Проблемы с Микротиком Падение уровня
короче, полная лажа. база 433AH, only G, канал 2432, скан эфира в прикреплённом файле, export настроек wireless ниже.
/interface wireless security-profiles
set default authentication-types="" eap-methods=passthrough group-ciphers="" \
group-key-update=5m interim-update=0s mode=none name=default \
radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
static-sta-private-algo=none static-sta-private-key="" \
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=\
none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key="" \
wpa2-pre-shared-key=""
add authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip \
group-key-update=5m interim-update=0s mode=static-keys-required name=\
profile1 radius-eap-accounting=no radius-mac-accounting=no \
static-algo-0=104bit-wep static-algo-1=none static-algo-2=none \
static-algo-3=none static-key-0=тут ключ :) static-key-1=\
"" static-key-2="" static-key-3="" static-sta-private-algo=none \
static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=\
"" tls-certificate=none tls-mode=no-certificates unicast-ciphers=tkip \
wpa-pre-shared-key="" wpa2-pre-shared-key=""
/interface wireless
это магистраль
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=2.4ghz-onlyg \
basic-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=\
"" burst-time=disabled comment=magistral compression=no country=\
no_country_set default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=no disconnect-timeout=3s \
frame-lifetime=0 frequency=2492 frequency-mode=superchannel hide-ssid=no \
hw-retries=4 mac-address=мак адрес :) max-station-count=2007 mode=\
station mtu=1500 name=wlan2 noise-floor-threshold=default \
on-fail-retry-time=100ms periodic-calibration=default \
periodic-calibration-interval=60 preamble-mode=long \
proprietary-extensions=post-2.9.25 radio-name="kindiyka magistral" \
rate-set=configured scan-list=2492,2497,2502,2507,2512 security-profile=\
profile1 ssid=ssid_1 :) station-bridge-clone-mac=00:00:00:00:00:00 \
supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
supported-rates-b=11Mbps tx-power-mode=default update-stats-interval=\
disabled wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=\
100 wds-ignore-ssid=no wds-mode=disabled wmm-support=disabled
это раздача
set 1 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps basic-rates-b="" burst-time=\
disabled comment=razdacha compression=no country=no_country_set \
default-ap-tx-limit=0 default-authentication=no default-client-tx-limit=0 \
default-forwarding=no dfs-mode=none disable-running-check=no disabled=no \
disconnect-timeout=3s frame-lifetime=0 frequency=2432 frequency-mode=\
superchannel hide-ssid=no hw-retries=4 mac-address=мак адрес :) \
max-station-count=2007 mode=ap-bridge mtu=1500 name=wlan1-razdacha \
noise-floor-threshold=default on-fail-retry-time=100ms \
periodic-calibration=default periodic-calibration-interval=60 \
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=\
kindiyka-cnti rate-set=configured scan-list=default security-profile=\
default ssid=ssid_2 :) station-bridge-clone-mac=00:00:00:00:00:00 \
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps supported-rates-b="" \
tx-power-mode=default update-stats-interval=disabled wds-cost-range=\
50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no \
/interface wireless manual-tx-power-table
set wlan2 comment=magistral manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11M\
bps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17\
,54Mbps:17,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,\
HT20-8:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0,HT\
40-8:0"
set wlan1-razdacha comment=razdacha manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbp\
s:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,4\
8Mbps:17,54Mbps:17,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,H\
T20-7:0,HT20-8:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT4\
0-7:0,HT40-8:0"
/interface wireless nstreme
set wlan2 comment=magistral disable-csma=no enable-nstreme=no enable-polling=\
yes framer-limit=3200 framer-policy=none
set wlan1-razdacha comment=razdacha disable-csma=no enable-nstreme=no \
enable-polling=yes framer-limit=3200 framer-policy=none
/interface wireless access-list
add ap-tx-limit=0 authentication=yes client-tx-limit=0 comment=\
"arhangel (pc)" disabled=no forwarding=yes interface=wlan1-razdacha \
mac-address=мак клиента private-algo=none private-key="" \
private-pre-shared-key="" signal-range=-120.120
..... и ещё 5 похожих записей
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless connect-list
add area-prefix="" comment="" connect=yes disabled=no interface=wlan2 \
mac-address=мак адрес магистрали с другой стороны security-profile=profile1 signal-range=\
-120.120 ssid=""
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
максимум, что вижу по графикам - это 1.7 Мбит/с download на клиентов и 50 КБайт/с upload с клиентов (одновременно)... при этом пинг доходит до 3 сек., пропадания... уровни от клиентов от -50 до -75... клиенты D-Link G700, 2 из них conceptronik. одновременно работают 5 клиентов.
