I just got a pair of Cisco APs and a WLC in order to play around for my Wireless CCNA certification. I'm having troubles connecting all 3 devices together. I believe I need a switch to connect them. In the WLC there are 2 ports which aren't Ethernet though
Here is the picture: Cisco Devices
So:
  • Is it possible to connect the APs directly to the WLC?
  • If I need a switch, through which interface should I connect it?
1 час назад, sarahjohn сказал:
So:
Hi.
You need switch. Controller connect to switch through TRUNK. AP may connect through access.
And you need router.
В 23.08.2018 в 15:03, sarahjohn сказал:
no, you need switch
you can to connect your ap to any port in switch. but dont forget about power - use poe switch or external power for ap
