Может проблемы именно с конкретным железом?
у меня было уже штуки три ИОСА, ничего не глючит.. есть 4 штуки 2811 с данным модулем
sm-glh-c2811#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(23), RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2008 by Cisco Systems, Inc.
Compiled Sat 08-Nov-08 21:58 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
sm-glh-c2811 uptime is 4 weeks, 2 days, 20 hours, 51 minutes
System returned to ROM by Reload Command
System restarted at 13:18:55 EET Tue Feb 10 2009
System image file is "flash:c2800nm-advipservicesk9-mz.124-23.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco 2811 (revision 53.50) with 247808K/14336K bytes of memory.
Processor board ID FTX1241A1K0
6 FastEthernet interfaces
2 Serial(sync/async) interfaces
2 Low-speed serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2102
sm-glh-c2811#sh inv
sm-glh-c2811#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811 , VID: V06 , SN: FTX******
NAME: "4 Port FE Switch", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW , VID: V01 , SN: FOC*****
NAME: "2nd generation two port FXS voice interface daughtercard", DESCR: "2nd generation two port FXS voice interface daughtercard"
PID: VIC2-2FXS , VID: V01 , SN: FOC*******
NAME: "WAN Interface Card - Serial 2T", DESCR: "WAN Interface Card - Serial 2T"
PID: WIC-2T= , VID: 1.0, SN: ******
NAME: "WAN Interface Card - Serial 2A/S", DESCR: "WAN Interface Card - Serial 2A/S"
PID: WIC-2A/S= , VID: 1.0, SN: *******
NAME: "PVDMII DSP SIMM with one DSP", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16 , VID: V01 , SN: FOC*******
