Коллеги, будет ли работать policing/shaping на Port-channel 802.1q интерфейсе?
interface Port-channel2.532
description = Customer =
encapsulation dot1Q 532
ip address 192.168.0.1 255.255.255.248
service-policy output SHAPER-USER-35MBIT
policy-map OUT-WAN-USER
class class-default
fair-queue
random-detect
policy-map SHAPER-USER-35MBIT
class class-default
shape average 35000000
service-policy OUT-WAN-USER
Ну проверь же. sh policy-map interface po2.532, если не suspend то все ок
 Port-channel2.532
 Service-policy output: SHAPER-USER-35MBIT
   Class-map: class-default (match-any)
     561596255 packets, 785347912365 bytes
     5 minute offered rate 1061000 bps, drop rate 0 bps
     Match: any
     Queueing
     queue limit 64 packets
     (queue depth/total drops/no-buffer drops) 0/0/0
     (pkts output/bytes output) 0/0
     shape (average) cir 35000000, bc 140000, be 140000
     target shape rate 35000000
     Service-policy : OUT-WAN-USER
         561596276 packets, 785347954999 bytes
         Match: any
         Queueing
         (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
         Fair-queue: per-flow queue limit 16
           Exp-weight-constant: 9 (1/512)
           Mean queue depth: 0 packets
           class     Transmitted       Random drop      Tail/Flow drop Minimum Maximum Mark
                     pkts/bytes    pkts/bytes       pkts/bytes    thresh  thresh  prob
           0               0/0               0/0              0/0                 20            40  1/10
           1               0/0               0/0              0/0                 22            40  1/10
           2               0/0               0/0              0/0                 24            40  1/10
           3               0/0               0/0              0/0                 26            40  1/10
           4               0/0               0/0              0/0                 28            40  1/10
           5               0/0               0/0              0/0                 30            40  1/10
           6               0/0               0/0              0/0                 32            40  1/10
           7               0/0               0/0              0/0                 34            40  1/10
Вроде работает, но по графику вижу, что были всплески до 80 Мбит/c
