Коммутация WIC-1T и WIC-2T кабелями DB60-V35MT + переходник V35-RS232 + SS-RS232FC выполнена.
, порты включаются, лампочки горят, но
На Wic-1T
interface Serial1/0
ip address 10.0.0.2 255.255.255.0
encapsulation ppp
Serial1/0 is up, line protocol is down
Hardware is DSCC4 Serial
Internet address is 10.0.0.2/24
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
LCP Listen
Closed: IPCP, CDPCP
Last input never, output 00:02:51, output hang never
Last clearing of "show interface" counters 00:03:56
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
11 packets output, 154 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 output buffer failures, 0 output buffers swapped out
29 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
На Wic-2T задан clock rate 2000000
interface Serial0/1
ip address 10.0.0.1 255.255.255.0
encapsulation ppp
clockrate 2000000
dce-terminal-timing-enable
Serial0/1 is up, line protocol is down
Hardware is PowerQUICC Serial
Internet address is 10.0.0.1/24
Encapsulation PPP, LCP REQsent, loopback not set
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:04:15
52 packets output, 728 bytes, 0 underruns
0 output errors, 0 collisions, 16 interface resets
10 carrier transitions
Edited by fzakharov
Метров 5 - кишка такая составная
На максимально возможную скорость для WIC-2T и длины интерфейсных кабелей обратите внимание, а так же на строку в вашем же выводе "Available Bandwidth 1158 kilobits/sec". А вы ему рэйт на 2мбит ввалили.
Спасибо.
Сlock rate 64000 - работает, но только если связка DB60-RS232MT + SS-RS232FC. Кстати, расстояние тоже около 5 метров.
Снижение clock rate при связке кабелями DB60-V35MT + переходник V35-RS232 + SS-RS232FC результата не дает.
Ну может тогда появились бы ошибки тут:
Router#sh contr s0/0
Interface Serial0/0
Hardware is PowerQUICC MPC860
DTE V.35 TX and RX clocks detected.
idb at 0x82E4B9C0, driver data structure at 0x82E53ABC
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [sCCE]=0x0000, Mask [sCCM]=0x001F, Status [sCCS]=0x06
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00367F80, Pending [CIPR]=0x00008000
Mask [CIMR]=0x40204000, In-srv [CISR]=0x00000000
Command register [CR]=0x600
Port A [PADIR]=0x0000, [PAPAR]=0xFFFF
[PAODR]=0x0000, [PADAT]=0xF6FF
Port B [PBDIR]=0x0180F, [PBPAR]=0x0000E
[PBODR]=0x00000, [PBDAT]=0x3E77D
Port C [PCDIR]=0x00C, [PCPAR]=0x000
[PCSO]=0x020, [PCDAT]=0xFC2, [PCINT]=0x00F
Receive Ring
rmd(680126B0): status 9000 length 1A address 7D3B2E4
rmd(680126B8): status 9000 length 60C address 7D3AC64
rmd(680126C0): status 9000 length 60C address 7D3FA64
rmd(680126C8): status 9000 length 60C address 7D3A5E4
или тут:
Router#sh int s0
Serial0/0 is up, line protocol is up
reliability 254/255, txload 1/255, rxload 1/255
Encapsulation HDLC, loopback not set
Last input 00:00:09, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:17:55
Queueing strategy: fifo
Output queue: 0/40 (size/max)
91 packets input, 4526 bytes, 0 no buffer
Received 91 broadcasts, 0 runts, 0 giants, 0 throttles
22 input errors, 0 CRC, 22 frame, 0 overrun, 0 ignored, 0 abort
187 packets output, 28808 bytes, 0 underruns
0 output errors, 0 collisions, 46 interface resets
66 carrier transitions
Их разве нет?
P.S>А зачем вам этот копролит понадобился вообще? Лабу что ли делаете?
Хотел собрать лабу на стареньком оборудовании, а не на виртуалках, но кабели SS-SS и SS-DB60 дороговаты, вот нашел такие, соединил и ошибки...
Может их можно "вручную укоротить"?? Если проблема только в длине кабелей.
Спасибо.
Если в первой связке работает то зачем вторую мучить?
А вторая связка вообще допустима?
Спасибо за комментарий. Ну почему же не допустима моя длинная связка?? Кабели есть, собираются, DTE/DCE на WIC определяются. Да и 6м. - нормальное расстояние. Ну поставлю BW поменьше: мне для icmp/cdp пакетов не страшно. Чего-то мелкого не хватает, чтобы схемка заработала. Кстати в async режиме "is up, line protocol is up", но пинги не идут ((.
Оказывается белые переходники не EIA-232, а EIA-530, соответственно связаться с SS-232 они никак не могут. (((
Как вы думаете, друзья, какие варианты могут тут быть??
Как думаете, а если достать кабель DB60-RS530 и заменить ему папу на маму согласно мануалам - все свяжется?? Я посмотрел, там вроде внутри проводочки одни, без микросхем.
