Добрый день.
при настройке MIRRORING на SNR возника проблема с тем, что при мирроринге TX направления в vlan нет трафика. При этом с RX всё нормально.
sh version
   SoftWare Version 7.0.3.5(R0241.0085)
   BootRom Version 7.2.25
   HardWare Version 1.0.2
vlan 5
 name SNR_MIRROR
Interface Ethernet1/0/1
 description "## UPSTREAM ##"
 switchport access vlan 43
Interface Ethernet1/0/17
 description ## RASPBERRY PI3 ##
 switchport mode trunk
 switchport trunk allowed vlan 5;555
 switchport trunk native vlan 43
monitor session 1 source interface Ethernet1/0/1 tx
monitor session 1 destination interface Ethernet1/0/17
monitor session 1 remote vlan 5
Tx трафик на интерфейсе E1/0/1 есть
sh interface e1/0/1
Interface brief:
  Ethernet1/0/1 is up, line protocol is up
  Ethernet1/0/1 is layer 2 port, alias name is "## UPSTREAM ##", index is 1
  Hardware is Gigabit-TX, address is f8-f0-82-75-e9-b0
  PVID is 43
  MTU 1500 bytes, BW 100000 Kbit
  Time since last status change:0w-0d-0h-23m-26s  (1406 seconds)
  Encapsulation ARPA, Loopback not set
  Auto-duplex: Negotiation full-duplex, Auto-speed: Negotiation 100M bits
  FlowControl is off, MDI type is auto
Statistics:
  5 minute input rate 4076121 bits/sec, 490 packets/sec
  5 minute output rate 530122 bits/sec, 635 packets/sec
  The last 5 second input rate 1706016 bits/sec, 129 packets/sec
  The last 5 second output rate 273438 bits/sec, 126 packets/sec
Но в дампе на устройстве - только переиодически проскакивающие ARP запросы
 tcpdump -npi eth0.5
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0.5, link-type EN10MB (Ethernet), capture size 262144 bytes
12:49:08.978352 IP 10.30.23.133.17500 > 10.30.23.143.17500: UDP, length 167
12:49:37.469808 IP 10.30.23.130.5353 > 224.0.0.251.5353: 0 [4q] [1au] PTR (QU)? _homekit._tcp.local. PTR (QU)? _raop._tcp.local. PTR (QU)? _airplay._tcp.local. PTR (QU)? _sleep-proxy._udp.local. (117)
12:49:37.484561 IP6 fe80::8f3:690a:cf78:46b1.5353 > ff02::fb.5353: 0 [4q] [1au] PTR (QU)? _homekit._tcp.local. PTR (QU)? _raop._tcp.local. PTR (QU)? _airplay._tcp.local. PTR (QU)? _sleep-proxy._udp.local. (117)
12:49:38.289479 IP 10.30.23.130 > 224.0.0.251: igmp v2 report 224.0.0.251
12:49:38.474804 ARP, Request who-has 10.30.23.131 tell 10.30.23.131, length 50
12:49:38.475497 ARP, Request who-has 10.30.23.131 (ff:ff:ff:ff:ff:ff) tell 10.30.23.140, length 46
12:49:38.481795 IP 10.30.23.130.5353 > 224.0.0.251.5353: 0 [4q] [1au] PTR (QM)? _homekit._tcp.local. PTR (QM)? _raop._tcp.local. PTR (QM)? _airplay._tcp.local. PTR (QM)? _sleep-proxy._udp.local. (117)
12:49:38.482391 IP6 fe80::8f3:690a:cf78:46b1.5353 > ff02::fb.5353: 0 [4q] [1au] PTR (QM)? _homekit._tcp.local. PTR (QM)? _raop._tcp.local. PTR (QM)? _airplay._tcp.local. PTR (QM)? _sleep-proxy._udp.local. (117)
12:49:39.039575 IP 10.30.23.133.17500 > 10.30.23.143.17500: UDP, length 167
12:49:39.475767 ARP, Request who-has 10.30.23.131 tell 10.30.23.131, length 50
12:49:39.476399 ARP, Request who-has 10.30.23.131 (ff:ff:ff:ff:ff:ff) tell 10.30.23.140, length 46
При этом если добавляю
(config)#monitor session 1 source interface Ethernet1/0/1 rx
то в дампе трафик появляется
tcpdump -npi eth0.5
12:53:51.662602 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [P.], seq 2059023215:2059023253, ack 2971579541, win 114, options [nop,nop,TS val 3173380672 ecr 2448491651], length 38
12:53:51.663545 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [P.], seq 38:80, ack 1, win 114, options [nop,nop,TS val 3173380672 ecr 2448491651], length 42
12:53:51.751544 IP 91.231.219.151.1194 > 10.30.23.139.43924: UDP, length 101
12:53:51.761683 IP 91.231.219.151.1194 > 10.30.23.139.43924: UDP, length 101
12:53:51.811092 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [.], seq 80:1478, ack 1, win 114, options [nop,nop,TS val 3173380819 ecr 2448491688], length 1398
12:53:51.811367 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [.], seq 1478:2876, ack 1, win 114, options [nop,nop,TS val 3173380819 ecr 2448491688], length 1398
12:53:51.811615 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [.], seq 2876:4274, ack 1, win 114, options [nop,nop,TS val 3173380819 ecr 2448491688], length 1398
12:53:51.811839 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [.], seq 4274:5672, ack 1, win 114, options [nop,nop,TS val 3173380819 ecr 2448491688], length 1398
Нужна какая то дополнительная настройка?
