Наблюдаю чудеса. Уж и не знаю в какую сторону копать.
Имею Extreme Summit X480 и Juniper MX80 связанные по многолинку (LACP). Хочется перенести траффик на 10-ку.
Что делаю:
На X480:
# sh sha
Load Sharing Monitor
Config    Current    Agg       Ld Share    Ld Share  Agg   Link    Link Up
Master    Master     Control   Algorithm   Group     Mbr   State   Transitions
    1      1        LACP      L3          1          Y      A        1
                              L3          2          Y      A        1
                              L3          3          Y      A        1
                              L3          4          Y      A        1
# sh ports 30 info det
Port:	30(LINK2):
Virtual-router:	VR-Default
Type:		XFP_LR Unsupported Optic Module
Random Early drop:	Unsupported
Admin state:	Enabled with  10G full-duplex
Link State:	Active, 10Gbps, full-duplex
Link Counter: Up 	5 time(s)
VLAN cfg:
STP cfg:
Protocol:
Trunking:	Load sharing is not enabled.
EDP:		Enabled
ELSM:		Disabled
Ethernet OAM:		Disabled
Learning:	Enabled
Unicast Flooding:	Enabled
Multicast Flooding:	Enabled
Broadcast Flooding:	Enabled
Jumbo:	Enabled, MTU= 9216
Flow Control:	Rx-Pause: Disabled	Tx-Pause: Disabled
Priority Flow Control: Disabled
Reflective Relay:	Disabled
Link up/down SNMP trap filter setting:	Enabled
Egress Port Rate:	No-limit
Broadcast Rate:		No-limit
Multicast Rate:		No-limit
Unknown Dest Mac Rate:	No-limit
QoS Profile:	None configured
Ingress Rate Shaping : 		Unsupported
Ingress IPTOS Examination: 	Disabled
Ingress 802.1p Examination: 	Enabled
Ingress 802.1p Inner Exam: 	Disabled
Egress IPTOS Replacement:	Disabled
Egress 802.1p Replacement:	Disabled
NetLogin: 			Disabled
NetLogin port mode: 		Port based VLANs
Smart redundancy: 		Enabled
Software redundant port: 	Disabled
IPFIX:   Disabled		Metering:  Ingress, All Packets, All Traffic
	IPv4 Flow Key Mask:	SIP: 255.255.255.255 		DIP: 255.255.255.255
	IPv6 Flow Key Mask:	SIP: ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
				DIP: ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
Far-End-Fault-Indication: 	Disabled
shared-packet-buffer: 	default
# configure vlan ACC add ports 30 tagg
# configure vlan ACC delete ports 1
На MX80:
# show interfaces ae0.3
description "ACC";
vlan-id 3;
family inet {
   filter {
       input acc;
   address XXX.XX.XXX.X/29;
[edit]
# show interfaces xe-0/0/0
description LINK2;
vlan-tagging;
gigether-options {
   no-flow-control;
[edit]
# run show interfaces xe-0/0/0
Physical interface: xe-0/0/0, Enabled, Physical link is Up
 Interface index: 135, SNMP ifIndex: 508
 Description: DPI
 Link-level type: Ethernet, MTU: 1518, LAN-PHY mode, Speed: 10Gbps,
 Loopback: None, Source filtering: Disabled, Flow control: Disabled
# delete interfaces ae0 unit 3
# set interfaces xe-0/0/0 unit 3 description "ACC"
# set interfaces xe-0/0/0 unit 3 vlan-id 3
# set interfaces xe-0/0/0 unit 3 family inet filter input acc
# set interfaces xe-0/0/0 unit 3 family inet address XXX.XX.XXX.X/29
# delete protocols ospf area 0.0.0.0 interface ae0.3
# set protocols ospf area 0.0.0.0 interface xe-0/0/0.3 authentication md5 1 key ...
По результату имею потери пакетов в 12%. Как при несогласовании дуплекса.
Куда копать?
Плохой патч-корд. Плохой модуль.
Проверяется просмотром детальной статистики на предмет ошибок - show interface extensive для MX, для Summit точной команды не знаю, но она там наверняка есть.
В том-то и дело, что и патчкорд менял, и модули менял.
> show interfaces xe-0/0/0 extensive
 Input errors:
   Errors: 0, Drops: 0, Framing errors: 0, Runts: 0, Policed discards: 0,
   L3 incompletes: 0, L2 channel errors: 0, L2 mismatch timeouts: 0,
   FIFO errors: 0, Resource errors: 0
 Output errors:
   Carrier transitions: 4, Errors: 0, Drops: 0, Collisions: 0, Aged packets: 0,
   FIFO errors: 0, HS link CRC errors: 0, MTU errors: 0, Resource errors: 0
# sh port 30 rxerrors no
Port Rx Error Monitor
Port      Link     Rx      Rx      Rx        Rx      Rx         Rx         Rx
         State    Crc    Over    Under     Frag    Jabber      Align      Lost
DPI       A        0       0        0        0        0          0          0
         Link State: A-Active, R-Ready, NP-Port Not Present L-Loopback
# sh port 30 txerrors no
Port Tx Error Monitor
Port      Link      Tx          Tx          Tx          Tx       Tx       Tx
         State     Coll        Late coll   Deferred    Errors   Lost     Parity
DPI       A         0            0           0         0         0         0
         > indicates Port Display Name truncated past 8 characters
Может я чего недогоняю и Джунику надо какими-то особыми командами 10-ку поднимать?
