Добрый день!
На коммутаторах SNR-S3650G-48S растут счётчики pause frame.
Пример:
Сделан сброс счётчиков на порту Ethernet1/0/11.
За 4 часа значение input счётчика Pause frame увеличилось с 0 до 2072.
Скорость передачи трафика на порту не поднималась выше 1,4 мбит/с (см. скрин во вложении)
Конфиг порта:
Interface Ethernet1/0/11
bandwidth control 307200 both
switchport mode trunk
switchport trunk allowed vlan 1;406;805
О коммутаторе:
#sh ver
SNR-S3650G-48S Device, Compiled on Nov 03 10:13:33 2014
CPU Mac f8:f0:82:10:1c:0d
Vlan MAC f8:f0:82:10:1c:0c
SoftWare Version 7.0.3.5(B0207.0019)
BootRom Version 7.1.5
HardWare Version 1.0.1
CPLD Version N/A
Serial No.:SW032610D610000187
Copyright (C) 2014 NAG LLC
All rights reserved
Last reboot is warm reset.
Uptime is 29 weeks, 5 days, 2 hours, 43 minutes
Интерфейс
#sh interface Ethernet1/0/11
Interface brief:
Ethernet1/0/11 is up, line protocol is up
Ethernet1/0/11 is layer 2 port, alias name is test, index is 11
Hardware is SFP, address is f8-f0-82-10-1c-0d
PVID is 1
MTU 1500 bytes, BW 1000000 Kbit
Time since last status change:2w-4d-3h-43m-5s (1568585 seconds)
Encapsulation ARPA, Loopback not set
Auto-duplex: Negotiation full-duplex, Auto-speed: Negotiation 1G bits
FlowControl is off, MDI type is auto
Transceiver info:
SFP found in this port, manufactured by OEM, on (null) 00 0.
Type is 1000BASE-LX. Serial number is SK130930130051.
Link length is 3000 m for Single Mode Fiber.
Nominal bit rate is 1300 Mb/s.
Laser wavelength is 1310 nm.
Statistics:
5 minute input rate 1672 bits/sec, 0 packets/sec
5 minute output rate 8428 bits/sec, 12 packets/sec
The last 5 second input rate 150 bits/sec, 0 packets/sec
The last 5 second output rate 7914 bits/sec, 13 packets/sec
Input packets statistics:
90950 input packets, 10269217 bytes, 0 no buffer
88698 unicast packets, 180 multicast packets, 0 broadcast packets
0 input errors, 0 CRC, 0 frame alignment, 0 overrun, 0 ignored,
0 abort, 0 length error, 2072 pause frame
Output packets statistics:
303433 output packets, 339803505 bytes, 0 underruns
235756 unicast packets, 30487 multicast packets, 37190 broadcast packets
0 output errors, 0 collisions, 0 late collisions, 0 pause frame
С Ethernet1/0/11 по оптике запущен DGS-1100-06/ME на котором Flow control отключён.
Есть и другие клиенты на чьих портах при аналогичной схеме подключения input счётчики Pause frame, у некоторых увеличиваются, а у некоторых остаются неизменными либо как у топикстартера незначительно увеличиваются.
