Пробую настроить mac vlan на этом девайсе с терминацией L3 на нем - же .
кусок конфига:
/interface ethernet
set [ find default-name=ether1 ] name=e1-inet
set [ find default-name=ether2 ] name=e2-local
set [ find default-name=ether24 ] master-port=e2-local name=e24-uplink
set [ find default-name=ether3 ] master-port=e2-local
set [ find default-name=ether4 ] master-port=e2-local
set [ find default-name=ether5 ] master-port=e2-local
set [ find default-name=ether6 ] master-port=e2-local
set [ find default-name=ether7 ] master-port=e2-local
set [ find default-name=ether8 ] master-port=e2-local
set [ find default-name=ether9 ] master-port=e2-local
set [ find default-name=ether10 ] master-port=e2-local
set [ find default-name=ether11 ] master-port=e2-local
set [ find default-name=ether12 ] master-port=e2-local
set [ find default-name=ether13 ] master-port=e2-local
set [ find default-name=ether14 ] master-port=e2-local
set [ find default-name=ether15 ] master-port=e2-local
set [ find default-name=ether16 ] master-port=e2-local
set [ find default-name=ether17 ] master-port=e2-local
set [ find default-name=ether18 ] master-port=e2-local
set [ find default-name=ether19 ] master-port=e2-local
set [ find default-name=ether20 ] master-port=e2-local
set [ find default-name=ether21 ] master-port=e2-local
set [ find default-name=ether22 ] master-port=e2-local
set [ find default-name=ether23 ] master-port=e2-local
set [ find default-name=sfp1 ] master-port=e1-inet
/interface vlan
add interface=e2-local name=vlan150 vlan-id=150
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/interface ethernet switch egress-vlan-translation
add customer-vid=150 new-customer-vid=0 ports=e2-local
/interface ethernet switch mac-based-vlan
add new-customer-vid=150 src-mac-address=00:15:65:12:0E:B5
add new-customer-vid=150 src-mac-address=00:15:65:11:49:E9
add new-customer-vid=150 src-mac-address=00:15:65:12:0E:87
add new-customer-vid=150 src-mac-address=00:15:65:12:11:21
add new-customer-vid=150 src-mac-address=00:15:65:82:F9:3D
add new-customer-vid=150 src-mac-address=00:15:65:12:10:C7
add new-customer-vid=150 src-mac-address=00:15:65:5D:AE:82
add new-customer-vid=150 src-mac-address=00:15:65:12:0E:3D
add new-customer-vid=150 src-mac-address=00:15:65:11:49:91
add new-customer-vid=150 src-mac-address=00:15:65:12:11:5F
add new-customer-vid=150 src-mac-address=00:15:65:12:0F:8F
add new-customer-vid=150 src-mac-address=00:15:65:7A:C7:F8
add new-customer-vid=150 src-mac-address=00:15:65:82:F9:A5
add new-customer-vid=150 src-mac-address=00:15:65:12:10:2B
/interface ethernet switch port
set 1 egress-vlan-mode=untagged
set 2 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 3 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 4 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 5 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 6 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 7 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 8 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 9 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged egress-vlan-tag-table-lookup-key=according-to-bridge-type
set 10 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 11 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 12 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 13 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 14 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 15 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 16 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 17 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 18 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 19 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged
set 20 allow-fdb-based-vlan-translate=yes
set 21 allow-fdb-based-vlan-translate=yes
set 22 allow-fdb-based-vlan-translate=yes
/interface ethernet switch vlan
add ports=e2-local,switch1-cpu vlan-id=150
[code]
На интерфейс vlan150 пакеты успешно прилетают (там повешен ip и на нем dhcp) , но вот судя по всему в ответ не долетают.
/interface ethernet switch egress-vlan-translation пробовал делать и на e2-local и на конечных портах - не помогает.
Может есть у кого рабочий пример mac-vlan с терминацией его н этом же устройстве?
А что вы вообще хотите получить? В вашем конфиге по этой теме - терминация вланов по L3 нет ничего.
Вы хотите сразу IP на нужный влан повесить, или на порт? Или на основе мака абонента?
Ну , неважные моменты не включал в конфиг и так простыня большая.
Оно вот так:
/ip address
add address=192.168.0.14/24 comment="Local network" interface=e2-local network=192.168.0.0
add address=192.168.85.1/24 interface=vlan150 network=192.168.85.0
Я вешаю ip на 150 влан. Прилетающие пакеты в случае совпадения с настроенным маком попадают в 150 vlan , там запущен dhcp
/ip dhcp-server
add address-pool=voip1 disabled=no interface=vlan150 name=server1
/ip dhcp-server network
add address=192.168.85.0/24 dns-server=8.8.8.8 gateway=192.168.85.1 netmask=24
DHCP видит прилетающие пакеты в 150 vlan
# ADDRESS MAC-ADDRESS HOST-NAME SERVER RATE-LIMIT STATUS
0 D 192.168.85.250 00:15:65:12:11:5F SIP-T22P server1 offered
1 D 192.168.85.249 00:15:65:12:0E:3D SIP-T22P server1 offered
2 D 192.168.85.248 00:15:65:12:10:2B SIP-T22P server1 offered
3 D 192.168.85.247 00:15:65:11:49:91 SIP-T28P server1 offered
Сниффером на интерфейсе vlan150 видны ответы клиентам , но до клиентов они не долетают.
Тоесть мне нужно поместить некоторое количество клиентов в на основе mac в vlan. В одну сторону это явно работает , а вот ответы untag'om обратно не приходят.