Можно посмотреть то, что в буфер не влезло. Перегрузка в общем:
p1-vost92.4 # sh ports 17-20 congestion no-refresh
Port Congestion Monitor
Port      Link      Packet
         State     Drop
r1-ae1-x> A         0
r1-ae1-x> A         51
r1-ae1-x> A         0
r1-ae1-x> A         4854274
show pfe statistics traffic
show pfe statistics error
Проверьте вот это на наличие ошибок, можете сюда выложить. Если там счетчики не растут то вероятнее всего проблема не на MX .
Кстати а как проверяете ?
Там тоже тишина. Смотрел уже.
Модули ставил в том числе и такие, на которых у нас сеть агрегации собирали на экстримах. Так-что на 480-й и его настройки я меньше всего подозрения имею. А вот джунику 10-ку впервой заводу.
По диагностике - вообще чудеса сплошные. Ошибок нет. Дропов нет, а пакеты куда-то деваются.
Может для джуника тоже магию а-ля "clear adj" у кошек применить надо?
Тли он с SNR XFP как-то по особому работает?
а как проверяете и где фиксируете ошибки ?
На интерфейсах. Есть в начале темы.
2> show pfe statistics traffic
Packet Forwarding Engine traffic statistics:
   Input  packets:       35428818877589               459543 pps
   Output packets:       35394365442208               462943 pps
Packet Forwarding Engine local traffic statistics:
   Local packets input                 :           5070020493
   Local packets output                :           7310294598
   Software input control plane drops  :                    0
   Software input high drops           :                    0
   Software input medium drops         :                    0
   Software input low drops            :                    0
   Software output drops               :                    0
   Hardware input drops                :            245608318
Packet Forwarding Engine local protocol statistics:
   HDLC keepalives            :                    0
   ATM OAM                    :                    0
   Frame Relay LMI            :                    0
   PPP LCP/NCP                :                    0
   OSPF hello                 :             86319837
   OSPF3 hello                :               828632
   RSVP hello                 :                    0
   LDP hello                  :                    0
   BFD                        :                    1
   IS-IS IIH                  :                    0
   LACP                       :            882252517
   ARP                        :             22781753
   ETHER OAM                  :                    0
   Unknown                    :                   10
Packet Forwarding Engine hardware discard statistics:
   Timeout                    :                    0
   Truncated key              :                    0
   Bits to test               :                    0
   Data error                 :                    0
   Stack underflow            :                    0
   Stack overflow             :                    0
   Normal discard             :          25642368567
   Extended discard           :                    0
   Invalid interface          :                    0
   Info cell drops            :                    0
   Fabric drops               :                    0
Packet Forwarding Engine Input IPv4 Header Checksum Error and Output MTU Error statistics:
   Input Checksum             :                    0
   Output MTU                 :                    0
Slot 0
HSL2 Errors:
 *****  No errors on this PFE  *****
От "Hardware input drops" стоит напрягаться?
Да. Возможно у вас многовато дропов.
dmvy@border> show pfe statistics traffic
   Input  packets:       19282150465538              5628014 pps
   Output packets:       19254233688239              5679768 pps
   Local packets input                 :            360243000
   Local packets output                :            201250289
   Hardware input drops                :                14397
   HDLC keepalives            :                    0
   ATM OAM                    :                    0
   Frame Relay LMI            :                    0
   PPP LCP/NCP                :                    0
   OSPF hello                 :               951628
   OSPF3 hello                :               950643
   RSVP hello                 :                    0
   LDP hello                  :              1906290
   BFD                        :                    0
   IS-IS IIH                  :                    0
   LACP                       :             38029476
   ARP                        :             81521434
   ETHER OAM                  :                    0
   Unknown                    :                   58
   Timeout                    :                    0
   Truncated key              :                    0
   Bits to test               :                    0
   Data error                 :                    0
   Stack underflow            :                    0
   Stack overflow             :                    0
   Normal discard             :          27630917519
   Info cell drops            :                    0
   Fabric drops               :                    0
   Input Checksum             :                    0
   Output MTU                 :               300900
это скорее всего ACL
У нас MX80 соединен с 2 X670 десятками в LACP.
Вот спасибо тебе, добрый человек! Почтил малость. Уже понятнее стало куда рыть. А рыть, похоже, надо в сторону тегов...
А что в фаерволе ACC? На встроенных десятках нет HQoS...
Проверил только-что.
Hardware input drops, видимо, старый, со времен атаки на NTP (где-то март-апрель).
При потере пакетов счетчик не увеличивается.
Итого: Ошибок нет. Дропы есть. Вернулся на исходную точку.
Причем сегодня проводил совсем чистый эксперимент:
На Экстриме: вынес sharing, вынес sflow, вынес vlan с аггрегата, добавил на 10-ку, добавил sharing, добавил sflow.
На Джунике: вынес unit с аггрегата, закоммитил, добавил юнит на 10-ку и в протоколы, закоммитил.
Чего, блин, кому не хватает?
Фаер переносится 1-в-1. И нет, 10-ки вообще первый раз затронул - потребности небыло.
я про шейперы в ACL. в верхних MIC можно использовать 256000 очередей, а нижние порты по логике предназначены для подсоединения к SwitchFabric и в них всего 8 очередей. Вот и спрашиваю: есть ли шейперы в ACL?
Нет. Нету.
Кстати, про очереди. Есть возможность как-то посмотреть? (Я уже туплю.)
Вообще-то, это несколько нечестный MX80. Это 5G-бандл первой инкарнации (синий), но за 5-ку аплинка мы не выходим полюбасу.
Ларчик проще открывался:
Переставил XFP из VIM2-10G4X в намордный и все заработало сразу.
Теперь вот думаю, как оттестировать работу VIM2 модуля и системной шины...
This topic is now closed to further replies.
