Добрый день,
Пытаюсь поднять mpls по схеме, как здесь http://shop.nag.ru/article/oriond48mpls
Конфиг коммутатора А(слева)
mpls enable
ip vrf test
rd 100:1
route-target both 100:1
interface Vlan591
label-switching
ldp enable
ip address 10.168.7.117 255.255.255.252
interface Loopback1
ip address 172.31.255.42 255.255.255.255
interface Loopback3
ip vrf forwarding test
ip address 192.168.200.1 255.255.255.255
router ospf 1
network 10.168.7.116/30 area 0
network 10.168.7.120/30 area 0
network 172.31.255.42/32 area 0
router bgp 92
neighbor 172.31.255.43 remote-as 92
neighbor 172.31.255.43 update-source Loopback1
address-family vpnv4 unicast
neighbor 172.31.255.43 activate
exit-address-family
address-family ipv4 vrf test
redistribute connected
exit-address-family
router ldp
Конфиг коммутатора B аналогичен, но адрес loopback интерфеса 192.168.100.1.
В таблицах обоих коммутаторов роуты видны.
A#sh ip route vrf test
Codes: K - kernel, C - connected, S - static, R - RIP, B - BGP
O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default
B 192.168.100.1/32 [200/0] via 172.31.255.43, 00:04:52 tag:0
C 192.168.200.1/32 is directly connected, Loopback3 tag:0
Total routes are : 2 item(s)
Ping не проходит.
A#ping vrf test src 192.168.200.1 192.168.100.1
Type ^c to abort.
Sending 5 56-byte ICMP Echos to 192.168.100.1, using source address 192.168.200.1, timeout is 2 seconds.
Success rate is 0 percent (0/5), round-trip min/avg/max = 0/0/0 ms
A#sh ver
SNR-S3750G-48S-E Device, Compiled on Nov 15 05:43:44 2013
sysLocation Ak.Vonsovskogo str. 1-118, Ekaterinburg, Russia
CPU Mac f8:f0:82:10:18:b9
Vlan MAC f8:f0:82:10:18:b8
SoftWare Version 7.0.3.5(R0123.0011)
BootRom Version 7.1.4
HardWare Version 1.0.2
CPLD Version N/A
Serial No.:SW032810D610000163
Copyright © 2013 NAG LLC
All rights reserved
Last reboot is cold reset.
Uptime is 0 weeks, 0 days, 1 hours, 8 minutes
A#sh tcam usage
TCAM Total: 1536 extended (3072 standard) entries on unit: 0
USED: 62 extended entries for l4 function
FREE: 1474 extended entries
TCAM Total: 1536 extended (3072 standard) entries on unit: 1
Sorry,
Loopbackи действительно не пингуются.
CE же подключенные к обычному влану, в том же VRF пингуются и работают нормально.
Да,после того как поднялись CE в схеме c 2-мя рутерами, подняли схему с P роутером в центре, работало нормально.
Далее переконфигурировал центральный P в PE c route-reflector, т.е. PE-PE(RR)-PE, то же все нормально.
железо какое используете в роли ПЕ? распишите подробнее )
а VPWS не пробовали?
л3впны конечно хорошо.. но..
п.с. покажите полностью конфиг роутер лпд?
Edited by zhenya`
В тестовой схеме все PE SNR-S3750G-48S-E.
Версии у всех 7.0.3.5(R0207.0012), конфиги как в первом сообщении.
Ни VPLS, ни PW не заработали, только L3VPN.
router ldp
router-id 172.31.255.42
transport-address 172.31.255.42
а у меня VPWS работало в схеме ASR9010 -vlan- 3750. Нюанс только с targeted hello.
Предполагаю, что это работало на старой версии прошивки, в последних версиях VPWS и PW отключены из-за проблем со стабильностью.
Еще, если в конфиге PE прописано так
router ldp
, то пинги между CE вообще не проходят.
Конфиг для LDP должен быть тупым, только
router ldp
, тогда все работает.
А для Orion Delta 48 VPLS и PW будут работать, так как написано в документации ?
L3VPN на Orion Delta 48 работает нормально.
Использовать функционал EoMPLS (VPWS/VPLS) на коммутаторах серии S3750G не рекомендуется. Аппаратная составляющая имеет серьезные ограничения, в ходе эксплуатации могут возникать краши коммутатора.
С S3750G понятно, на OrionDelta 48 функционал EoMPLS (VPWS/VPLS) работает ?
This topic is now closed to further replies.
