Помогите!
настраиваю cisco ios 15.2 = radius
при передаче пакетов биллингу что то не нравиться.
как найти что?
12:36:28.602139 In a4:0c:c3:7c:2c:19 ethertype IPv4 (0x0800), length 175: (tos 0x0, ttl 255, id 9646, offset 0, flags [none], proto UDP (17), length 159)
10.1.0.1.datametrics > 10.1.0.2.radius: [udp sum ok] RADIUS, length: 131
Access Request (1), id: 0x0b, Authenticator: f2c5cf5f8743deee672a8d76736 1ae86
Username Attribute (1), length: 12, Value: 10.1.10.21
0x0000: 3130 2e31 2e31 302e 3231
Password Attribute (2), length: 18, Value:
0x0000: 1b7b 3014 9cdb 7487 205e 409c e276 970f
Vendor Specific Attribute (26), length: 19, Value: Vendor: Cisco (9)
Vendor Attribute: 250, Length: 11, Value: S10.1.10.21
0x0000: 0000 0009 fa0d 5331 302e 312e 3130 2e32
0x0010: 31
NAS Port Type Attribute (61), length: 6, Value: Virtual
0x0000: 0000 0005
Vendor Specific Attribute (26), length: 17, Value: Vendor: Cisco (9)
Vendor Attribute: 2, Length: 9, Value: 0/0/3/250
0x0000: 0000 0009 020b 302f 302f 332f 3235 30
NAS Port Attribute (5), length: 6, Value: 0
0x0000: 0000 0000
NAS Port ID Attribute (87), length: 11, Value: 0/0/3/250
0x0000: 302f 302f 332f 3235 30
Service Type Attribute (6), length: 6, Value: Outbound
0x0000: 0000 0005
NAS IP Address Attribute (4), length: 6, Value: 10.1.0.1
0x0000: 0a01 0001
Accounting Session ID Attribute (44), length: 10, Value: 0000000D
0x0000: 3030 3030 3030 3044
12:36:29.602487 Out 00:1f:29:e0:56:fa ethertype IPv4 (0x0800), length 64: (tos 0 x0, ttl 64, id 58924, offset 0, flags [none], proto UDP (17), length 48)
10.1.0.2.radius > 10.1.0.1.datametrics: [bad udp cksum 92e8!] RADIUS, length : 20
Access Reject (3), id: 0x0b, Authenticator: 84ce35f13e835c89b3b4a520e828 4782
во первых какой биллинг? во вторых какой подробно ios и модель cisco? какой сервис pppoe или ipoe?
конфиг циски покажите
Edited by alexaaa
биллинг CarbonSoft
cisco 7200 NPE-G1 ios c7200-advipservicesk9-mz.152-4.S7
схема IPoE
конфиг
Building configuration...
Current configuration : 6022 bytes
! Last configuration change at 10:33:37 UTC Thu Apr 14 2016
version 15.2
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname KharinoIPoE
boot-start-marker
boot system disk2:c7200-advipservicesk9-mz.152-4.S7.bin
boot-end-marker
enable secret 5 $1$G4sK$Q616cITrTmXUIz0iS0.Sz1
aaa new-model
aaa group server radius CRB_AAAGS_IPOE
server-private 10.1.0.2 auth-port 1812 acct-port 1813 timeout 3 retransmit 2 key 7 1405130F05113902142716
ip radius source-interface GigabitEthernet0/3.10
deadtime 1
aaa authentication login AAA_LIST_IPOE group CRB_AAAGS_IPOE
aaa authentication ppp AAA_LIST_IPOE group CRB_AAAGS_IPOE
aaa authorization network AAA_LIST_IPOE group CRB_AAAGS_IPOE
aaa authorization subscriber-service default local
aaa authorization subscriber-service AAA_LIST_IPOE local group CRB_AAAGS_IPOE
aaa accounting delay-start all
aaa accounting jitter maximum 10
aaa accounting update periodic 20
aaa accounting network AAA_LIST_IPOE
action-type start-stop
aaa server radius dynamic-author
client 10.1.0.2 server-key 7 120B04131B1E1F2D1A2401
port 3799
auth-type any
aaa session-id common
aaa policy interface-config allow-subinterface
ip cef
ip flow-cache timeout inactive 30
ip flow-cache timeout active 20
ip domain name KharinoIPoE
no ipv6 cef
subscriber service multiple-accept
subscriber authorization enable
multilink bundle-name authenticated
archive
log config
hidekeys
username admin privilege 15 secret 5 $1$J9.1$Hy5OeGNL40k..5Bam.EsU/
ip ssh version 1
