
!version 10.1.0F build 88803
service timestamps log date
service timestamps debug date
service password-encryption
logging buffered 4096
hostname MKO-OLT01
port-protected 1
spanning-tree mode rstp
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username admin password 7 0822462c46311d15245b
enable password 7 0822462c46311d15245b level 15
epon oam-version 1 0x30
epon oam-version 2 0x21
epon oam-version 3 0x20
epon onu-config-template user1
 cmd-sequence 001 epon onu port 1 ctc vlan mode tag 2300
 cmd-sequence 002 epon onu port 1 ctc loopback detect
 cmd-sequence 003 epon onu port 2 ctc vlan mode tag 2300
 cmd-sequence 004 epon onu port 2 ctc loopback detect
 cmd-sequence 005 epon onu port 3 ctc vlan mode tag 2300
 cmd-sequence 006 epon onu port 3 ctc loopback detect
 cmd-sequence 007 epon onu port 4 ctc vlan mode tag 2300
 cmd-sequence 008 epon onu port 4 ctc loopback detect
 cmd-sequence 009 loopback-detection recovery-time 7200
interface Null0
interface FastEthernet0/0
 no ip address
 no ip directed-broadcast
!!slot 0 1 unknow CARD
interface GigaEthernet0/1
 shutdown
 switchport trunk vlan-allowed 2-4094
 switchport mode dot1q-tunnel-uplink
interface GigaEthernet0/2
 shutdown
interface GigaEthernet0/3
 shutdown
interface GigaEthernet0/4
 shutdown
interface GigaEthernet0/5
 shutdown
interface GigaEthernet0/6
 shutdown
interface GigaEthernet0/7
 shutdown
interface GigaEthernet0/8
 description UPLINK
 switchport trunk vlan-allowed 1,100,2300-2302
 dhcp snooping trust
interface TGigaEthernet0/1
 shutdown
interface TGigaEthernet0/2
 shutdown
interface EPON0/1
 description user_PPPoE
 epon pre-config-template user1 binded-onu-llid 1-64
 epon bind-onu mac 70a5.6a1a.03b8 1
 filter bpdu
 filter dhcp
 switchport trunk vlan-allowed 2300
 switchport trunk vlan-untagged none
 switchport mode trunk
 switchport protected 1
interface EPON0/1:1
  epon onu port 1 ctc vlan mode tag 2300 priority 0
interface EPON0/2
 filter bpdu
 filter dhcp
interface EPON0/3
 filter bpdu
 filter dhcp
interface EPON0/4
 filter bpdu
 filter dhcp
interface EPON0/5
 shutdown
interface EPON0/6
 shutdown
interface EPON0/7
 shutdown
interface EPON0/8
 shutdown
!!slot end
interface VLAN100
 description management
 ip address 10.45.0.2 255.255.255.0
dot1q-tunnel
vlan 100
 name MANAGEMENT
vlan 2300
 name GEPON_ports_1-4
vlan 2301
 name GEPON_ports_5-8
vlan 2302
 name FTTH
vlan 1,100,2300-2302
ip route default 10.45.0.1
ip exf
ipv6 exf
ip http server
ip sshd enable
time-zone Yekaterinburd 5 0
ntp query-interval 3600
ntp server 10.45.0.1
!Pending configurations for absent linecards:
!No configurations pending global
Vlan    Mac Address       Type       Ports
1       b869.f48d.4578    DYNAMIC    g0/8
100     b869.f48d.4578    DYNAMIC    g0/8
2301    b869.f48d.4578    DYNAMIC    g0/8
2300    b869.f48d.4578    DYNAMIC    g0/8
2302    b869.f48d.4578    DYNAMIC    g0/8
2300    001f.167b.3563    DYNAMIC    epon0/1:1
Edited by scfx
38 минут назад, scfx сказал:
 description UPLINK
 dhcp snooping trust
Первоначально так и делал, вместо
делал
Но в этом случае микротик видит bdcom только на 1 pvid