Заранее спасибо за помощь.
Edited by sda_1
@sda_1, добрый!
По всей видимости речь о коммутаторе серий S2965 или S2985G, мирроринг TX на них работает.
Обновите ПО коммутатора, архивы с образами рекомендованных версий можете загрузить здесь:
S2965 или S2985G
2 часа назад, Victor Tkachenko сказал:
@sda_1, добрый!
S2965 или S2985G
Софт обновил, но картина не поменялась
 tcpdump -npi eth0.5
18:25:54.851976 IP 10.30.23.133.137 > 10.30.23.143.137: NBT UDP PACKET(137): QUERY; REQUEST; BROADCAST
18:25:54.852738 IP 10.30.23.133.57012 > 224.0.0.252.5355: UDP, length 22
18:25:54.853381 IP 10.30.23.133.59151 > 224.0.0.252.5355: UDP, length 22
18:25:55.262392 IP 10.30.23.133.57012 > 224.0.0.252.5355: UDP, length 22
18:25:55.263198 IP 10.30.23.133.59151 > 224.0.0.252.5355: UDP, length 22
18:25:55.601989 IP 10.30.23.133.137 > 10.30.23.143.137: NBT UDP PACKET(137): QUERY; REQUEST; BROADCAST
18:25:56.351990 IP 10.30.23.133.137 > 10.30.23.143.137: NBT UDP PACKET(137): QUERY; REQUEST; BROADCAST
18:26:13.847265 IP 10.30.23.133.17500 > 255.255.255.255.17500: UDP, length 168
18:26:13.854255 IP 10.30.23.133.17500 > 255.255.255.255.17500: UDP, length 168
18:26:13.854405 IP 10.30.23.133.17500 > 10.30.23.143.17500: UDP, length 168
18:26:13.855158 IP 10.30.23.133.17500 > 255.255.255.255.17500: UDP, length 168
SNR#sh version
  SNR-S2985G-24T Device, Compiled on Jun 06 20:16:59 2018
  sysLocation Building 57/2,Predelnaya st, Ekaterinburg, Russia
  CPU Mac f8:f0:82:75:e9:b0
  Vlan MAC f8:f0:82:75:e9:af
  SoftWare Version 7.0.3.5(R0241.0258)
  BootRom Version 7.2.33
  CPLD Version N/A
  Serial No.:SW067210GB21000366
  Copyright (C) 2018 NAG LLC
  All rights reserved
  Last reboot is warm reset.
  Uptime is 0 weeks, 0 days, 0 hours, 1 minutes
Edited by sda_1
  • 2 weeks later...
проблема была в самом tcpdump, а именно ключе -p, который не переводил интерфейс в режим приема всех пакетов (promiscuous mode).
tcpdump -ni eth0.5 host 85.112.113.90 -c 20
20:35:06.645762 IP 10.30.23.135.4642 > 85.112.113.90.443: Flags [S], seq 3730807690, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
20:35:06.671513 IP 10.30.23.135.4642 > 85.112.113.90.443: Flags [.], ack 3804666398, win 256, length 0
20:35:06.675108 IP 10.30.23.135.4642 > 85.112.113.90.443: Flags [P.], seq 0:517, ack 1, win 256, length 517
Edited by sda_1
