Здравствуйте!
Не срабатывает выдача адресов согласно классу ( порту )
В чем проблемы? помогите люди добрые
debian 7 wheezy
isc-dhcp-server ( dhcp3 )
Имею такой вот конфиг ( тестовый вариант )
option domain-name "foo.com";
local-address 192.168.254.249;
option subnet-mask 255.255.0.0;
default-lease-time 60000;
max-lease-time 62000;
subnet 192.168.0.0 netmask 255.255.0.0 {
 option broadcast-address 192.168.255.255;
 class "fixed6" {
       match if  binary-to-ascii(16, 8, ":", substring(option agent.remote-id, 2, 6)) = "0:22:B0:63:43:8F"
		and	binary-to-ascii (10, 8, "/", suffix ( option agent.circuit-id, 2)) = "0/1";
 pool {
       range 192.168.30.54;
       allow members of "fixed6";
 class "fixed7" {
		and	binary-to-ascii (10, 8, "/", suffix ( option agent.circuit-id, 2)) = "0/2";
 pool {
       range 192.168.30.55;
       allow members of "fixed7";
 pool {
option domain-name-servers bogus.foo.com;
range 192.168.30.15 192.168.30.20;
default-lease-time 50000;
if exists agent.circuit-id
 log (info, concat("Lease for ",
               binary-to-ascii (10, 8, ".", leased-address),
               " is connected to interface ",
               suffix ( option agent.circuit-id, 2)),
               " (add 1 to port number!), VLAN ",
               binary-to-ascii (10, 16, "",
               substring( option agent.circuit-id, 2, 2)),
               " on switch ",
               substring( option agent.remote-id, 2, 6))));
               " raw option-82 info is CID: ",
               binary-to-ascii (10, 8, ".", option agent.circuit-id),
               " AID: ",
               binary-to-ascii(16, 8, ".", option agent.remote-id)));
Настройки коммутатора des 3010g
DES-3010G:4#show dhcp_relay
Command: show dhcp_relay
DHCP/BOOTP Relay Status         : Enabled
DHCP/BOOTP Hops Count Limit     : 4
DHCP/BOOTP Relay Time Threshold : 0
DHCP Vendor class identifier option 60 State: Disabled
DHCP Client identifier option 61 State: Disabled
DHCP Relay Agent Information Option 82 State  : Enabled
DHCP Relay Agent Information Option 82 Check  : Disabled
DHCP Relay Agent Information Option 82 Policy : Replace
Interface     Server 1         Server 2         Server 3         Server 4
System        192.168.254.249
Получаем вот такой лог
Jul 25 03:11:11 mail dhcpd: DHCPREQUEST for 192.168.30.16 from 30:85:a9:b1:fc:90 via eth3
Jul 25 03:11:11 mail dhcpd: DHCPACK on 192.168.30.16 to 30:85:a9:b1:fc:90 (Hostname Unsuitable for Printing) via eth3
Jul 25 03:11:11 mail dhcpd: Lease for 192.168.30.16 is connected to interface 0/2 (add 1 to port number!), VLAN 1 on switch 0:22:b0:63:43:8f
Jul 25 03:11:11 mail dhcpd: Lease for 192.168.30.16 raw option-82 info is CID: 0.4.0.1.0.2 AID: 0.6.0.22.b0.63.43.8f
Jul 25 03:11:11 mail dhcpd: DHCPREQUEST for 192.168.30.16 from 30:85:a9:b1:fc:90 (Hostname Unsuitable for Printing) via 192.168.151.41
Jul 25 03:11:11 mail dhcpd: DHCPACK on 192.168.30.16 to 30:85:a9:b1:fc:90 (Hostname Unsuitable for Printing) via 192.168.151.41
Там в МАКах буковки маленькие должны быть в операциях match, не?
В идентификаторе в конфиге дхцп?
Ну да. Вот тут:
Напомните, что значит 2, 6? В свое время я использовал 2, 32:
#user50767
class "10-99-140-12:21:USER"          { match if (substring(option agent.remote-id,2,32)="10.99.140.12" and binary-to-ascii(10,8,"",suffix(option agent.circuit-id,1))="21"); }
P.S. RID ставили равным IP-адресу коммутатора.
Edited by xcme
В данный момент я добавился выдачи адресов согласно классу,но почему-то происходит следующее:
И так он до бесконечности выдает и сбрасывает,выдает и сбрасывает.
ddns-update-style interim;
ignore client-updates;
class "matrosova43p2" {
match if option agent.circuit-id = "Vlan1+Ethernet1/8" and option
agent.remote-id=00:03:0f:40:3d:32;
match if option agent.circuit-id = "Vlan1+Ethernet1/7" and option
option routers 192.168.102.2;
option domain-name "example.com.cn";
option domain-name-servers 192.168.10.3;
authoritative;
pool {
range 192.168.102.21 192.168.102.50;
default-lease-time 86400; #24 Hours
max-lease-time 172800; #48 Hours
allow members of "matrosova43p2";
pool {
range 192.168.102.51 192.168.102.80;
default-lease-time 43200; #12 Hours
max-lease-time 86400; #24 Hours
Aug  2 01:32:39 mail dhcpd: DHCPNAK on 192.168.102.21 to 30:85:a9:b1:fc:90 via eth3
Aug  2 01:32:39 mail dhcpd: DHCPDISCOVER from 30:85:a9:b1:fc:90 via eth3: network 192.168.0.0/16: no free leases
Aug  2 01:32:39 mail dhcpd: DHCPREQUEST for 192.168.102.21 (192.168.254.249) from 30:85:a9:b1:fc:90 via 192.168.1.71
Aug  2 01:32:39 mail dhcpd: DHCPACK on 192.168.102.21 to 30:85:a9:b1:fc:90 (Hostname Unsuitable for Printing) via 192.168.1.71
lease 192.168.102.21 {
 starts 0 2015/08/02 05:31:24;
 ends 1 2015/08/03 05:31:24;
 cltt 0 2015/08/02 05:31:24;
 binding state active;
 next binding state free;
 rewind binding state free;
 hardware ethernet 30:85:a9:b1:fc:90;
 uid "\0010\205\251\261\374\220";
 option agent.circuit-id "Vlan1+Ethernet1/8";
 option agent.remote-id 0:3:f:40:3d:32;
 ends 0 2015/08/02 05:31:24;
 tstp 0 2015/08/02 05:31:24;
 binding state free;
Edited by stealallsock
