Собственно - не делал никаких настроек на N3K, и данная серия считает пакеты и байты по int vlan
N3K-C3064PQ-10GE, NXOS: version 7.0(3)I7(8)
show interface vlan 700 counters
Port                                     InOctets                      InUcastPkts
Vlan700                           2956698475                          39089828
Port                                  InMcastPkts                      InBcastPkts
Vlan700                                   --                                --
Port                                    OutOctets                     OutUcastPkts
Vlan700                           7685312037                          49096076
Port                                 OutMcastPkts                     OutBcastPkts
Vlan700                                   --                                --
N9K-C93180YC-EX, NXOS: version 9.3(3)
show int vlan 700 counters
Vlan700                                         0                                0
Vlan700                                   --                                --
Vlan700                                         0                                0
Vlan700                                   --                                --
на N9K внутри int vlan нет параметр counters (и на n3k тоже нет)
Вопрос - как включить счетчики на n9k
Edited by artplanet
Печаль тоска
hardware access-list tcam region ?
  egr-cntacl          Egress CNTACL
  egr-copp            Egress copp Tcam region size
  egr-l2-qos          Egress L2 QOS
  egr-l3-vlan-qos     Egress L3/VLAN QOS
  egr-racl            Egress RACL
  egr-sup             Egress SUP
  ing-cntacl          Egress CNTACL
  ing-flow-redirect   Egress region in ACX
  ing-fstat           Ingress FSTAT
  ing-ifacl           Ingress PACL
  ing-l2-qos          Ingress L2 QOS
  ing-l2-span-filter  Ingress L2 SPAN filter
  ing-l3-span-filter  Ingress L3 SPAN filter
  ing-l3-vlan-qos     Ingress L3/VLAN QOS
  ing-nbm             Ingress NBM
  ing-racl            Ingress RACL
  ing-rbacl           Ingress RBACL
  ing-redirect        Ingress Redirect
  ing-sup             Ingress SUP
  nat                 Ingress NAT
  span                SPAN
  tcp-nat             TCP NAT region within NAT region
  vacl                VACL
у меня нет svi
как и по команде
show system internal access-list globals   нет упоминаний о SVI
slot  1
  Atomic Update : ENABLED
  Default ACL   : DENY
  Bank Chaining : DISABLED
  Fabric path DNL : DISABLED
  NS Buffer Profile: Burst optimized
  Min Buffer Profile: all
  EOQ Class Stats: qos-group-0
  NS MCQ3 Alias: qos-group-3
  Ing PG Share: ENABLED
  IPG in Shape: DISABLED
  Classify ns-only : DISABLED
  Ing PG Min: NOT-DISABLED
  Ing PG Headroom reservation: 100
  OQ Drops Type: both
  OQ Stats Type:   [c1]: q 1 both
  [c2]: q 2 both
  [c3]: q 3 both
  [c4]: q 4 both
  [c5]: q 5 both
  [c6]: q 6 both
  [c7]: q 7 both
  [c8]: q 8 both
  [c9]: q 9 both
  peak count type: port
  counter 0 classes: 255
  counter 1 classes: 0
  OOBST Max records: 1000
  DPP Aging Period: 5000
  DPP Max Number of Packets: 120
  AFD ETRAP Aging Period: 50
  AFD ETRAP Byte Count: 1048555
  AFD ETRAP Bandwidth Threshold: 500
  ACL Inner Header Match : DISABLED
  VXLAN OAM Dynamic Entry Move: TRUE
  VXLAN XConnect ACL Programmed: FALSE
  DOT1X Entry Move: TRUE
  DOT1X Entry ACL Programmed: TRUE
  DOT1X Multi Auth ACL Entry Programmed: FALSE
  Multicast NLB enabled: FALSE
  TCAM Template Initialised: TRUE
  LOU Threshold Value : 5
                 INSTANCE 0 TCAM Region Information:
Ingress:
                    Region          TID     Base     Size     Width
                         NAT         13        0        0         1
                Ingress PACL          1        0        0         1
                Ingress VACL          2        0        0         1
                Ingress RACL          3        0     2304         1
               Ingress RBACL          4        0        0         1
              Ingress L2 QOS          5     2304      256         1
         Ingress L3/VLAN QOS          6     2560      512         1
                 Ingress SUP          7     3072      512         1
         Ingress L2 SPAN ACL          8     3584      256         1
    Ingress L3/VLAN SPAN ACL          9     3840      256         1
               Ingress FSTAT         10        0        0         1
                        SPAN         12     4096      512         1
            Ingress REDIRECT         14        0        0         1
Netflow/Analytics Filter TCAM         21     4608      512         1
                 Ingress NBM         30        0        0         1
       Ingress Flow-redirect         39        0        0         1
           Ingress RACL Lite         42        0        0         1
      Ingress PACL IPv4 Lite         41        0        0         1
      Ingress PACL IPv6 Lite         43        0        0         1
              Ingress CNTACL         44        0        0         1
Total configured size: 5120
Remaining free size: 0
Note: Ingress SUP region includes Redirect region
Egress:
                 Egress VACL         15        0        0         1
                 Egress RACL         16        0     1792         1
               Egress CNTACL         17        0        0         1
                  Egress SUP         18     1792      256         1
               Egress L2 QOS         19        0        0         1
          Egress L3/VLAN QOS         20        0        0         1
                 Egress CoPP         37        0        0         1
               Egress CNTACL         45        0        0         1
Total configured size: 2048
“hardware profile svi flex-stats-enable” would enable only ingress unicast counters on the SVI. Egress or non-unicast counters will still not work due to hardware limitations. This knob also disables L2 VLAN egress counters.
CSCvk10357 is an enhancement request that hasn’t seen any movement in almost 2 years, unlikely to ever be resolved on this platform.
