Arsen1810 Posted October 8, 2019 Posted October 8, 2019 Добрый день! Подскажите в чем проблема, при обновлении прошивки на коммутаторе SNR-S2940-8G-v2 выдает ошибку: "error(Error:Type mismatching.)!" Обновится пытаюсь с : SoftWare Version 7.0.3.1(R0058.0002) BootRom Version 7.1.3 HardWare Version 1.0.1 CPLD Version 1.2 на : http://data.nag.ru/SNR Switches/Firmware/SNR-S2940-8G-v2/recommended/ Вставить ник Quote
Evgeny Mirhasanov Posted October 8, 2019 Posted October 8, 2019 Добрый день. Возможно у вас SNR-S2940-8G-v1. Какой вывод дает команда show vendor? Вставить ник Quote
Arsen1810 Posted October 8, 2019 Author Posted October 8, 2019 25 минут назад, Evgeny Mirhasanov сказал: Какой вывод дает команда show vendor? SNR-S2940-8G-v2#sh ver SNR-S2940-8G-v2 Device, Compiled on May 16 22:19:41 2013 sysLocation Ak.Vonsovskogo str. 1-118, Ekaterinburg, Russia CPU Mac f8:f0:82:10:24:37 Vlan MAC f8:f0:82:10:24:36 SoftWare Version 7.0.3.1(R0058.0002) BootRom Version 7.1.3 HardWare Version 1.0.1 CPLD Version 1.2 Serial No.:SW003710D712000714 Copyright (C) 2013 NAG LLC All rights reserved Last reboot is warm reset. Uptime is 0 weeks, 0 days, 19 hours, 55 minutes SNR-S2940-8G-v2#sh ven NAME LEN VALUE ------------ ----- ------------------------------ SwitchName 15 SNR-S2940-8G-v2 VersionPre 0 VendNameEn 7 NAG LLC VendNameBr 3 NAG VendWWW 18 http://shop.nag.ru VendLocate 47 Ak.Vonsovskogo str. 1-118, Ekaterinburg, Russia CopyRight 26 Copyright (C) 2013 NAG LLC VendContact 14 support@nag.ru WebLogo 10976 WebLogin 5597 WebFacebd 12701 WebBG 13495 WebLang 2 cn VendorOid 19 1.3.6.1.4.1.40418.7 DeviceOid 21 1.3.6.1.4.1.40418.7.2 KeyNeed 4 0 BaseMac 6 f8 f0 82 10 00 00 CliStyle 3 0 HsrpNeed 4 0 DevType(ID) 4 18 ChassisCard 0 FileVersion 7 10.5.75 IMGPrefix 0 RomPrefix 0 HardWarePre 0 Prompt 0 UserName 5 admin PassWord 5 admin ManageIP 4 10.10.10.1 SNR-S2940-8G-v2# Вставить ник Quote
Evgeny Mirhasanov Posted October 8, 2019 Posted October 8, 2019 Спасибо, у вас SNR-S2940-8G-v2. Попробуйте обновиться для начала до "промежуточной" версии. http://data.nag.ru/SNR Switches/Firmware/SNR-S2940-8G-v2/all/S2940-8G-v2_7.0.3.5(R0217.0140).zip Вставить ник Quote
Arsen1810 Posted October 8, 2019 Author Posted October 8, 2019 42 минуты назад, Evgeny Mirhasanov сказал: Попробуйте обновиться для начала до "промежуточной" версии. При этом мне boot.rom нужно обновлять, или же могу с версией BootRom Version 7.1.3 сразу переходить на промежуточную? Вставить ник Quote
Evgeny Mirhasanov Posted October 8, 2019 Posted October 8, 2019 7.1.3 уже является новейшим bootrom, т.ч. не нужно. Вставить ник Quote
Arsen1810 Posted October 8, 2019 Author Posted October 8, 2019 Понял, щас попробую! Вставить ник Quote
Arsen1810 Posted October 8, 2019 Author Posted October 8, 2019 Загрузилось с промежуточной. Дальше как я понял можно грузить ту прошивку которую указывал выше и загружаться с неё? При этом boot.rom который с прошивкой в архиве он новее 7,1,3 или такой же? Вставить ник Quote
Evgeny Mirhasanov Posted October 8, 2019 Posted October 8, 2019 Bootrom там тоже 7.1.3. Да, теперь попробуйте самую новую версию. Вставить ник Quote
Arsen1810 Posted October 8, 2019 Author Posted October 8, 2019 24 минуты назад, Evgeny Mirhasanov сказал: Да, теперь попробуйте самую новую версию. выдало такую же ошибку : File transfer complete. Recv total 6736931 bytes Begin to write local file, please wait... Write file "flash:/nos1.img" error(Error:Type mismatching.)! close tftp client. Вставить ник Quote
Evgeny Mirhasanov Posted October 8, 2019 Posted October 8, 2019 Вот самая новая версия ПО, точно будет работать: http://data.nag.ru/SNR Switches/Firmware/SNR-S2940-8G-v2/recommended/S2940-8G-v2_7.0.3.5(R0217.0175).zip Вставить ник Quote
Arsen1810 Posted October 8, 2019 Author Posted October 8, 2019 36 минут назад, Evgeny Mirhasanov сказал: Вот самая новая версия ПО, точно будет работать: Почему-то после обновления он показывают промежуточную версию : SoftWare Version 7.0.3.5(R0217.0140) BootRom Version 7.1.3 HardWare Version 1.0.1 CPLD Version 1.2 а не (R0217.0175) Вставить ник Quote
