На узле агрегации(snr2995) и на l2 свичах за ним настроен mstp. На одном из свичей(SNR-S2985G-24T-UPS), судя по логам постоянно перестаивается топология, в логах имеем:
2231 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10
2230 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 5
2229 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10
2228 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 4
2227 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10
2226 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 3
2225 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10
2224 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 1
2223 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:CistRoot = 24576.f8:f0:82:78:72:80, CistRegRoot = 24576.f8:f0:82:78:72:80
2222 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE=0
2221 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0
2220 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 5
2219 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0
2218 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 4
2217 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0
2216 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 3
2215 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0
2214 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 1
2213 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:CistRoot = 32768.f8:f0:82:78:08:b7, CistRegRoot = 32768.f8:f0:82:78:08:b7
2212 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE=0
За свичем на котором постоянно происходит изменение рута включено еще несколько свичей каскадом, соответственно на них также по логам идет перестроение.
Схема следующая:
L3 (3порт)----(8порт)snr2985-8(10порт)----(28порт)SNR-S2985G-24T-UPS -- с этого свича c  23 по 27 порт идут еще свичи друг за другом.
На L3 специально понижен приоритет до 24576  для всех интансов.
Настройки mstp на всех свичах одинаковые, при перестроение порт между snr2985-8 и SNR-S2985G-24T-UPS не падает.
В чем может быть проблема, почему каждые 20-40 секунд SNR-S2985G-24T-UPS делает себя рутом и сразу же перестраивает что рут за 28 портом?
Конфигурация stp:
spanning-tree mst configuration
 name ru.fcomm
 revision-level 1
 instance 1 vlan 1-79
 instance 2 vlan 80-95;130-150
 instance 3 vlan 96-110;112;114;151-199
 instance 4 vlan 200-699
 instance 5 vlan 700-799
 instance 6 vlan 800-4094
 instance 7 vlan 111;113;115;117-121;124-129
 instance 8 vlan 116
 instance 9 vlan 122
 instance 10 vlan 123
 exit
spanning-tree
Свич:
SNR-S2985G-24T-UPS Device, Compiled on Nov 28 13:19:04 2018
  CPU Mac f8:f0:82:78:08:b7
  Vlan MAC f8:f0:82:78:08:b6
  SoftWare Version 7.0.3.5(R0241.0283)
  BootRom Version 7.2.40
  HardWare Version 1.0.1
  CPLD Version N/A
  Serial No.:SW071010H923001066
  Copyright (C) 2018 NAG LLC
  All rights reserved
  Last reboot is cold reset.
  Uptime is 0 weeks, 1 days, 20 hours, 52 minutes
Edited by marsh
  • 3 weeks later...
Добрый день!
Такая же проблема, аггрегатор SNR-S2985G-24T-UPS (root), mstp, кольцо собрано из SNR-S2985G-8T, общее количество коммутаторов в кольце 8 шт.
на третьем "hop" коммутатор начинает на 3 секунды назначать себя root и обратно.
Bridge Times :  Max Age 20, Hello Time 2, Forward Delay 15
SNR-S2985G-8T Device, Compiled on Jan 23 14:49:06 2017
SoftWare Version 7.0.3.5(R0241.0137)
BootRom Version 7.2.21
HardWare Version 1.1.2
CPLD Version N/A
Подскажите, в чем может проблема?
@Nurzhan Добрый день!
Обновите NOS и Bootrom, если проблема будет продолжаться - оставьте обращение на support.nag.ru - разберемся. У @marsh проблема исчезла после проблем с электропитанием на узле, к сожалению, мы не успели ее диагностировать.
