Коллеги. Нужна помощь - не получается собрать Port-channel между 6509 и d-link 3052.
На d-link
show link_aggregation
Command: show link_aggregation
Link Aggregation Algorithm = MAC_source
Group ID : 1
Type : LACP
Master Port : 51
Member Port : 51-52
Active Port : 51
Status : Enabled
Flooding Port : 51
Total Entries : 1
порты в актив
show lacp_port
51 Active
52 Active
На циске
Router#sh run int gi1/46
Building configuration...
Current configuration : 212 bytes
interface GigabitEthernet1/46
switchport
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 11
switchport mode trunk
lacp rate fast
channel-protocol lacp
channel-group 1 mode active
end
Router#sh run int gi1/47
interface GigabitEthernet1/47
switchport
lacp rate fast
end
Router#sh run int po1
Current configuration : 138 bytes
interface Port-channel1
switchport
end
При этом 1 из портов шлёт больше пакетов
Router# show lacp count
LACPDUs Marker Marker Response LACPDUs
Port Sent Recv Sent Recv Sent Recv Pkts Err
Channel group: 1
Gi1/46 1880 1086 0 0 0 0 0
Gi1/47 2678 1086 0 0 0 0 0
show etherchan 1 det
Group state = L2
Ports: 2 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Gi1/46
Port state = Up Mstr In-Bndl
Channel group = 1 Mode = Active Gcchange = -
Port-channel = Po1 GC = - Pseudo port-channel = Po1
Port index = 0 Load = 0xFF Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Gi1/46 FA bndl 32768 0x1 0x1 0x12F 0x3F
Partner's information:
Partner Partner LACP Partner Partner Partner Partner Partner
Port Flags State Port Priority Admin Key Oper Key Port Number Port State
Gi1/46 FA bndl 1 0x0 0x33 0x34 0x3F
Age of the port in the current state: 0d:00h:13m:25s
Port: Gi1/47
Port state = Up Mstr Not-in-Bndl
Port-channel = null GC = - Pseudo port-channel = Po1
Port index = 0 Load = 0x00 Protocol = LACP
Local information:
Gi1/47 FA not-bnd 32768 0x1 0x1 0x130 0x7
Gi1/47 FA not-bnd 1 0x0 0x33 0x33 0x77
Age of the port in the current state: 3050584830d:14h:25m:39s
Port-channels in the group:
Port-channel: Po1 (Primary Aggregator)
Age of the Port-channel = 0d:03h:21m:34s
Logical slot/port = 14/1 Number of ports = 2
HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = LACP
Fast-switchover = disabled
Load share deferral = disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 FF Gi1/46 Active 8
Time since last port bundled: 0d:00h:00m:00s Gi1/47
Time since last port Un-bundled: 0d:00h:00m:00s Gi1/47
Last applied Hash Distribution Algorithm: Fixed
Уже и порты попробовал поменять -взял соседний свободный порт.. всё равно 1 из портов в
GigabitEthernet1/47 is up, line protocol is down (notconnect)
Перезагрузил d-link- порты поменялись местами, в смысле 47 в ап ушёл..а 46 в line protocol is down
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SXH8, RELEASE SOFTWARE (fc1)
Сделайте с одной стороны passive, с другой active.
Проблем между Cisco и D-Link в плане LACP не замечал ни разу.
"lacp rate fast" можете убрать.
lacp rate fast убирал. В результате 1 порт
SA, а 2 FA.
Причём если моргнуть линками то могут местами поменяться..
Убрал lacp rate fast
d-link сделал пассивом.
сделал shu/ no shu po1и физ линкам.
на мгновение оба порат ушли в P - bundled in port-channel..и тут же 1 из портов ушёл в stand-alone
Да если важно.. но не думаю что играет роль. Со стороны циски 2 sfp междных наговских
покажите снова:
sh runn int gi1/46
sh runn int gi1/47
sh runn int po1
sh etherchan po1 sum
А в логи циска ничего не пишет про mismatch чегонибудь ... ?
Ну и, как вариант, попробуйте коммутаторам актив/пассив местами поменять.
Вот тут было что-то про dlink, cisco, lacp и active/passive: http://www.dlink.ru/ru/faq/62/250.html
Да в общем-то так оно и сделано. Единственная разница - на портах входящих в LACP включен vlan со стороны длинка и на самом po со стороны циски
switchport
покажите снова:
sh runn int gi1/46
sh runn int gi1/47
sh runn int po1
Логи чистые. Их 1 делом смотрел.
