silvercaptain
Пользователи
  • Публикации
    6
  • Зарегистрирован
  • Посещение
Все публикации пользователя silvercaptain
  1. Смена брузера не помогает?
  2. rate-limit ? Router(config-if)#rate-limit input access-group 101 2010000 250000 250000 conform-action transmit exceed-action drop Router(config)#access-list 101 permit udp any any eq 80
  3. sm-sm7-c2960#sh ver | i cisco cisco WS-C2960-24TT-L (PowerPC405) processor (revision D0) with 61440K/4088K bytes of memory. sm-sm7-c2960(config-if)#switchport port-security maximum ? <1-8192> Maximum addresses
  4. Может проблемы именно с конкретным железом? у меня было уже штуки три ИОСА, ничего не глючит.. есть 4 штуки 2811 с данным модулем sm-glh-c2811#sh ver Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(23), RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright © 1986-2008 by Cisco Systems, Inc. Compiled Sat 08-Nov-08 21:58 by prod_rel_team ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1) sm-glh-c2811 uptime is 4 weeks, 2 days, 20 hours, 51 minutes System returned to ROM by Reload Command System restarted at 13:18:55 EET Tue Feb 10 2009 System image file is "flash:c2800nm-advipservicesk9-mz.124-23.bin" This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. Cisco 2811 (revision 53.50) with 247808K/14336K bytes of memory. Processor board ID FTX1241A1K0 6 FastEthernet interfaces 2 Serial(sync/async) interfaces 2 Low-speed serial(sync/async) interfaces 1 Virtual Private Network (VPN) Module 2 Voice FXS interfaces DRAM configuration is 64 bits wide with parity enabled. 239K bytes of non-volatile configuration memory. 62720K bytes of ATA CompactFlash (Read/Write) Configuration register is 0x2102 sm-glh-c2811#sh inv sm-glh-c2811#sh inventory NAME: "2811 chassis", DESCR: "2811 chassis" PID: CISCO2811 , VID: V06 , SN: FTX****** NAME: "4 Port FE Switch", DESCR: "4 Port FE Switch" PID: HWIC-4ESW , VID: V01 , SN: FOC***** NAME: "2nd generation two port FXS voice interface daughtercard", DESCR: "2nd generation two port FXS voice interface daughtercard" PID: VIC2-2FXS , VID: V01 , SN: FOC******* NAME: "WAN Interface Card - Serial 2T", DESCR: "WAN Interface Card - Serial 2T" PID: WIC-2T= , VID: 1.0, SN: ****** NAME: "WAN Interface Card - Serial 2A/S", DESCR: "WAN Interface Card - Serial 2A/S" PID: WIC-2A/S= , VID: 1.0, SN: ******* NAME: "PVDMII DSP SIMM with one DSP", DESCR: "PVDMII DSP SIMM with one DSP" PID: PVDM2-16 , VID: V01 , SN: FOC*******
