Сабж.
Не рисует графики нагрузки на сеть. Ни 32-битные, ни 64-битные.
Debian GNU/Linux 8.8 (jessie) 64 бит
Сетевая ixgbe
driver: ixgbe
version: 4.3.15
firmware-version: 0x800003e7
bus-info: 0000:03:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
Пакеты snmp на сервере.
ii libsnmp-base 5.7.2.1+dfsg-1 all SNMP configuration script, MIBs and documentation
ii libsnmp30:amd64 5.7.2.1+dfsg-1 amd64 SNMP (Simple Network Management Protocol) library
ii snmp 5.7.2.1+dfsg-1 amd64 SNMP (Simple Network Management Protocol) applications
ii snmp-mibs-downloader 1.1 all Install and manage Management Information Base (MIB) files
ii snmpd 5.7.2.1+dfsg-1 amd64 SNMP (Simple Network Management Protocol) agents
Cacti 0.8.8g (на другой машине)
У меня рисует
Debian GNU/Linux 7.8 (wheezy) 64 бит
Сетевая ixgbe
driver: ixgbe
version: 3.19.1-k
firmware-version: 0x546c0001
bus-info: 0000:03:00.1
supports-test: yes
ii libnet-snmp-perl 6.0.1-2 all Script SNMP connections
ii libsnmp-base 5.4.3~dfsg-2.8+deb7u1 all SNMP (Simple Network Management Protocol) MIBs and documentation
ii libsnmp-dev 5.4.3~dfsg-2.8+deb7u1 amd64 SNMP (Simple Network Management Protocol) development files
ii libsnmp-perl 5.4.3~dfsg-2.8+deb7u1 amd64 SNMP (Simple Network Management Protocol) Perl5 support
ii libsnmp15 5.4.3~dfsg-2.8+deb7u1 amd64 SNMP (Simple Network Management Protocol) library
ii php5-snmp 5.4.45-0+deb7u1 amd64 SNMP module for php5
ii snmp 5.4.3~dfsg-2.8+deb7u1 amd64 SNMP (Simple Network Management Protocol) applications
ii snmpd 5.4.3~dfsg-2.8+deb7u1 amd64 SNMP (Simple Network Management Protocol) agents
Cacti 0.8.8f (на другой машине)
  • 5 weeks later...
# snmpwalk -c xxxx  -v2c localhost .1.3.6.1.2.1.31.1.1.1.1.6
iso.3.6.1.2.1.31.1.1.1.1.6 = STRING: "eth0"
# snmpwalk -c xxxx  -v2c localhost .1.3.6.1.2.1.2.2.1.5.6
iso.3.6.1.2.1.2.2.1.5.6 = Gauge32: 1000000000
# snmpwalk -c xxxx  -v2c localhost .1.3.6.1.2.1.31.1.1.1.6
iso.3.6.1.2.1.31.1.1.1.6.1 = Counter64: 4294967296
iso.3.6.1.2.1.31.1.1.1.6.2 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.6.3 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.6.4 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.6.5 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.6.6 = Counter64: 8252161912
iso.3.6.1.2.1.31.1.1.1.6.7 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.6.8 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.6.9 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.6.10 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.6.11 = Counter64: 0
# snmpwalk -c xxxx -v2c localhost .1.3.6.1.2.1.31.1.1.1.10
iso.3.6.1.2.1.31.1.1.1.10.1 = Counter64: 4294967296
iso.3.6.1.2.1.31.1.1.1.10.2 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.10.3 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.10.4 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.10.5 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.10.6 = Counter64: 31350811848
iso.3.6.1.2.1.31.1.1.1.10.7 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.10.8 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.10.9 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.10.10 = Counter64: 0
iso.3.6.1.2.1.31.1.1.1.10.11 = Counter64: 0
Смотрю cacti/resource/snmp_queries/interface.xml:
               <ifHCInOctets>
                       <name>Bytes In - 64-bit Counters</name>
                       <method>walk</method>
                       <source>value</source>
                       <direction>output</direction>
                       <oid>.1.3.6.1.2.1.31.1.1.1.6</oid>
               </ifHCInOctets>
               <ifHCOutOctets>
                       <name>Bytes Out - 64-bit Counters</name>
                       <oid>.1.3.6.1.2.1.31.1.1.1.10</oid>
               </ifHCOutOctets>
Получается, счетчики статичные, хотя траф бегает....
# ifconfig eth0
eth0      Link encap:Ethernet  HWaddr 0c:c4:7a:ce:bb:7a
         inet addr:
         inet6 addr:
         UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
         RX packets:83416313 errors:0 dropped:0 overruns:0 frame:0
         TX packets:49995732 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:10000
         RX bytes:8630127883 (8.0 GiB)  TX bytes:34372717092 (32.0 GiB)
# ifconfig lo0
lo        Link encap:Local Loopback
         inet addr:127.0.0.1  Mask:255.0.0.0
         inet6 addr: ::1/128 Scope:Host
         UP LOOPBACK RUNNING  MTU:65536  Metric:1
         RX packets:1512342 errors:0 dropped:0 overruns:0 frame:0
         TX packets:1512342 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:0
         RX bytes:189086301 (180.3 MiB)  TX bytes:189086301 (180.3 MiB)