Теперь уже в ПН выложу логи.
А так при no shu po1
1 из портов сразу в P - bundled in port-channel
2 порт сначала в
w - waiting to be aggregated
потом тк же на мгновение становится
P - bundled in port-channel и далее уже сваливается в
I - stand-alone
А так сильно не нравится что
show lacp count показывает сильно разные цифры в Sent по портам, и что 1 порт SA, а 2 FA.
stalker86,
А untagged vlan (любой) есть в на портах с lacp (ну или на самом lacp)? Попробуйте добавить - где-то я такое встречал.
Можно "глухой", который никуда больше не смотрит.
stalker86,
На длинке или на кошке?
stalker86,
И на циске (native) и на длинке (pvid), если не задан явно, то по-умолчанию всегда равен единице.
Сомневаюсь, что дело в этом.
Мне кажется, что где-то порты настроены по-разному. Может, действительно, pvid, stp, storm-control-ы ...
Просмотрите на обеих железках весь конфиг полностью и досконально.
Edited by g3fox
Странные проблемы у вас. Обычно никаких вопросов не возникает. Начните с обновления прошивки длинка, это может быть вероятной причиной.
Конфиги работающей связки ниже, правда свитч 3200-52 С1.
cisco (ws-x6748-ge-tx)
interface GigabitEthernet4/3
description - CORE-RACK:       OFFICE SWITCH 1    -
switchport
switchport trunk allowed vlan 666
channel-group 12 mode active
interface GigabitEthernet4/4
description - CORE-RACK:       OFFICE SWITCH 2    -
switchport
interface Port-channel12
description - CORE-RACK:       OFFICE SWITCH 2G   -
switchport
dlink
# LACP
config link_aggregation algorithm ip_source_dest
create link_aggregation group_id 1 type lacp
config link_aggregation group_id 1 master_port 51 ports 51-52 state enable
config lacp_port 1-50 mode passive
config lacp_port 51-52 mode active
Опять же, на 3120, это работает, если первый влан подан на этот порт. А если его нет - pvid нужно сменить на тот, который реально подан на порт. Я у себя ставлю пвид управляющего влана.
Если на 3028 сам lacp собрался, то значит все настройки впорядке. Но проверить всё же стоит, мож баг какой.
Кстати, да, у нас такая-же практика, пвидом делать управляющий влан. Но по другой причине: если пвидом будет какой-то левый влан, который никуда не выкинут - ломается stp.
Циска с почти ещё дефолтным конфигом. Завтра доберусь до железки выложу конфиг. d-link - stp отключал, да и если бы stp в логах была бы ругань как минимум.
dlink
# LACP
Да вот сам не ожидал тут проблем словить.
Конфиг циски почти пустой, d-link stp отключал, да и в логах тишина.
В глаза сильно бросается что на циске 1 порт в FA, а второй сваливается в SA
Прошивка d-link последняя.
Вопрос а vlan (который тегированный) Вы вешаете на оба интерфейса в аггрегации или только на тот, который мастер?
Надо на оба, но вроде бы если повесить на мастера, то он довесится сам. По крайней мере на 3120 так.
Настройки портов должны быть идентичны во всем. И pvid и набор вланов.
Да так и сделано. Собрал на d-link аггрегацию, повесил на порныт входящие в аггрегацию нужный vlan.
Остаётся ещё раз проверить версию прошивки и насвежую голву завтра ещё раз сравнить настройки портов. И разве что отресетить d-link попробовать
В общем помогло обновить прошивку до последней (2.94.B07, была 2.06) и отключение gvrp.
просто обновление прошивки было мало.
Теперь при падении 1 из линков теряется пакетика 3-5 и потом летим на 2 ноге.
Так оба порта стали активны в show link_agg ?
на длинке они и были в актив и в аггпегации.
Но циска не верила длинку :) и 1 порт выпадал в осадок на циске. Актив но не в бандлере.
Сейчас оба
Router#show etherchannel summ
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use N - not in use, no aggregation
f - failed to allocate aggregator
M - not in use, no aggregation due to minimum links not met
m - not in use, port not aggregated due to minimum links not met
u - unsuitable for bundling
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gi1/46(P) Gi1/47(P)
