Cramac Posted August 9, 2014 Posted August 9, 2014 Всем привет. Есть астрериск и модем. Все настроено и работает, GSM через dongle Но есть проблема, периодически при звонках длительностью 1м40с и выше, связь обрывается. Как можно решить данную проблему? > dongle show devices ID Group State RSSI Mode Submode Provider Name Model Firmware IMEI IMSI Number dongle0 0 Free 15 3 3 Beeline E1550 11.608.12.00.143 3519......4361 250......829 Unknown конфиг донгла # cat dongle.conf [general] interval=15 ; Number of seconds between trying to connect to devices [defaults] context=mobile ; context for incoming calls group=0 ; calling group rxgain=0 ; increase the incoming volume; may be negative txgain=0 ; increase the outgoint volume; may be negative autodeletesms=yes ; auto delete incoming sms resetdongle=yes ; reset dongle during initialization with ATZ command u2diag=-1 ; set ^U2DIAG parameter on device (0 = disable everything except modem function) ; -1 not use ^U2DIAG command usecallingpres=yes ; use the caller ID presentation or not callingpres=allowed_passed_screen ; set caller ID presentation by default use default network settings mindtmfgap=0 mindtmfduration=0 mindtmfinterval=100 exten=9629....79 dtmf=relax [dongle0] rxgain=5 txgain=-2 audio=/dev/ttyUSB1 ; tty port for audio connection; no default value data=/dev/ttyUSB2 ; tty port for AT commands; no default value imei=3519......4361 imsi=2500......02452 Вставить ник Quote
