Здравствуйте!
Вчера с НАГа привезли сабджевый коммутатор.
Требуется от него тупая агрегация.
Версия ПО коммутатора:
Beta-B52X#sh ver
Product Name: Beta-B52X
Hardware Version: A.03
Bootstrap Version: 5.2.1
Software Version: NOS_1.2.1639
PCB Version: A.1
FPGA Version: --
CPLD Version: 1.1
NOS Version: --
BOM Version: A1.2
Compiled May 08 2015, 12:42:04
System MacAddress: F8F0.8271.33EF
Serial number: 140207000603S15527S0092G
128 M bytes DRAM
32 M bytes Flash Memory
Конфиг:
Beta-B52X#sh running-config
System current configuration:
!command in view_mode
!command in config_mode first-step
create vlan 5,100-500 active
!command in aclmap_mode
!command in enable_mode
enable encrypt-password crS31vC89mHszw+wqPWJ7Q==
user name admin encrypt-password p0LmuBIy4pNnQg/1T8dZOw== privilege 15
!command in region_mode
!command in ip igmp profile mode
!command in evc mode
!command in aggregation_mode
!command in qos mapping mode
!command in wred mode
!command in l2cpprofile_mode
!command in sla thresholdprofile_mode
!command in port_mode
interface port 1
switchport trunk native vlan 5
switchport mode trunk
interface port 2
interface port 3
interface port 4
switchport access vlan 5
interface port 5
interface port 6
interface port 7
interface port 8
interface port 9
interface port 10
interface port 11
interface port 12
interface port 13
interface port 14
interface port 15
interface port 16
interface port 17
interface port 18
interface port 19
interface port 20
interface port 21
interface port 22
interface port 23
interface port 24
interface port 25
interface port 26
interface port 27
interface port 28
interface port 29
interface port 30
!command in vlan configuration mode
vlan 5
name managed
!command in dhcp-pool mode
!command in dhcp6-pool mode
!command in ip interface mode
interface ip 0
ip vlan 5
ip address 10.107.8.10 255.255.255.0
ipv6 address dhcp
!command in loopback interface mode
!command in traffic policer mode
!command in cmap_mode
!command in pmap_mode
!command in bandwidth profile mode
!command in hcos_mode
!command in hvlan_mode
!command in e_service_mode
system mtu 10218
management-port ip address 192.168.0.1 255.255.255.0
ip default-gateway 10.107.8.1
loopback-detection mode vlan-based
loopback-detection down-time 360
loopback-detection enable port-list 1-47,49-51
loopback-detection loop discarding port-list 1-47
ntp server 10.107.8.1 version v2
!command in service_mode
После установки в стойку, и подключении SFP модулей начал тупить терминал, - после ввода любой команды перестал возвращать результат выполнения оной. При этом зависала терминальная сессия, но не сбрасывалась. Можно было повторно залогиниться но результат опять такой же. Даже по COM порту такая же ситуация. При этом у пользователей интернет работал в их вланах, т.е. он их пропускал.
Когда вынули все модули и ребутнули все стало просто замечательно - и телнет и ssh заработал и ком порт раздуплился. В чем трабл?
Такая же конфигурация работает на двух х900 аллиедах, но увы заканчиваются порты. Хотели заменить их этой чудо железякой...
Edited by Pharaoh
IP интерфейса управления и шлюза из сильно разных сетей - ИМХО неправильно.
Может из-за этого девайс и тупит по управлению?
Не думаю, что это как то коррелирует. Тем паче, как я понял этот 192 адрес доступен только из порта управления на самой железке который. Я им управлял через транковый порт в 5м влане на Layer3 интерфейсе.
Edited by Pharaoh
путаете горячее с красным. менеджмент - это отдельный порт, не маршрутизируемый. а для сетевого управления на этой железеке висит
ip vlan 5
В чем трабл?
Чудеса с распознованием китайского idprom и ddm в процессе первой вставки. Этим очень многие грешат.