что за лажа? у кого такое было? может у кого-то лучшие показатели? кто что привязывал к микротику? лечится ли такое заменой клиентов на микротики или выравниванием уровней у всех или прошивкой всех в wive-NG?
Поделиться сообщением
Ссылка на сообщение
Поделиться на других сайтах
А попробуй запустить wireless sniffer и snooper. Что там на каналах тварится?
Ссылка на сообщение
Изменено пользователем ice_m
Ссылка на сообщение
Трудно сказать. Эфир почти нормальный. Местами проскакивают ориноки ТС.
Была такая же лажа. Но после того как поставил грозозащиту и заземлил там все - как-то само прекратилось.
Я смотрю, что карточки стоят R52. Они же 17Дб (64мВт). Может карточку стоит взять R52H. У нее на выходе около 400мВт. С пробывал с ней.
А антена какая стоит? И как долго? Может ее залило?
Ссылка на сообщение
По идее 17дБм - это 50мВт...
Антенну, кабель, всё меняли... заземление стоит... должно работать и на R52... почему пинги такие длинные, даже на клиентов в 600м от базовой? :(
Всё-таки грешу на пару клиентов с плохими уровнями и CCQ.. поедем на след. неделе к ним и попробуем улучшить связь... может и всем остальным полегчает... о результатах отпишусь...
R52H на разных частотах, на разных модуляциях и полосе канала имеет разные показатели... Она непредсказуема :( Лучше уже что-то от Ubiquty
Ссылка на сообщение
Может кто-то в сети флудит? Забивает канал. Был один прецендент - решил один клиент в локалку со спутника в мультикасте каналы транслировать. Убил все. А на МТ изоляция клиетов стоит (точно не помню, под опцией Hide SSID - forwarding)?
Ссылка на сообщение
Тестировал на столе связку: RB433AH (ap bridge, 2,4 Ghz G-only) - D-link G700 Conceptronik (station). Добился 70 попугаев с Д-линка (-55 dBm на Микротике показывает). Качаю... Вижу: 200 Кбит/с download и 70 Кбит/с upload... Игра с Data rates ничего не даёт (при зарезании 54/54 скорость падает в 10 раз)... Удивляюсь... А удивляюсь потому, что у реально подключённого клиента на расстоянии 2.3 км при уровне -75 на Edimax 7206APG были такие же результаты, только upload не выше 40 Кбит/с... Т.е. уровень, обстановка в эфире, кол-во клиентов не влияет вообще... Все эти дешёвые тд не дружат с микротиком... Разубедите меня, пожалуйста :)
Ссылка на сообщение
Откатись на 2.9.51 говорят иногда помогает.
Ссылка на сообщение
Router OS 2.9.51? А где её взять-то теперь? Стоит 3.14 та кот. на столе тестируется...
Даст ли какой-то результат, если перепрошить D-Link G700 в wive-ng?
Ссылка на сообщение
У сапорта спроси дадут. Надо пробивать а не спрашивать поможет или нет :)
Ссылка на сообщение
так и делаю :) смотри пост про перепрошивку концептроник в вайв :) может кто раньше ответит или совет дельный даст, чем я найду :)
Ссылка на сообщение
wive-ng вам подрежит уровень.
