Некоторое время назад вдруг массово начались какие-то проблемы с коммутаторами SNR-S2960-48G.
ПО на них с 6 ветки (например 6.2.138.121).
Конфигурация такая:
loopback-detection interval-time 60 5
loopback-detection control-recovery timeout 60
loopback-detection trap enable
vlan 1;300-499;800-999
vlan 10
 name MGMT
vlan 1000
 name STUB
vlan 60
 name IPTV
 multicast-vlan
 multicast-vlan association 400-499
firewall enable
access-list 6010 permit ip any-source 224.0.0.0 0.0.0.255
access-list 6010 permit ip any-source 239.0.0.0 0.0.255.255
access-list 6010 permit ip any-source 239.1.0.0 0.0.255.255
access-list 6010 permit ip any-source 239.195.0.0 0.0.255.255
access-list 6010 permit ip any-source 239.250.0.0 0.0.255.255
access-list 6010 deny ip any-source any-destination
mac-access-list extended pppoe
  permit any-source-mac 00-30-88-1c-00-00 00-00-00-00-ff-ff untagged-eth2 ethertype 34915
  permit any-source-mac 00-30-88-1c-00-00 00-00-00-00-ff-ff untagged-eth2 ethertype 34916
  permit any-source-mac 01-00-5e-00-00-00 00-00-00-ff-ff-ff
  permit 01-00-5e-00-00-00 00-00-00-ff-ff-ff any-destination-mac
  deny any-source-mac any-destination-mac
  exit
multicast destination-control
pppoe intermediate-agent
pppoe intermediate-agent format circuit-id ascii
pppoe intermediate-agent format remote-id ascii
mls qos
Interface Ethernet0/0/1-48
 ip multicast destination-control access-group 6010
 switchport access vlan 4xx
 switchport association multicast-vlan 60
 mac access-group pppoe in
 pppoe intermediate-agent vendor-tag strip
 loopback-detection specified-vlan 400-499
 loopback-detection control block
 igmp snooping drop query
Interface Ethernet0/0/49-52
 switchport mode trunk
 switchport trunk allowed vlan 10;60;300-499;800-999
 pppoe intermediate-agent trust
ip igmp snooping
ip igmp snooping vlan 60
ip igmp snooping vlan 60 immediately-leave
ip igmp snooping vlan 60 query-interval 60
isolate-port group ACCESS switchport interface ethernet0/0/1-48
isolate-port group ACCESS switchport interface ethernet0/0/50-52
Аплинк в порту 49, предоставляется PPPoE (VLAN 4xx) и IPTV (мультикаст-vlan 60).
Бывают жалобы на скорость, на проблемы с подключением (не с первого раза или долго), на разрывы.
Жалобы не постоянные, но и не разовые.
При этом жалобы в основном при случаях прямого подключения (непосредственно с ПК или ноутбука).
Если подключение производится через роутер, то обычно все подключается сразу.
Вчера ТП снимала тестовые дампы процесса подключения, абонент был подключен в порт 1, ноутбук ТП с Wireshark в порт 48.
ТП уверяет, что зеркало трафика было настроено правильно (source на порту 1, destination на порту 48) и проверялось командой show monitor.
Однако в дампе трафика абонентских пакетов менее 1%. Зато куча всего, что могло быть только на магистральном порту (трафик транзитных VLAN).
FDB-таблица выглядит так:
#sh mac-address-table count
Compute the number of mac address....
Max entries can be created in the largest capacity card:
Total     Filter Entry Number is: 8192
Static    Filter Entry Number is: 8192
Unicast   Filter Entry Number is: 8192
Multicast Filter Entry Number is: 255
Current entries have been created in the system:
Total     Filter Entry Number is: 2120
Individual    Filter Entry Number is: 2120
Static    Filter Entry Number is: 405
Dynamic   Filter Entry Number is: 1715
Multicast(Insert) Filter Entry Number is: 1
Multicast(Wait) Filter Entry Number is: 0
Может быть так, что на коммутаторе сломалась собственно коммутация и он флудит во все порты?
Как это проверить?
@alibek, не исключаю на 100% подобного поведения, но архитектурно такое маловероятно и подобных случаев ранее не фиксировалось.
Обращаю внимание, что порт назначения зеркала не отключается от коммутации, возможно туда прилетал избыточный трафик не из зеркала.
Как туда мог прилететь обычный не широковещательный трафик?
Я в дампе видел трафик из VLAN 8xx; это выделенные линии для ЮЛ, на них статикой прописаны публичные IP-адреса. Они никак не могут случайно попасть на обычный абонентский порт.
@alibek, в зависимости от настроек туда мог прилететь BUM-трафик.
Рекомендую повторить эксперимент с зеркалом, поместив destination в отдельный vlan и убедившись что source выбран корректно. Если ситуация воспроизведется, соберите дамп без зеркала, настроив порт аналогично клиентскому, либо включившись непосредственно в клиентский порт.
С более подробным описанием проблемы затем стоит обратиться в support.nag.ru.
