marsh
Новичок
  • Content Count
    2
  • Joined
  • Last visited
About marsh
  • Rank
    Абитуриент
  1. На узле агрегации(snr2995) и на l2 свичах за ним настроен mstp. На одном из свичей(SNR-S2985G-24T-UPS), судя по логам постоянно перестаивается топология, в логах имеем: 2231 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10 2230 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 5 2229 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10 2228 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 4 2227 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10 2226 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 3 2225 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 24576.f8:f0:82:78:72:80, DesgBridgeID = 32768.f8:f0:82:77:e0:93, DesgPortID = 128.10 2224 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 1 2223 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:CistRoot = 24576.f8:f0:82:78:72:80, CistRegRoot = 24576.f8:f0:82:78:72:80 2222 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE=0 2221 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0 2220 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 5 2219 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0 2218 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 4 2217 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0 2216 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 3 2215 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:MstiRegRoot = 32768.f8:f0:82:78:08:b7, DesgBridgeID = 32768.f8:f0:82:78:08:b7, DesgPortID = 0.0 2214 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE = 1 2213 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:CistRoot = 32768.f8:f0:82:78:08:b7, CistRegRoot = 32768.f8:f0:82:78:08:b7 2212 %May 04 16:47:40 2020 <warnings> MODULE_L2_MSTP[tMstp]:Root bridge has been changed. PRS is triggered: INSTANCE=0 За свичем на котором постоянно происходит изменение рута включено еще несколько свичей каскадом, соответственно на них также по логам идет перестроение. Схема следующая: L3 (3порт)----(8порт)snr2985-8(10порт)----(28порт)SNR-S2985G-24T-UPS -- с этого свича c 23 по 27 порт идут еще свичи друг за другом. На L3 специально понижен приоритет до 24576 для всех интансов. Настройки mstp на всех свичах одинаковые, при перестроение порт между snr2985-8 и SNR-S2985G-24T-UPS не падает. В чем может быть проблема, почему каждые 20-40 секунд SNR-S2985G-24T-UPS делает себя рутом и сразу же перестраивает что рут за 28 портом? Конфигурация stp: spanning-tree mst configuration name ru.fcomm revision-level 1 instance 1 vlan 1-79 instance 2 vlan 80-95;130-150 instance 3 vlan 96-110;112;114;151-199 instance 4 vlan 200-699 instance 5 vlan 700-799 instance 6 vlan 800-4094 instance 7 vlan 111;113;115;117-121;124-129 instance 8 vlan 116 instance 9 vlan 122 instance 10 vlan 123 exit ! spanning-tree Свич: SNR-S2985G-24T-UPS Device, Compiled on Nov 28 13:19:04 2018 CPU Mac f8:f0:82:78:08:b7 Vlan MAC f8:f0:82:78:08:b6 SoftWare Version 7.0.3.5(R0241.0283) BootRom Version 7.2.40 HardWare Version 1.0.1 CPLD Version N/A Serial No.:SW071010H923001066 Copyright (C) 2018 NAG LLC All rights reserved Last reboot is cold reset. Uptime is 0 weeks, 1 days, 20 hours, 52 minutes
  2. MIBы
    Здравствуйте. Есть у кого-нибудь опыт реализации связи данных по мощности сигнала(.1.3.6.1.4.1.3320.101.10.5.1.5) с портом для мониторинга в системе заббикс. Такие данные как трафик на порту вытягиваю при помощи динамических индексов, например ifOutOctets["index","ifDescr","EPON0/x"].