class-map type traffic match-any CLS_BLOCKED_REDIRECT
match access-group input name ACL_BLOCKED_REDIRECT
class-map type traffic match-any CLS_BLOCKED_TRUSTED
match access-group input name ACL_BLOCKED_TRUSTED
match access-group output name ACL_BLOCKED_TRUSTED
class-map type traffic match-any CLS_NOSHAPE
match access-group output name ACL_NOSHAPE
match access-group input name ACL_NOSHAPE
class-map type traffic match-any CLS_NEGBAL_REDIRECT
match access-group input name ACL_NEGBAL_REDIRECT
class-map type traffic match-any CLS_NEGBAL_TRUSTED
match access-group input name ACL_NEGBAL_TRUSTED
match access-group output name ACL_NEGBAL_TRUSTED
class-map type traffic match-any CLS_ACCEPT
class-map type control match-all CTRL_TIMER_AUTH
match authen-status authenticated
match timer TIMER_AUTH
class-map type control match-all CTRL_TIMER_UNAUTH
match authen-status unauthenticated
match timer TIMER_UNAUTH
policy-map type control CTRL_IPOE
class type control always event timed-policy-expiry
1 service disconnect
class type control always event account-logoff
class type control always event radius-timeout
10 set-timer TIMER_UNAUTH 10
20 service-policy type service name FWPOL_DEFAULT
class type control always event session-start
10 set-timer TIMER_AUTH 10080
20 authorize aaa list AAA_LIST_IPOE password servicemode identifier source-ip-address
30 set-timer TIMER_UNAUTH 5
40 service-policy type service name FWPOL_BLOCKED_TRUSTED
50 service-policy type service name FWPOL_BLOCKED_REDIRECT
interface GigabitEthernet0/1
ip address dhcp
ip nat outside
media-type rj45
speed auto
duplex auto
no negotiation auto
interface GigabitEthernet0/2
no ip address
shutdown
media-type rj45
speed auto
duplex auto
no negotiation auto
no ip address
media-type rj45
speed auto
duplex auto
no negotiation auto
encapsulation dot1Q 10
ip address 10.1.0.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/3.250
encapsulation dot1Q 250
ip address 10.1.10.1 255.255.255.0
ip nat inside
ip flow ingress
ip flow egress
service-policy type control CTRL_IPOE
ip subscriber routed
initiator unclassified ip-address
ip nat translation timeout 300
ip nat translation tcp-timeout 12000
ip nat translation pptp-timeout 12000
ip nat translation udp-timeout 60
ip nat translation finrst-timeout 10
ip nat translation syn-timeout 10
ip nat translation icmp-timeout 10
ip nat translation port-timeout tcp 80 180
ip nat translation port-timeout tcp 8080 180
ip nat translation port-timeout tcp 1600 180
ip nat translation port-timeout tcp 110 180
ip nat translation port-timeout tcp 25 180
ip nat inside source list 10 interface GigabitEthernet0/1 overload
ip forward-protocol nd
ip flow-export source GigabitEthernet0/3
ip flow-export version 5
ip flow-export destination 10.1.0.2 9996
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
ip access-list extended ACL_ACCEPT
permit ip any any
ip access-list extended ACL_BLOCKED_REDIRECT
deny ip any host 10.1.0.2
deny ip host 10.1.0.2 any
permit tcp any any eq www
deny ip any any
ip access-list extended ACL_BLOCKED_TRUSTED
permit udp any any eq domain
permit ip any host 10.1.0.2
permit ip host 10.1.0.2 any
ip access-list extended ACL_NEGBAL_REDIRECT
deny ip any any
ip access-list extended ACL_NEGBAL_TRUSTED
ip access-list extended ACL_NOSHAPE
access-list 10 permit 10.1.0.0 0.0.0.255
access-list 23 permit 10.1.0.0 0.0.0.255
radius-server attribute 44 include-in-access-req default-vrf
radius-server vsa send cisco-nas-port
radius-server vsa send authentication
