Добрый день. Имеется Debian GNU/Linux 7. Три сетевых интерфейса. eth0-встроенная, eth1,eth2- pcie Intel Corporation 82576 Gigabit Network Connection.
eth1 смотрит в локалку. eth2 смотрит в инет. Инета нет. я подключен к машине по ssh через eth1.
Вот проблема:
root@pppoe1:~# service networking restart
[warn] Running /etc/init.d/networking restart is deprecated because it may not re-enable some interfaces ... (warning).
[....] Reconfiguring network interfaces...RTNETLINK answers: File exists
Failed to bring up eth0.
Failed to bring up eth1.
Failed to bring up eth2.
done.
root@pppoe1:~# ifdown eth1
ifdown: interface eth1 not configured
root@pppoe1:~# ifdown eth2
ifdown: interface eth2 not configured
Как сеть работает, если eth1 не сконфигурирован...?
Вот конфиг сети(скопировал с рабочей машины что бы исключить ошибки в синтаксисе, адреса поменял):
auto eth0
iface eth0 inet static
address 192.168.1.100
#gateway 192.168.1.1
netmask 255.255.255.0
auto eth1
   iface eth1 inet static
   address 10.222.0.5
   netmask 255.255.224.0
   gateway 91.230.72.70
auto eth2
   iface eth2 inet static
   address 91.230.72.70
   netmask 255.255.255.252
   gateway 91.230.72.69
И еще:
root@pppoe1:~# cat /etc/udev/rules.d/70-persistent-net.rules
# This file was automatically generated by the /lib/udev/write_net_rules
# program, run by the persistent-net-generator.rules rules file.
# You can modify it, as long as you keep each rule on a single
# line, and change only the value of the NAME= key.
# PCI device 0x10ec:/sys/devices/pci0000:00/0000:00:1c.5/0000:04:00.0 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="60:a4:4c:cb:74:5f", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x8086:/sys/devices/pci0000:00/0000:00:01.1/0000:02:00.0 (igb)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="90:e2:ba:79:05:e6", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth1"
# PCI device 0x8086:/sys/devices/pci0000:00/0000:00:01.1/0000:02:00.1 (igb)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="90:e2:ba:79:05:e7", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth2"
root@pppoe1:~#
мак-адреса и названия сетевых интефейсов совпадают в ifconfig и в etc/udev/rules.d/70-persistent-net.rules.
У меня мало сообщений(
Вы можете отправить еще 3 сообщений сегодня. Данное ограничение будет действовать пока у вас не будет 7 одобренных сообщений.
Покажите
ifconfig
ip ro
ip ru
iptables -vnL
iptables -vnL -t nat
sysctl -a | grep '\.forw' | grep ipv4
auto eth1
address 10.222.0.5
Шлюз может быть только из подсети на которой висит интерфейс, и если протелепатировать, то здесь он вообще не нужен.
Шлюз может быть из любой подсети, кроме 0/8, 127/8 и 224/4, главное чтобы система знала через какой интерфейс пакеты на этот адрес слать.