Есть ли, какое-то решение? Была надежда на этот свитч.
Перевоткнуть проблемную сфп, или заменить ее. а поймать ее относительно просто - переставлять сфп не сразу, а выдерживая интервал в 5-10 секунд и параллельно отслеживать состояние коммутатора. Проблемную сфп можно перешить на более приличную.
Действительно, не углядел с первого захода, что у железки есть oob менеджмент на отдельном порту.
к слову, с момента написания мною обзора тестирования http://forum.nag.ru/forum/index.php?showtopic=101500
железка в продакшне еще ни разу не вызвала ни одного нарекания в эксплуатации.
Beta-B52X#sh version
Hardware Version: A.02
Software Version: NOS_1.2.241
PCB Version: A.1
FPGA Version: --
CPLD Version: 1.0
NOS Version: --
BOM Version: A1.2
Compiled Jan 15 2014, 10:24:58
System MacAddress: F8F0.8271.1213
Serial number: 140207000602B14126B0002S
128 M bytes DRAM
System uptime is 120 days, 10 hours, 3 minutes
как-то так.
  • 4 weeks later...
Четыре модуля воткнули с клиентами:
Beta-B52X(config)#show cpu-utilization dynamic
CPU threshold trap enable: Disable
Rising threshold: 100
Fallingthreshold: 1
Trap transfer observation interval(second): 60
Dynamic statistics period: 1 second
Last 1 second CPU utilization: 67%
Last 5 seconds CPU utilization: 35%
Total CPU utilization: 11%
Вот эта строчка прыгает от 16 до 70%
Сделал по совету саппорта:
transceiver ddm disable
Это нормально? И как выяснить, что его так грузит?
В Аллиедах не было такой загрузки...
Edited by Pharaoh
Если честно, жесть, у меня эти показатели стабильно на низком уровне:
Last 1 second CPU utilization:     19%
Last 5 seconds CPU utilization:    17%
Last 1 minute CPU utilization:     14%
Last 10 minutes CPU utilization:   15%
Last 2 hours CPU utilization:      15%
Total CPU utilization:             15%
стоит покрутить дебаг, заодно покрутить "защитные" конструкции (storm-control, igmp snooping/filter, multicast filter и т.д.)
Хм, вот типичная статистика по одному из портов:
Speed during 2 seconds Statistics:
Interface: port2
Input Normal Statistics:
InOctets: 14,925,730,838
InUcastPkts: 33,172,309
InMulticastPkts: 41,328
InBroadcastPkts: 32,043
Output Normal Statistics:
OutOctets: 48,834,975,637
OutUcastPkts: 44,818,791
OutMulticastPkts: 144,390
OutBroadcastPkts: 2,100,215
Bit Statistics:
Ingress Bits: 119,405,846,704
Egress Bits: 390,679,805,096
Ingress Speed(bps): 4,876,535
Egress Speed(bps): 9,976,811
Ingress Speed(pps): 1,307
Egress Speed(pps): 1,770
Bandwidth Utilization during 2 senconds Statistics:
Ingress Bandwidth Utilization: 0
Egress Bandwidth Utilization: 0
Please press <Ctrl+C> to stop.
Может, что-то посоветуете?
  • 2 weeks later...
Я вот сейчас на этапе выбора подобной железки B52X и меня напрягают подобные тикеты.
Ни что не мешает взять железку на тест ;) у себя уже 6шт таких расставил и пока тьфу тьфу тьфу все гладко.
Сегодня пересоздал заявку. Советовали вот это transceiver ddm disable
Не помогло. Пока не втыкаем другие модули, боимся, что поляжет.
  • 1 year later...
SW_1#show run
syscli.c LINE 1403: Can not alloc memory
Кто-нибудь сталкивался с подобным на данном коммутаторе?
По консоли цепляться не пробовал, так как коммутатор на узле стоит. Перезагружать тоже побаиваюсь
  • 2 weeks later...