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 600 0
logging synchronous
transport input ssh
ntp master 3
ntp update-calendar
ntp server ntp2.stratum2.ru
ntp server ntp3.stratum2.ru
ntp server time-a.nist.gov prefer
end
Edited by Andrey75
это требует у вас пароль пользователя на авторизацию
20 authorize aaa list AAA_LIST_IPOE password > servicemode < identifier source-ip-address
добавте атрибуты
radius-server attribute 44 extend-with-addr
radius-server attribute 8 include-in-access-req
radius-server attribute 32 include-in-accounting-req
radius-server attribute 55 include-in-acct-req
radius-server attribute 31 mac format unformatted
radius-server vsa send accounting
Edited by alexaaa
добавте атрибуты
не помогло, в логах тоже ошибка авторизации
ip/servicemode
рабочий вариант
class-map type traffic match-any CM_T_NoMoney_PASS
match access-group input name CM_T_NoMoney_PASS
match access-group output name CM_T_NoMoney_PASS
class-map type traffic match-any CM_T_NoMoney_REDIRECT_WWW
match access-group input name CM_T_NoMoney_REDIRECT_WWW
class-map type traffic match-any CM_T_NoMoney_REDIRECT_DNS
match access-group input name CM_T_NoMoney_REDIRECT_DNS
class-map type traffic match-any CM_ANY
match access-group input name CM_T_ANY
match access-group output name CM_T_ANY
class-map type traffic match-any CM_ANY6
match access-group input name CM_T_ANY6
match access-group output name CM_T_ANY6
class-map type traffic match-any CM_T_NoMoney_PASS_HTTPS
match access-group input name CM_T_NoMoney_PASS_HTTPS
match access-group output name CM_T_NoMoney_PASS_HTTPS
class-map type control match-all CM_C_IPoE_RTIMEOUT_REAUTH
match timer IPoE_RTIMEOUT_REAUTH
class-map type control match-all CM_C_IPoE_REJECT_REAUTH
match timer IPoE_REJECT_REAUTH
policy-map type service NoMoney10
10 class type traffic CM_T_NoMoney_PASS
class type traffic default in-out
drop
policy-map type service NoMoney500
500 class type traffic CM_T_NoMoney_REDIRECT_WWW
redirect to group NoMoney
drop
policy-map type service NoMoney510
510 class type traffic CM_T_NoMoney_REDIRECT_DNS
redirect to group NoMoneyDNS
drop
policy-map type service Internet
100 class type traffic CM_ANY
drop
policy-map type service NoMoney400
400 class type traffic CM_T_NoMoney_PASS_HTTPS
police input 128000
police output 128000
drop
policy-map type control IPoE
class type control CM_C_IPoE_RTIMEOUT_REAUTH event timed-policy-expiry
class type control CM_C_IPoE_REJECT_REAUTH event timed-policy-expiry
10 authorize aaa list IPOE password ciscoo identifier source-ip-address
20 set-timer IPoE_REJECT_REAUTH 1
30 service-policy type service aaa list IPOE name NoMoney10
34 service-policy type service aaa list IPOE name NoMoney400
40 service-policy type service aaa list IPOE name NoMoney500
50 service-policy type service aaa list IPOE name NoMoney510
class type control always event service-stop
1 service-policy type service unapply identifier service-name
class type control always event session-restart
1 set-timer IPoE_RTIMEOUT_REAUTH 1
10 service-policy type service aaa list IPOE name NoMoney10
14 service-policy type service aaa list IPOE name NoMoney400
20 service-policy type service aaa list IPOE name NoMoney500
30 service-policy type service aaa list IPOE name NoMoney510
у Вас "10 authorize aaa list IPOE password ciscoo identifier source-ip-address"
У меня "20 authorize aaa list AAA_LIST_IPOE password servicemode identifier source-ip-address"
где брать этот пароль на радиусе?