Evgeny Mirhasanov Posted October 9, 2019 Posted October 9, 2019 В привилегированном режиме введите команду show boot-files Скорее всего файл с новейшей прошивкой помечен сейчас как бэкап-образ. Запомните его название, и введите: boot img flash:/<имя файла>.img primary Затем перезагрузите коммутатор. Вставить ник Quote
Arsen1810 Posted October 9, 2019 Author Posted October 9, 2019 2 часа назад, Evgeny Mirhasanov сказал: Скорее всего файл с новейшей прошивкой помечен сейчас как бэкап-образ. SNR-S2940-8G-v2#show boot-files Booted files on switch The primary img file at the next boot time: flash:/nos1.img The backup img file at the next boot time: flash:/nos.img Current booted img file: flash:/nos1.img The startup-config file at the next boot time: flash:/startup.cfg Current booted startup-config file: flash:/startup.cfg Прежде чем перегрузить после загрузки нового ПО я вбил команду: "boot img nos1.img primary" "nos1.img"- это новая прошивка, а backup я выставил которая там уже была "nos.img" на всякий если вдруг не запустится с новой прошивкой. Разве не так делается? Вставить ник Quote
Evgeny Mirhasanov Posted October 10, 2019 Posted October 10, 2019 Добрый день. Заметил, что вы удалили свой последний комментарий. В итоге успешно обновили ПО? Вставить ник Quote
Arvest Posted December 12, 2019 Posted December 12, 2019 On 10/8/2019 at 10:21 PM, Evgeny Mirhasanov said: Вот самая новая версия ПО, точно будет работать: http://data.nag.ru/SNR Switches/Firmware/SNR-S2940-8G-v2/recommended/S2940-8G-v2_7.0.3.5(R0217.0175).zip Здравствуйте. Скажите, где посмотреть список изменений этой версии? Файл во вложении заканчивается на 158. Вставить ник Quote
Evgeny Mirhasanov Posted December 12, 2019 Posted December 12, 2019 31 minutes ago, Arvest said: Здравствуйте. Скажите, где посмотреть список изменений этой версии? Файл во вложении заканчивается на 158. Добрый день. Перезалили ПО на сервер, теперь changelog корректный. Также продублирую сюда: 7.0.3.5(R0217.0175) FIX|MT8316 DHCP Snooping intersepts PXE BINL packets 7.0.3.5(R0217.0174) FIX|MT8283 Issue with DHCP Snooping untrusted ports 7.0.3.5(R0217.0170) FIX|MT7848 3650/3950 switch hangup after request of big log file via web 7.0.3.5(R0217.0168) FIX|MT7738 dhcp snooping drops dhcp packets with ethernet trailer 7.0.3.5(R0217.0167) FIX|MT7730 3950-28C LLDP Local Management address OID not available 7.0.3.5(R0217.0165) ADD|MT7441 LLDP data values throught SNMP. ADD new command "lldp response standard | private" 7.0.3.5(R0217.0162) FIX|MT7400 DCS-3950-28C LLDP don't accept "Management address OID" from neighbor 7.0.3.5(R0217.0160) FIX|MT7275 on combo ports flow-control enabled as default 7.0.3.5(R0217.0159) ADD|MT7051 DHCPv6-solicit DUID type 4 (RFC6355) support Вставить ник Quote
tros10 Posted December 12, 2019 Posted December 12, 2019 Уточните пожалуйста, подходит ли этот софт для SNR-S2960-24G ? Вставить ник Quote
Evgeny Mirhasanov Posted December 12, 2019 Posted December 12, 2019 14 minutes ago, tros10 said: Уточните пожалуйста, подходит ли этот софт для SNR-S2960-24G ? Для этих коммутаторов отдельная ветка ПО: https://data.nag.ru/SNR Switches/Firmware/SNR-S2960-24G/recommended/S2960-24G_7.0.3.5(R0217.0170).zip Вставить ник Quote
tros10 Posted December 12, 2019 Posted December 12, 2019 Я поглядел релиз 170, они по размеру совпадают для SNR-S2960-24G и для SNR-S2940-8G-v2. Вставить ник Quote
Evgeny Mirhasanov Posted December 12, 2019 Posted December 12, 2019 1 hour ago, tros10 said: Я поглядел релиз 170, они по размеру совпадают для SNR-S2960-24G и для SNR-S2940-8G-v2. Действительно, моя ошибка. Выложили новейшую версию ПО и для SNR-S2960-24G https://data.nag.ru/SNR Switches/Firmware/SNR-S2960-24G/recommended/S2960-24G_7.0.3.5(R0217.0175).zip Вставить ник Quote