к сожалению только старая Wive. У меня на 3км 2мбита прокачивает....
надо настоле тестонуть,как раз есть и мтик и G700
Ссылка на сообщение
скачал торрентом с сайта микротика... но там пакеты как-то по другому называются :( ... all_packages_ns... wireless-crd-2.9.51.npk, wireless-crd-2.9.51-ns.npk ну и т.д.
малова-то... это максимум что она может?
протестируйте, пожалуйста, на столе... очень интересно сравнить результаты...
а можете старую wive скинуть?
Ссылка на сообщение
смотри на mipsbe.npk
Изменено пользователем yrida
Ссылка на сообщение
нет там такого :( есть образ mikrotik-2.9.51.iso ... на кот. есть файлы типа routerbo.npk, wireless.npk и т.д.
нашёл у себя all_packages-mipsbe-3.10... поможет?
Ссылка на сообщение
нпк и заливай поочереди
или только wireless.npk
когда уже мат часть начнем учить то http://wiki.mikrotik.com/wiki/Upgrading_RouterOS
Ссылка на сообщение
Какой mipsbe в 2.9?
Ссылка на сообщение
Adaptive Noise Immunity (ANI) adjusts various receiver parameters dynamically to minimize interference and noise effect on the signal quality [1] This setting is added in the wireless driver for Atheros AR5212 and newer chipset cards
всё-таки должна работать :)
Ссылка на сообщение
Протестировал на столе:
Связка RB433AH AP Bridge + 2 клиента: D-link G700 Conceptronik, Ovislink 5460AP
1. G-only ... Одновременный download клиентов - микротик отдаёт примерно по 10Мбит/с каждому. Одновременный download+upload - микротик отдаёт по 4-5Мбит/с каждому, но при этом забирает по 1Мбит/с от каждого (скорость плавает).
2. B-only ... По 3Мбит/с каждому... 2Мбит/с на 40Кбит/с каждому соответственно предыдущему тесту...
А теперь представьте при B режиме 10-15 человек... Жесть... Что сейчас и наблюдаем...
Вопрос ко всем, кто сейчас читает эту ветку:
Какие результаты получали Вы при связке:
1. Микротик база - клиенты: много не Микротиков, не на Атеросе (rtl8186, prism2)
2. Микротик база - клиенты:много не Микротиков, на Атеросе
3. Микротик база - клиенты:много Nano Station
4. Микротик база - клиенты:много Микротиков
Не жадничайте, поделитесь результатами... Очень надо для дальнейшего понимания, что и как работает
Ссылка на сообщение
Что, никто не строил сеть хотя бы по одной из этих схем? НЕ ВЕРЮ! :)
Ссылка на сообщение
База 433AH - клиенты: RB411 - 2шт
G-only ... Одновременный download клиентов - микротик отдаёт примерно по 15Мбит/с каждому. Одновременный download+upload - микротик отдаёт по 6Мбит/с каждому (макс.), при этом забирает по 3Мбит/с от каждого (макс.). Максимально при одновременном down|up двух клиентов получилось на wlan интерфейсе 433AH соотношение 13/6Мбит/с (tx|rx). Скорость очень плавает, но с помощью simple queues можно "нарезать" полосы для каждого клиента исходя из максимально полученной скорости. Т.е. на лицо более производительная схема, чем 1.
p.s. спецы, не поленитесь выложить свои результаты (реально работающих или протестированных схем).
Ссылка на сообщение
подскажите, что означает 1Mbps-SP во вкладке registration напротив клиента?
хотя в этой ветке я уже не надеюсь получить ответ :(
и ещё: ACK Timeout должен быть как можно ниже на клиенте? 140-360 us это много?
Ссылка на сообщение
Очень сильно влияют высоковольтные линии электропередач. Сильное затухание сигнала, прокачка почти никакая...
Ссылка на сообщение
SP - short preamble
LP - long preamble
Ссылка на сообщение
Гость
Ответить в тему...