в логах радиуса биллинга ошибка
Auth: Login incorrect: [10.1.10.21/servicemode]
Edited by Andrey75
СПАСИБО alexaaa!
Поставил пароль абоненту servicemode , абонент авторизуется.
интернета нет, подскажите по конфигу где копать?
выставите приоритеты классам
СПАСИБО alexaaa!
опять же СПАСИБО
не могу понять как выдавать ip с 30 маской?
и возможен редирект, если нет авторизации по радиусу
Edited by Andrey75
Если рад-сервер признается мертвым то абонентов должно выпускать в инет. Вы обращались в ТП биллинга?
  • 3 weeks later...
помогите с редиректом при не авторизованном абоненте
конфиг
redirect server-group RSG_NEGBAL_REDIRECT
server ip 10.1.0.2 port 442
redirect server-group RSG_BLOCKED_REDIRECT
server ip 10.1.0.2 port 444
redirect server-group RSG_RADIUS_REDIRECT
server ip 10.1.0.2 port 440
ip ssh version 1
class-map type traffic match-any CLS_RADIUS_REDIRECT
match access-group input name ACL_RADIUS_REDIRECT
policy-map type service FWPOL_ACCEPT
service local
class type traffic CLS_ACCEPT
policy-map type service FWPOL_NEGBAL_TRUSTED
service local
class type traffic CLS_NEGBAL_TRUSTED
policy-map type service FWPOL_NEGBAL_REDIRECT
service local
class type traffic CLS_NEGBAL_REDIRECT
redirect to group RSG_NEGBAL_REDIRECT
drop
policy-map type service FWPOL_BLOCKED_TRUSTED
service local
class type traffic CLS_BLOCKED_TRUSTED
policy-map type service FWPOL_BLOCKED_REDIRECT
service local
class type traffic CLS_BLOCKED_REDIRECT
redirect to group RSG_BLOCKED_REDIRECT
drop
policy-map type service FWPOL_DEFAULT
service local
10 class type traffic CLS_ACCEPT
police input 512000
police output 512000
policy-map type service FWPOL_NOSHAPE
class type traffic CLS_NOSHAPE
police input 90000000
police output 90000000
policy-map type service FWPOL_RADIUS_REDIRECT
service local
class type traffic CLS_RADIUS_REDIRECT
redirect to group RSG_RADIUS_REDIRECT
10 authorize aaa list AAA_LIST_IPOE password adminIPoE identifier source-ip-address
20 set-timer TIMER_UNAUTH 1
30 service-policy type service name FWPOL_ACCEPT
40 service-policy type service name FWPOL_NEGBAL_TRUSTED
50 service-policy type service name FWPOL_NEGBAL_REDIRECT
60 service-policy type service name FWPOL_BLOCKED_TRUSTED
70 service-policy type service name FWPOL_BLOCKED_REDIRECT
80 service-policy type service name FWPOL_RADIUS_REDIRECT
permit ip any any
deny ip any any
ip access-list extended ACL_NAT
permit ip any 10.1.10.0 0.0.0.255
permit ip 10.1.10.0 0.0.0.255 any
deny ip any any
ip access-list extended ACL_RADIUS_REDIRECT
deny ip any any
ip access-list extended WIFIGainy
permit ip any any
Edited by Andrey75
где у меня ошибка? ПОМОГИТЕ!
