UART1 output test ok
Uart init
mfid=00000001 devid=00002249
Found 1 x 2M flash memory
---RealTek(RTL8186)at 2005.06.21-18:13+0800 version 1.3c , CAMEO version v2.01.r
12 [16bit] (180MHz)
Jump to image start=0x80300000...
early printk enabled
Determined physical RAM map:
memory: 00800000 @ 00000000 (usable)
Initial ramdisk at: 0x80208000 (32848 bytes)
On node 0 totalpages: 2048
zone(0): 2048 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/ram console=0 ramdisk_start=0 noisapnp pci=nobios
179.40 BogoMIPS
Memory: 5768k/8192k available (1887k kernel code, 2424k reserved, 156
init, 0k highmem)
Dentry-cache hash table entries: 1024 (order: 1, 8192 bytes)
Inode-cache hash table entries: 512 (order: 0, 4096 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 2048 (order: 1, 8192 bytes)
check_wait... unavailable.
POSIX conformance testing by UNIFIX
bogomips: Initialized.
user_watchdog: Initialized.
led0: Initialized.
led1: Initialized.
sysmem: Initialized.
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
devfs: v1.10 (20020120) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x0
Serial driver version 6.02 (2003-03-12) with no serial options enabled
ttyS00 at 0x00c3 (irq = 3) is a rtl_uart1
state->flags=00000000
block: 64 slots per queue, batch=16
RAMDISK driver initialized: 16 RAM disks of 512K size 1024 blocksize
PPP generic driver version 2.4.2
PPP MPPE Compression module registered
PPP Deflate Compression module registered
PPP BSD Compression module registered
RealTek E-Flash System Driver. © 2002 RealTek Corp.
Found 1 x 2M Byte AMD AM29LV160DB at 0xbe000000
=> Scan for ROOT signature in flash from pos=0x000000
Founded at pos=0x0CFFF4
Checksumm ok for 0x0EC000 bytes calced=0x8F11, stored=0x8F11) Checksumm OK
. Use as ROOT partition (/dev/mtd1)
Reallocate partition for root size=0x0EC000 bytes
Creating 4 MTD partitions on "DiskOnChip Millennium":
0x00000000-0x000d0000 : "boot+cfg
0x000d0000-0x001c0000 : "root fs"
0x001e0000-0x00200000 : "TGZfs"
0x00000000-0x00200000 : "all_flash"
8186NIC Ethernet driver v0.1.0-NG (15.10.2008)
eth0: RTL8186-NIC at 0xbd200000, 00:01:02:03:04:05, IRQ 4
eth1: RTL8186-NIC at 0xbd300000, 04:05:06:07:08:09, IRQ 5
Check MII:phy 2, reg 31
0x0000e000
Check MII:phy 2, reg 26
0x00000000
Asic.revision=0x00000000
RTL8185 driver version 1.14 (2008-02-15)
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kby
Linux IP multicast router 0.06 plus PIM-SM
ip_conntrack version 2.1 (64 buckets, 512 max) - 312 bytes per conntrack
PPTP netfilter connection tracking: registered
ip_tables: © 2000-2002 Netfilter core team
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 32k freed
VFS: Mounted root (ext2 filesystem).
Freeing unused kernel memory: 60k freed
mount /proc file system ok!
mount /dev/mtd1 file system ok!
Kernel panic: No init found. Try passing init= option to kernel.
Enable Watch Dog to Reset whole system
лог запуска 700ap в чем проблема ???
