Добрый день!
Помогите с настройкой msdp.
Отдаем провайдеру мультикаст по пиму, настроен msdp, mbgp не используем
Проблема в том у оператора которому мы отдаем проблемы.
Наша циска
3750X-12SE-BGP#sho running-config | include msdp
ip msdp peer 1.1.1.2 connect-source Vlan2001 remote-as 31133
ip msdp sa-filter out 1.1.1.2 route-map deny
ip msdp peer 10.255.253.1 connect-source Loopback0 remote-as 65001
ip msdp cache-sa-state
ip msdp originator-id Loopback0
ip msdp rpf rfc3618
interface Vlan2001
ip address 1.1.1.1 255.255.255.252
ip pim bsr-border
ip pim sparse-mode
ip igmp access-group deny
load-interval 30
interface Vlan2003
description IPTV-Rline
ip address 10.255.253.2 255.255.255.252
ip pim bsr-border
ip pim sparse-mode
load-interval 30
ip pim rp-address 176.115.136.5 IPTV override
ip pim bsr-candidate Loopback0 0
ip pim rp-candidate Loopback0 group-list mcACL-HITV priority 10
Его экстрим
# Module pim configuration.
configure pim add vlan "IPTV" sparse
configure pim timer 30 60 vlan "IPTV"
configure pim vlan "IPTV" trusted-gateway "none"
configure pim crp vlan "IPTV" "rp-list" 0
configure pim vlan "IPTV" shutdown-priority 1024
configure pim vlan "IPTV" dr-priority 1
configure pim vlan "IPTV" border
enable pim
configure pim crp timer 60
configure pim dense-neighbor-check on
configure pim register-suppress-interval 60 register-probe-interval 5
configure pim register-checksum-to exclude-data
configure pim register-rate-limit-interval 0
configure pim spt_threshold 0
configure pim cbsr vlan "IPTV" 1
configure pim state-refresh timer source-active-timer 210
configure pim state-refresh timer origination-interval 60
configure pim state-refresh ttl 16
configure pim crp static 10.255.253.1 "rp-list" 0
X670-Core1.3 #
# Module msdp configuration.
create msdp peer 10.255.253.2 remote-as 41743 vr VR-Default
configure msdp peer 10.255.253.2 timer keep-alive 60 hold-time 75 vr VR-Default
configure msdp peer 10.255.253.2 source-interface any vr VR-Default
configure msdp peer 10.255.253.2 description vr VR-Default
configure msdp peer 10.255.253.2 sa-limit 0 vr VR-Default
configure msdp peer 10.255.253.2 ttl-threshold 0 vr VR-Default
enable msdp peer 10.255.253.2 process-sa-request vr VR-Default
configure msdp peer 10.255.253.2 default-peer vr VR-Default
configure msdp peer 10.255.253.2 sa-filter in none vr VR-Default
configure msdp peer 10.255.253.2 sa-filter out none vr VR-Default
configure msdp peer 10.255.253.2 mesh-group none vr VR-Default
configure msdp peer 10.255.253.2 password none vr VR-Default
enable msdp peer 10.255.253.2 vr VR-Default
configure msdp originator-id 10.255.253.1 vr VR-Default
configure msdp sa-cache-server 10.255.253.2 vr VR-Default
# маршрут руками прописали до источника
X670-Core1.4 # sh iproute | include 93.100
#s   93.100.195.0/24    10.255.253.2    1    UG---S-um--f- IPTV 6d:0h:12m:19s
Mtrace до исчтоника с моей циски
#mtrace 93.100.195.70
Type escape sequence to abort.
Mtrace from 93.100.195.70 to 37.29.105.198 via RPF
From source (?) to destination (?)
Querying full reverse path... * switching to hop-by-hop:
0  1.1.1.1
-1  1.1.1.1 PIM  [93.100.195.64/27]
-2  1.1.1.2 PIM  [default]
-3    * 10.222.5.109
mtrace с его extreme
* X670-Core1.7 # mtrace source 93.100.195.70
Mtrace from 93.100.195.70 to Self via 0.0.0.0
 0   10.255.253.1
-1   10.255.253.1     PIM thresh^ 0   93.100.195.0/24
-2   10.255.253.2     PIM thresh^ 0   93.100.195.64/27     No space in packet
 3   1.1.1.2
ps
адреса заменены некоторые
Ах, да. не показывает у оператора за экстримом тв.
Вернее сказать иногда показывает один канал, а другой может не показывать, хотя источник один.
Канал не показывает
Поэтому нет принадлежнасти к влану
[23.04.2015 12:34:16] Andrey Aytul: а вот что происходит при подключении к 1 каналу
[23.04.2015 12:34:18] Andrey Aytul: [0000] 239.195.32.1    10.255.253.1 (WR)  (null)   Sparse
[0000] 239.195.32.1    93.100.195.70 ( )  IPTVSparse
Канал показывает
[0000] 239.195.32.5    10.255.253.1 (WR)  (null)   Sparse
[0001] 239.195.32.5    93.100.195.70 (S)  IPTVSparse
Mbgp не настроен между циской и экстримом, на экстриме прописаны маршруты до источников в мою сторону.
Подкорректировал первое сообщение , добавил конфиги недостающие.
А статических маршрутов не хватает для замены mbgp?
Я так понимаю мне ничего не мешает настроить только multicast bgp, без unicast?
Кстати в мануале на экстрим посмотрел примеры, там везде рекомендуют loopback интерфейсы использовать, может спасет?
multicast bgp будет достаточно, хотя, от греха подальше я б и юникастом спустил бы сурсовый адрес.
loopback интерфейсы нужны для anycast rp, без которого, кстати говоря, может все и не работает.
То есть лучше с его стороны поднять лупбек, а с нашей стороны еще и переделать сессию с нашим провайдером на лупбек.
Сессия с нашим поставщиком,
было так:
сделать так:
ip msdp peer 1.1.1.2 connect-source Loopback0 remote-as 31133
Если полоса позволяет, не проще уйти от msdp+pim на статическое выдавливание всего к Extreme.
И со стороны Extreme рассматривать задачу как бы это multicast идет от стримов(т.е. серверов)
др*чить на конфиги это неправильный метод траблшутинга.
я так и не понял где проблема и что происходит. есть подписка на экстриме, но нет на циске? есть подписка везде, но не идет трафик? еще что-то?
а если сделать статик джойн на экстриме на все группы, а если софт на экстриме обновить, а если... в общем "доктор, у меня это"
Включительно дебаг на цыске и дебаг логи на экстриме. Мы на экстриме делаем на lo интерфейсе msdp, обычный bgp и pim rp. Наш пир сделал один Статик-роут до lo и всю логику на него направляет.
+100. Мы даже отдельный порт поднимаем под это если есть возможность. И еще и фильтры вешаю, где запрещаю весь rx. Тут у нас такие есть приниматели мультикаста (не буду показывать пальцем на именитых операторов), что только диву даешься!!! Это решение имеет один неоспоримый плюс - приехал с ноутом, запустил VLC, натыкал носом принимающую сторону, и уехал.
