Добрый день.
при настройке MIRRORING на SNR возника проблема с тем, что при мирроринге TX направления в vlan нет трафика. При этом с RX всё нормально.
sh version
SoftWare Version 7.0.3.5(R0241.0085)
BootRom Version 7.2.25
HardWare Version 1.0.2
vlan 5
name SNR_MIRROR
Interface Ethernet1/0/1
description "## UPSTREAM ##"
switchport access vlan 43
Interface Ethernet1/0/17
description ## RASPBERRY PI3 ##
switchport mode trunk
switchport trunk allowed vlan 5;555
switchport trunk native vlan 43
monitor session 1 source interface Ethernet1/0/1 tx
monitor session 1 destination interface Ethernet1/0/17
monitor session 1 remote vlan 5
Tx трафик на интерфейсе E1/0/1 есть
sh interface e1/0/1
Interface brief:
Ethernet1/0/1 is up, line protocol is up
Ethernet1/0/1 is layer 2 port, alias name is "## UPSTREAM ##", index is 1
Hardware is Gigabit-TX, address is f8-f0-82-75-e9-b0
PVID is 43
MTU 1500 bytes, BW 100000 Kbit
Time since last status change:0w-0d-0h-23m-26s (1406 seconds)
Encapsulation ARPA, Loopback not set
Auto-duplex: Negotiation full-duplex, Auto-speed: Negotiation 100M bits
FlowControl is off, MDI type is auto
Statistics:
5 minute input rate 4076121 bits/sec, 490 packets/sec
5 minute output rate 530122 bits/sec, 635 packets/sec
The last 5 second input rate 1706016 bits/sec, 129 packets/sec
The last 5 second output rate 273438 bits/sec, 126 packets/sec
Но в дампе на устройстве - только переиодически проскакивающие ARP запросы
tcpdump -npi eth0.5
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0.5, link-type EN10MB (Ethernet), capture size 262144 bytes
12:49:08.978352 IP 10.30.23.133.17500 > 10.30.23.143.17500: UDP, length 167
12:49:37.469808 IP 10.30.23.130.5353 > 224.0.0.251.5353: 0 [4q] [1au] PTR (QU)? _homekit._tcp.local. PTR (QU)? _raop._tcp.local. PTR (QU)? _airplay._tcp.local. PTR (QU)? _sleep-proxy._udp.local. (117)
12:49:37.484561 IP6 fe80::8f3:690a:cf78:46b1.5353 > ff02::fb.5353: 0 [4q] [1au] PTR (QU)? _homekit._tcp.local. PTR (QU)? _raop._tcp.local. PTR (QU)? _airplay._tcp.local. PTR (QU)? _sleep-proxy._udp.local. (117)
12:49:38.289479 IP 10.30.23.130 > 224.0.0.251: igmp v2 report 224.0.0.251
12:49:38.474804 ARP, Request who-has 10.30.23.131 tell 10.30.23.131, length 50
12:49:38.475497 ARP, Request who-has 10.30.23.131 (ff:ff:ff:ff:ff:ff) tell 10.30.23.140, length 46
12:49:38.481795 IP 10.30.23.130.5353 > 224.0.0.251.5353: 0 [4q] [1au] PTR (QM)? _homekit._tcp.local. PTR (QM)? _raop._tcp.local. PTR (QM)? _airplay._tcp.local. PTR (QM)? _sleep-proxy._udp.local. (117)
12:49:38.482391 IP6 fe80::8f3:690a:cf78:46b1.5353 > ff02::fb.5353: 0 [4q] [1au] PTR (QM)? _homekit._tcp.local. PTR (QM)? _raop._tcp.local. PTR (QM)? _airplay._tcp.local. PTR (QM)? _sleep-proxy._udp.local. (117)
12:49:39.039575 IP 10.30.23.133.17500 > 10.30.23.143.17500: UDP, length 167
12:49:39.475767 ARP, Request who-has 10.30.23.131 tell 10.30.23.131, length 50
12:49:39.476399 ARP, Request who-has 10.30.23.131 (ff:ff:ff:ff:ff:ff) tell 10.30.23.140, length 46
При этом если добавляю
(config)#monitor session 1 source interface Ethernet1/0/1 rx
то в дампе трафик появляется
tcpdump -npi eth0.5
12:53:51.662602 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [P.], seq 2059023215:2059023253, ack 2971579541, win 114, options [nop,nop,TS val 3173380672 ecr 2448491651], length 38
12:53:51.663545 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [P.], seq 38:80, ack 1, win 114, options [nop,nop,TS val 3173380672 ecr 2448491651], length 42
12:53:51.751544 IP 91.231.219.151.1194 > 10.30.23.139.43924: UDP, length 101
12:53:51.761683 IP 91.231.219.151.1194 > 10.30.23.139.43924: UDP, length 101
12:53:51.811092 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [.], seq 80:1478, ack 1, win 114, options [nop,nop,TS val 3173380819 ecr 2448491688], length 1398
12:53:51.811367 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [.], seq 1478:2876, ack 1, win 114, options [nop,nop,TS val 3173380819 ecr 2448491688], length 1398
12:53:51.811615 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [.], seq 2876:4274, ack 1, win 114, options [nop,nop,TS val 3173380819 ecr 2448491688], length 1398
12:53:51.811839 IP 31.13.81.32.443 > 10.30.23.139.44236: Flags [.], seq 4274:5672, ack 1, win 114, options [nop,nop,TS val 3173380819 ecr 2448491688], length 1398
Нужна какая то дополнительная настройка?
Заранее спасибо за помощь.