KharinoIPoE#show subscriber session
Codes: Lterm - Local Term, Fwd - forwarded, unauth - unathenticated, authen -
authenticated, TC Ct. - Number of Traffic Classes on the main session
Current Subscriber Information: Total sessions 47
Uniq ID Interface State Service Up-time TC Ct. Identifier
46 IP authen Lterm 3d00h 2 10.1.10.52
988 IP authen Lterm 3d00h 2 10.1.10.106
312 IP unauthen Attempting 00:00:00 0 172.24.7.202
1031 IP authen Lterm 2d23h 2 10.1.10.64
1040 IP authen Lterm 1d00h 2 172.24.0.77
998 IP authen Lterm 1d00h 2 10.1.10.130
764 IP authen Lterm 1d21h 2 172.24.0.73
733 IP authen Lterm 1d21h 2 10.1.10.49
749 IP authen Lterm 1d21h 2 10.1.10.20
10 IP authen Lterm 2d05h 2 10.1.10.61
305 IP unauthen Lterm 22:33:30 2 172.24.7.200
303 IP unauthen Lterm 23:29:50 0 172.24.7.201
1038 IP authen Lterm 2d09h 2 10.1.10.34
1036 IP authen Lterm 2d11h 2 10.1.10.109
996 IP authen Lterm 2d10h 2 10.1.10.103
1034 IP authen Lterm 2d20h 2 10.1.10.85
991 IP authen Lterm 2d21h 2 10.1.10.82
956 IP authen Lterm 2d12h 2 10.1.10.58
1032 IP authen Lterm 2d22h 2 10.1.10.16
473 IP authen Lterm 2d22h 2 10.1.10.115
835 IP authen Lterm 3d00h 2 172.24.0.69
816 IP authen Lterm 3d00h 2 10.1.10.94
825 IP authen Lterm 3d00h 2 10.1.10.19
831 IP authen Lterm 3d01h 2 10.1.10.5
826 IP authen Lterm 3d00h 2 10.1.10.124
829 IP authen Lterm 3d00h 2 10.1.10.100
827 IP authen Lterm 3d01h 2 10.1.10.55
811 IP authen Lterm 3d01h 2 10.1.10.127
823 IP authen Lterm 3d01h 2 10.1.10.37
820 IP authen Lterm 3d01h 2 10.1.10.79
828 IP authen Lterm 3d00h 2 10.1.10.67
806 IP authen Lterm 3d01h 2 10.1.10.31
821 IP authen Lterm 3d01h 2 10.1.10.121
822 IP authen Lterm 3d01h 2 10.1.10.70
817 IP authen Lterm 3d01h 2 10.1.10.135
815 IP authen Lterm 3d01h 2 10.1.10.118
810 IP authen Lterm 3d01h 2 10.1.10.22
819 IP authen Lterm 3d01h 2 10.1.10.136
813 IP authen Lterm 3d01h 2 10.1.10.76
809 IP authen Lterm 3d01h 2 10.1.10.131
814 IP authen Lterm 3d01h 2 10.1.10.7
808 IP authen Lterm 3d01h 2 10.1.10.15
818 IP authen Lterm 3d01h 2 10.1.10.88
800 IP authen Lterm 3d01h 2 10.1.10.138
807 IP authen Lterm 3d01h 2 10.1.10.140
804 IP authen Lterm 3d01h 2 10.1.10.97
812 IP authen Lterm 3d01h 2 10.1.10.40
KharinoIPoE#show subscriber session uid 312
KharinoIPoE#
ip 172.24.0.202 присваивает биллинг без привязки к мак адресу.
как редиректить такой ip
Уверен что биллинг присваивает адреса корректно. Судя по всему вы не используете ни мак-привязку, ни опцию82. Адреса выдает ICS-DHCP и настраивается он через вебку биллинга
Фраза "как редиректить такой ip" предполагает что биллинг выдает "плохой, неправильный" адрес который невозможно редиректить. Откройте конфиг схемы, почитайте его и сравните с тем что у Вас на оборудовании
